Old 01-21-2013, 01:03 AM   #1
Warlo3k
Member#: 325957
2012 WRX Sedan
Default ecU shuts off underwot
I am pretty sure i have a grounding issue. the ecu cuts out under wot and sometimes randomly while driving. The dealer says my ecu is randomly shutting off. can anyone tell me on the 2012 wrx where I can look to find any grounding issues?
Warlo3k is offline   Reply With Quote
Old 01-21-2013, 01:29 AM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
The dealer told you your ecu is randomly shutting off and they did nothing to fix the problem? Why not?
Old 01-21-2013, 02:42 AM   #3
Warlo3k
Member#: 325957
2012 WRX Sedan
Yeah the car is modded and they said it is a failed ecu and will be about $1000 dollars to fix.
I think I figured it out though.
I made a ground wire out of some good gauge wire and some wire ends I had laying around. I attached it from the ground point that the factory uses (the one on the back of the drivers side fuel rail shield) to a chassis ground. After 10 pulls, not a single hesitation! I'm going to run it tomorrow as well for a good trip to verify it is indeed fixed.
