Old 01-20-2013, 04:01 PM   #1
USAFSTI
Member#: 224720
2005 Impreza WRX STI
Default engine misfire, new injectors,plugs, filters, gaskets?
I bought my wife a 02 wrx wagon Nov 2011. About 8 months into owning it we got a engine misfire code. Checked everything I could and found nothing. Reflashed the ECU and it never came back on. Recently we moved to Cali and the code became persistent. So I started researching and found it could be fuel injectors. When I looked it had STI pinks in it with all wrx parts. So first I ordered some used OEM wrx ones and installed them. The code went from 2 cylinders to all 4. So I sent all 8 injectors off the get cleaned and flowed (they were really bad) installed the wrx ones after along with new plugs, fuel filter and injector gaskets and now I am still getting misfire codes. It has always run fine and pulled normal. Where I am at now is either the coil packs are bad, valves are bad or ECU is bad. Any help would be awesome! Thanks in advance!
USAFSTI is offline   Reply With Quote
Old 01-20-2013, 05:34 PM   #2
rocketperson7
Member#: 283968
2003 WRX
MBP
so you changed fuel injectors without retuning for them?
well there's your problem
rocketperson7 is offline   Reply With Quote
Old 01-20-2013, 05:45 PM   #3
USAFSTI
Member#: 224720
Negative i have a cobb ap and reflashed the stage 2 after putting the oem blue injectors back in
Old 01-20-2013, 06:04 PM   #4
rocketperson7
Member#: 283968
2003 WRX
MBP
ah, ok
are the misfires audible at idle?
try..
checking for vacuum leaks
cleaning the iacv
clean the maf
do you have a lightweight flywheel?
if you do end up replacing coilpacks, get teh grey ones
Old 01-20-2013, 06:31 PM   #5
USAFSTI
Member#: 224720
No audible but kinda hard to tell it has solid motor and tranny mounts.
I have tried the best I can I think I will get a smoke test for the vacuum lines.
Yes I think it does have a light weight flywheel.
Which ones are the grey ones? The only ones I have found that are grey are the race ones and I don't got 700 for coil packs haha
Old 01-20-2013, 07:10 PM   #6
danger1138
Member#: 279525
04 rex luger!
No , oem grey coilpacks.. They should read 'FKO186'...
danger1138 is offline   Reply With Quote
Old 01-20-2013, 08:02 PM   #7
rocketperson7
Member#: 283968
2003 WRX
MBP
yep
the grey ones came on teh 04+ WRX and the STi, you should then have your tuner add in some dwell for more horsiepowers
you'll use the sparkplug sleeves from the black ones however
lightweight flywheels tend to trigger false misfires
the way I could always tell if mine were false or not were if there was an audible misfire at idle
Old 01-25-2013, 03:25 PM   #8
USAFSTI
Member#: 224720
Where can I get them at? I have been searching the Web and can't see any anywhere!
Old 01-25-2013, 06:38 PM   #9
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
clean off the cam and crank sensors, these cars are prone to having phantom misfires.
You can usually feel a true misfire. Not just hear it, but it should be pretty apparent when driving, especially if they're happening under boost.
Concillian is offline   Reply With Quote
Old 01-25-2013, 07:13 PM   #10
USAFSTI
Member#: 224720
I have noticed that it happens often with these from research.
It drives and pulls on boost like normal. Kinda hard to tell if it's idling hard because it had solid motor and tranny mounts. I have notice a little smoke from the tail pipe a while ago.
Old 01-25-2013, 07:58 PM   #11
quazimoto
Member#: 70395
quazimoto is offline   Reply With Quote
Old 01-25-2013, 08:13 PM   #12
USAFSTI
Member#: 224720
Originally Posted by quazimoto View Post
Good thread I'm about half way done with it already guess I'll try the rest thank you!
Old 01-27-2013, 04:13 PM   #13
civhatch92
Member#: 339711
2002 Wrx
Did you actually gap the plugs down? I replaced my plugs on my 2002 and thought they would be properly gapped from the factory.. wrong.
I was hitting misfire a whole bunch as well. Pulled the plugs back out, gapped them down to .28 and now it runs PERFECT!
civhatch92 is offline   Reply With Quote
Old 01-27-2013, 04:53 PM   #14
USAFSTI
Member#: 224720
No I didn't actually i figured they were as well.
Old 01-27-2013, 05:41 PM   #15
civhatch92
Member#: 339711
2002 Wrx
The ones I picked up were BIGGER than .40!!!!
Definitely pull them out and check, I bet they need to be gapped down to .28 and then it'll be all good!
Old 01-27-2013, 06:22 PM   #16
USAFSTI
Member#: 224720
What plugs are you using?
Old 01-27-2013, 06:40 PM   #17
civhatch92
Member#: 339711
2002 Wrx
I think these: NGK/Iridium/BKR6EIX/WRX/stock
Old 01-27-2013, 07:03 PM   #18
USAFSTI
Member#: 224720
I'm using the same
Old 01-27-2013, 07:08 PM   #19
civhatch92
Member#: 339711
2002 Wrx
Like I said, pull them back out and gap them to .28
Old 01-27-2013, 07:22 PM   #20
USAFSTI
Member#: 224720
Howe did you compress them back to .28
Old 01-27-2013, 07:39 PM   #21
civhatch92
Member#: 339711
2002 Wrx
Old 01-27-2013, 11:01 PM   #22
rocketperson7
Member#: 283968
2003 WRX
MBP
except you shouldn't be gapping iridiums..
when you break off the very very tiny electrode, you will render the plug useless
Old 01-27-2013, 11:13 PM   #23
USAFSTI
Member#: 224720
That's why you done touch the electrode
Old 01-28-2013, 05:36 AM   #24
danger1138
Member#: 279525
04 rex luger!
U can gap them without touching the electrode. You just have to be real careful while measuring the gap.
Old 01-28-2013, 12:09 PM   #25
civhatch92
Member#: 339711
2002 Wrx
Word, worked perfectly fine for me. Never had any issues. Or just buy non-iridum and gap them if you're worried about breaking them.
Way I look at it: improperly gapped - runs like crap with misfires, broken electrode - worthless spark plug, either way something has to be done!
Message Board Statistics All times are GMT -4. The time now is 07:16 AM.
