01-21-2013, 02:38 AM | #1 |
Member#: 344300
Vehicle:2002 WagonWRXImpreza WRB |
Winter Cold Start Interior pungent gas smell...
No clue... Mid winter morning cold starts sometimes I smell alot of what seems to be someone opening multiple gasoline containers in the cab but when I checked this seemed to be false...Whats up with the gas?
01-21-2013, 03:25 AM | #2 |
Member#: 180204
AKIC
There are a bunch of threads on that. Its the clamps on the fuel lines under the intake Mani. Start the car and look just over the ac pump with a flashlight. You will see the lines under the intake mani. You will know which ones they are cause the clamps are upside down. You will likely see gas dripping. It is a known problem that SOA recognizes. Theyre a pita to get to. You can pay someone to do it for about $600 give or take. You can do it yourself too. You maybe able to recoup the cost from SOA. I just did mine a week ago myself. If you have any mechanic skills it can be done at home.
01-21-2013, 05:39 AM | #3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
01-21-2013, 11:40 AM | #4 |
Member#: 343405
I'm noticing the same thing in my 02 wrx , ill have to check those lines. Thanks for the info share
01-21-2013, 01:07 PM | #5 |
Member#: 344300
Thanks for the good info, Def will checkout the lines my self...much appreciated
01-21-2013, 01:10 PM | #6 |
Member#: 273906
NESIC
Vehicle:2005 Lexus Grandpa |
Yes, it takes about three minutes and it seems like it happens every year as the hoses shrink in the winter. :shrug:
01-21-2013, 10:05 PM | #7 |
Member#: 344263
RMIC
Vehicle:2004 Impreza WRX silver |
i jus bought an 04 wrx about a month ago, and i noticed it smelled like gas in the cold mornings a couple times, but then it just goes away. It hasn't come back yet, could this be the same problem as yall? Thanks.
01-21-2013, 10:15 PM | #8 |
Member#: 180204
AKIC
You will know. I smells like someone spilled gas inside your car. The correct way to fix it is pull the intake mani
01-21-2013, 11:05 PM | #9 |
Member#: 306186
SCIC
Vehicle:2002 Subaru WRX PSM |
The best way to get this fixed is to call/email SOA, they will tell you to setup an appointment with a dealership, the dealer checks to make sure it's covered in the recall then they tell you it's a 4 hour job. It is going to take them double, but you don't have to do the work yourself. Watched them do mine and it wouldn't be hard but things can break etc. I am not in a "cold weather state" in the TSB but it is cold here so they took care of it.
