Closed Thread
Old 01-20-2013, 10:30 PM   #1
rshoop
Member#: 99383
Default How much
How much boost will 800cc injectors support? I've heard any ware from 22-28 any thoughts,
rshoop is offline
Old 01-20-2013, 11:19 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Your question has no clear answer. 22 psi from a td04 is a different volume of air than 22 psi from a 30r and 22 psi passing through your stock ic is different than 22 psi passing through a huge fmic. then 22 psi going into a 2.0 is different than 22 psi going into a 2.5. There are to many variables
mod maniac is offline
Old 01-20-2013, 11:22 PM   #3
hillsboro
Member#: 84823
14 Evo
00 Outback
this guy is a super lurker. 6 posts in 7 years.
hillsboro is offline
Old 01-20-2013, 11:58 PM   #4
living the dream
Member#: 342829
Okay guys this looks like an ok thread to hack.
First post ever and i am stoked to be apart of this great forum you guys are all amazing and a great help!
(Typing this from a cell phone so bare with me, and also just learning my way around the forums)
Okay need an idea of what my car will put down on the dyno just opinions.
Here goes-
2007 wrx tr
60k miles
Vf43 port and polished (pnp)
Intake manifold pnp
Tgv deletes pnp
Exhaust manifold pnp
Throttle body pnp
Grimmspeed up pipe (gs)
3 port boost solenoid gs
8mm phonelic spacers gs+ 3mm k spec spacers
38mm tial ewg
Invidia turbo back catless bellmouth
255 walbro
Aerometer fpr
Perrin fmic
Perrin fuel rails
K&N intake
Step colder plugs
Aquamist water/meth kit 6 series (with and without the kit)
All these parts are in the basement awaiting the install!!! aside for the tbe stage 2.cobb tune
Still running stock tr injectors 550cc* will they hold or what injectors do you perfer (
i can get a set of 1000 cc off a friend or is that a little over kill?!
Stock clutch..i baby it
Fully braced car on tein coilovers
Thanks for any input you have guys!!
Thanks again
living the dream is offline
Old 01-21-2013, 07:44 AM   #5
tuzzio
Member#: 292532
05 STI
Talk to your tuner. Don't thread jack. Too many variables. Get ready to be flamed.
tuzzio is offline
Old 01-21-2013, 08:49 AM   #6
Leafy
Member#: 330625
2006 WRX
Here goes-
2007 wrx tr
60k miles
Intake manifold pnp
Tgv deletes pnp
Throttle body pnp
38mm tial ewg
255 walbro
Aerometer fpr
Perrin fmic
Perrin fuel rails
K&N intake
Step colder plugs
Thanks again
As long as those 1000s are EV14s, you're good to go. If they're like EV6s or Ev1s, forget it, your idle will suck.
Leafy is offline
Old 01-21-2013, 12:33 PM   #7
living the dream
Member#: 342829
I apologize to *rshoop* for the jack, still trying to find my way around the forums.
Well i have been scanning the forums about my injector dilemma and i came up with that my stock tr 550's can be modified to a high 7+ low 8- cc, but the sprays will be less atomized and more direct stream. I also found that the 1000cc are almost the same problem more direct spray less atomization.. my question is.. should i save my money mod my stocks, or spend the cash and do the 1000s and kind of have the same dilemma..
Opinions are very welcome and if someone could guide me to the correct part of this forum to post these questions i would really apperciate it.
I know its heard alot but......is this mod list capable of 400hp (dont tear my head off lol)
Closed Thread
