Old 01-20-2013, 12:21 AM   #1
Chuck2012
Member#: 324568
2005 Wrx Sti
Default 6.75" component's fitment
Rockford Fosgate Power T1675-S
http://www.crutchfield.com/S-AkwHbjp...r-T1675-S.html
What would it require to fit them?
Obviously a spacer but would cutting be involved? Just found to good of a deal not to at least see what everyone else has to say.
Just wanting something more up front so the substage isn't over powering. Also about 100 sqft of sound dampening will be going in to sometime soon.
05 Sti
Chuck2012 is offline   Reply With Quote
Old 01-20-2013, 04:28 PM   #2
Chuck2012
Member#: 324568
2005 Wrx Sti
Anyone ?
Old 08-30-2013, 09:25 PM   #3
capbri52
Member#: 357982
2011 WRX
I'm curious about this as well. I was looking at putting these up front in my 2011. Im concerned about fitting the tweeters in the stock location and the crossovers behind the doors since they are bigger than other component sets.
capbri52 is offline   Reply With Quote
Old 09-01-2013, 08:25 AM   #4
garn
Member#: 56939
Should be no cutting.. 6.75's generally fit 6.5 openings as a standard.
Go check out diymobileaudio.com on speaker recommendations, don't think I would go with those!
garn is offline   Reply With Quote
Old 09-01-2013, 09:40 AM   #5
121jiggawatts
Member#: 345072
2009 Legacy
For 350 you can get way more speaker. To clear the basket you would need about a half inch thick bracket maybe 3/4. if you go more you run into the speaker hitting your door card during play.
https://www.woofersetc.com/p-9623-es...nt-system.aspx
121jiggawatts is offline   Reply With Quote
Old 09-04-2013, 02:51 PM   #6
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Not the small holes in Subaru inner door skins.
You will need a 1/2" or 3/4" spacer to help the basket clear the inner door skin but otherwise you should be good. They won't hit the door panels either. Check here for examples: http://www.subaruaudio.net/subaru-speaker-spacers/
phenryiv1 is offline   Reply With Quote
