Old 01-20-2013, 08:19 PM   #1
05_wRex
Member#: 170097
2007 WRX STi PTE6266
Can't seem to change the main title for the updated info. If a mod happens to see this, it should be "05_wRex's 07 STi - 651 WHP 557 WTQ. E98. VSR closed deck block." Or I can make a new thread I suppose. Thanks.
Dyno: Real Mustang Dyno (749/640 dynojet)
Temp: ~70 degrees
Elevation: ~900'
Tuner: Self
Car: 2007 STi, Rotated PTE 6266 .82a/r
Target boost: 37psi (falling to 35.5 at redline)
Target AFR: 11.8
Hp: 651whp
Tq: 557wtq
Fuel: E98
Vehicle Weight: 3351
Here is a video of the pull on my friends Mustang dyno.
Engine: Short block build by VSR motorsports (stage 2+) Long block assembled by me.
Manley Turbo-Tuff I Beam Rods
OEM Rod and Main Bearings
Polished OEM Crank
CP 9.0:1 Pistons with Upgraded Wrist Pins
ARP L19 Head Studs
GSC S2 Cam Shafts
GSC Beehive Valve Springs and Titanium Retainers
Supertech +1.0mm Intake Valves
Supertech +1.0mm Inconel Exhaust Valves
3 Angle Valve Job
Hand Ported and Polished Head Cases
AMS Air Pump/EGR Delete
Gates Racing Kevlar Timing Belt
NGK Iridium 1 Step Colder Spark Plugs
2.5i ported intake manifold
Injector Dynamics 2000cc Injectors
Dual walbro 465 LPH Fuel Pumps
Omnipower 4 Bar MAP Sensor
Exhaust:
MadDad whisper 3" single tip
Killer B Holy header w/ titanium wrap
2" cast up-pipe
Catless Downpipe
TiAL 44mm MVR External Wastegate
Intake:
PTE 6266 Ceramic Ball Bearing Turbo
4” Intake
AMS Front Mount Intercooler and Piping Kit
TiAL Q Blow Off Valve
AEM Intake Air Temperature Sensor
Running gear:
KW V3 coilovers
Volk ce28 18x9
DSS carbon fiber drive shaft
24mm front and rear sways
Management:
Vi-PEC V88 stand alone tuned by me
Hallman pro RX with heavy spring
05_wRex is offline   Reply With Quote
Old 01-20-2013, 08:39 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Nice car...
I think that 601whp pull is a software glitch... change the smoothing to 5 and see what you get. You will probably get around 570whp.
Nice job
Old 01-20-2013, 08:59 PM   #3
05_wRex
Member#: 170097
Originally Posted by juanmedina View Post
Nice car...
Nice job
I had considered that. However, the smoothing is the same for both pulls and the blue run matches the actual dyno run. I used 2 for the smoothing because it made the blue run look almost identical to the actual dyno sheet. I was thinking more along the lines of heat soak on the intake temps on the dyno vs out on the road helping the top end. Intake temps got pretty hot toward the end of the pull on the dyno vs out on the road. We had just got back from lunch and forgot to switch the fans back on in front of the car for the pull. Haha. My friend has been out of town. I will do an actual pull to make sure in the next couple weeks. It certainly feels ridiculous. Haha. 4th gear on race gas feels like 3rd gear on my pump gas tune. Or at least close. Haha.
Old 01-20-2013, 09:06 PM   #4
05_wRex
Member#: 170097
I also went back over the stretch of road I used to make sure there wasn't a dip or downhill slope at the end of the pull after seeing the graph. Just throwing that out there since it is dependant on the road for accurate numbers.
Old 01-20-2013, 09:11 PM   #5
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
It looks like the curves follow very similar paths, with the red curve about 20HP higher throughout most of the run. I agree with Juan that the spike up at the end of the red curve is probably not legitimate. You can trim the upper RPM's with VD and then it looks like you're peaking around 560WHP on that run.
To check your logging/location for pulls I would do at least 3 runs or so. If they're all within ~5HP then you know what you're at. If they vary a lot then the location probably isn't a very good one or you're not doing it in the exact same spot each time.
Anyways, looks like a great setup! Car looks really strong above 5k. I think something like this would a great for strong top end while still keeping a reasonable powerband if you're not revving super high. Looks very nice.
xluben is offline   Reply With Quote
Old 01-20-2013, 09:16 PM   #6
05_wRex
Member#: 170097
I only changed a few cells of fuel and peak boost - peak torque timing. Which is why the gap is bigger before 6000 rpm vs after. The new run was where it should have been AFR wise in the weird looking section vs pig rich on the blue run. I'm sure that has a bit to do with it also. Oddly enough one of the dyno graphs from the "ams prototype intake" thread from this car has a similar jump in the same spot. This was on ams' dyno with their intake on the car.
Old 01-20-2013, 09:38 PM   #7
05_wRex
Member#: 170097
Old 01-20-2013, 10:00 PM   #8
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Wow dude that's a lot of power. Must feel good to have the tune all sorted out now
Slimsti is offline   Reply With Quote
Old 01-20-2013, 10:28 PM   #9
05_wRex
Member#: 170097
Ya. It does feel good for sure. I actually get to drive the car now. Lol.
Old 01-21-2013, 01:27 AM   #10
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Nice thread man its Robert. Looking great!!
stretchedk7 is offline   Reply With Quote
Old 01-21-2013, 07:42 AM   #11
05_wRex
Member#: 170097
Thanks man! I appreciate all the help for sure.
Old 01-21-2013, 08:28 AM   #12
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
No problem glad to see help pay off. Plus it's super easy helping someone who already knows what's going on.
Old 01-30-2013, 09:52 AM   #13
05_wRex
Member#: 170097
Ya. I did so much reading and searching. At least now I can be a professional tuner if I wanted. Lol.
Old 01-30-2013, 09:59 AM   #14
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
there ya go buddy!! hit me up when your ready to make some more power! lets push the pump gas to 500 and race gas to a bit over 600
Old 01-30-2013, 10:07 AM   #15
05_wRex
Member#: 170097
I'll probably leave pump gas alone. Just in case. Haha. One day I might be brave enough to run 32ish psi and see 650-700...definitely going to need some sleeve reinforcement first though. I'm confident in the 580-600 whp range on my tune with race gas and stock sleeves though. Mainly because timing is half of what others consider safe. I couldn't imagine the numbers this thing would put out with 22-27* of timing. Lol.
Old 01-31-2013, 10:26 PM   #16
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
im sure at the same boost levels its at now with hardly any timing changes if any at all i can make 500 with just fueling changes.
also the race gas power would be the same. no more boost than you have been running id just smooth out and lean out the afr's a bit. spool and power will wake up. no reason to risk the timing or boost when theres still plenty of safe power left
Old 02-02-2013, 11:36 AM   #17
05_wRex
Member#: 170097
Ya. I do need to smooth out the afr in the spool area. I took the pump gas tune from 10.8 to 11.2. The map was super rich (10.1-10.5) during spool. When I get a chance, I'll send the cal over. I had to take a lot of fuel out of it. Haha.
Old 02-02-2013, 11:38 AM   #18
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Yeah man I saw the log and map!! 11.2 is great for wot . Nice and safe. I'd be happy with that myself.
Old 02-02-2013, 11:38 AM   #19
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I leave today for sea 2 weeks
Old 02-02-2013, 11:47 AM   #20
05_wRex
Member#: 170097
Ya. I haven't had a chance to get it back out after making a few adjustments. It still needs fuel taken out. Haha. Still pretty rich during spool, but its much closer than it was. I'm having to do it as I can find time so its taking a little longer than usual. Haha.
Gotcha. It will probably be that long before I get it finished up anyways. Lol.
Old 02-02-2013, 11:57 AM   #21
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Sweet man mine will be up and running soon
Old 02-02-2013, 12:01 PM   #22
05_wRex
Member#: 170097
Nice! Its going to be a beast.
Old 02-02-2013, 12:19 PM   #23
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Maybe!! I hope! We will see man
Old 02-02-2013, 12:20 PM   #24
HeubergerMotors
Member#: 344767
2016 WRX Premium
Dark Gray Metallic
Very Nice Build!
Clint @ Heuberger Subaru!
HeubergerMotors is offline   Reply With Quote
Old 02-02-2013, 12:23 PM   #25
05_wRex
Member#: 170097
Originally Posted by HeubergerMotors View Post
Very Nice Build!
Thanks man!
