Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 01-21-2013, 12:13 PM   #1
jakub911
Member#: 44919
2005 Subaru Baja T
Default No power No CEL.... sometimes
I have a 2005 Baja turbo with 134k. It has ran great for years, but now I got a problem. It has happened twice in the past month, I turn on the car it revs higher than normal, revs fluctate, car shakes and when I try to move the car it has no power, cant get it to go over 20mph. Turbo is boosting, I cannot notice any smells, and no CEL comes on. So I parked the car, and then tried a few hours later and it ran brand new...!! So now when I get up for work i never know if im driving or taking the bus... lol ....... any ideas ? Because of course it runs great every time I wanna take it to the shop.
Car has cold are in-take, and up-pipe.
jakub911 is offline   Reply With Quote
Old 01-22-2013, 09:42 AM   #2
faSTI666
Member#: 180204
2005 FXT Stg II 1/2
SSM
Is your maintenance up to date? I would start with cleaning the maf and resetting the computer.
faSTI666 is offline   Reply With Quote
Old 01-25-2013, 10:21 AM   #3
jakub911
Member#: 44919
2005 Subaru Baja T
Had the car towed to a subaru shop..... first they thought it was loose hoses, so they clamped them up left the car outside over night. Same problem in the morning, so today cleaning the injectors, checking the plugs and doing a compression test. :-)
All maintenance was up to date.
Old 01-25-2013, 10:26 AM   #4
jakub911
Member#: 44919
2005 Subaru Baja T
When the car is started at above freezing temps, it runs normal
Old 02-12-2013, 04:02 PM   #5
jakub911
Member#: 44919
2005 Subaru Baja T
So this is really becoming a nightmare...... so the "subaru shop" was a big waste of money. They chargered me for a look threw, new intake arm, tune-up and reclamping a few hoses. 400 dollars later, they didnt find or solve the problem. Now there not to quick to get back to my phone call.
It wasnt that cold this weekend in Chicago, but I hadnt started my car in four days and this morning same thing.
Miss fire on 3 out of 4 cylinders, a burning smell by the passenger side if the engine. No power, and a lot of sputtering. 1 hour of running it settled down and ran normally
Please help :-(
Old 02-12-2013, 04:12 PM   #6
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Do you have any way to datalog to see what's going on when it acts up?
Mr Wrex is offline   Reply With Quote
Old 02-12-2013, 06:58 PM   #7
jakub911
Member#: 44919
2005 Subaru Baja T
Sorry I do not
Old 02-16-2013, 10:00 PM   #8
jakub911
Member#: 44919
2005 Subaru Baja T
So all the shops cant give me a definite answer, but all suggest I should do the head gasket job
There goes 2 grand and "hopefully" thd problem goes away
Old 02-16-2013, 10:14 PM   #9
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Sounds like a misbehaving injector or o2 sensor on the way out
Slimsti is offline   Reply With Quote
Old 02-18-2013, 02:06 PM   #10
jakub911
Member#: 44919
2005 Subaru Baja T
It has a uppipe bypass....resistor. could that be the issues ?
Old 02-18-2013, 06:04 PM   #11
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
unplug the front O2 and see how it runs.
mechatricity is offline   Reply With Quote
Old 03-12-2013, 09:55 PM   #12
jakub911
Member#: 44919
2005 Subaru Baja T
Well I picked up the car from the shop, they did the headgasket along with everything else that goes with it.....1500 dollars later the problem is still there !!!!!.... This is very very frustrating. I will try to unplug the 02 sensor next time the weather is cold. Thanks
Old 03-21-2013, 04:27 PM   #13
jakub911
Member#: 44919
2005 Subaru Baja T
Had a few cold days here in Chicago, and the last two morning car barely ran. The front 02 sensor code turned on the other day so I picked up a Bosch one, and will install tonight. Next will be new injectors and/or coils, unless anyone has any other suggestions
Old 03-21-2013, 06:03 PM   #14
Sessions10
Member#: 350945
2011 WRX
Sounds electrical....
Sessions10 is offline   Reply With Quote
Old 03-21-2013, 07:29 PM   #15
findurpath
Member#: 277487
2006 CGM WRX Limited
6sp, 18G, Phatron tuned
Wow, the shop told you it was a head gasket issue???? What led them to that conclusion?
Before you start throwing more money and parts at it with no guarantee of resolving of the issue, I'd look into trying to do some logging. Find a tactrix cable or borrow a friend's AP and try to get some logs.
findurpath is offline   Reply With Quote
Old 12-02-2013, 12:51 AM   #16
jakub911
Member#: 44919
2005 Subaru Baja T
Well winter has returned and so has my baja cold running problem. I've read about the legacy tumbler gasket issue, does any one know if we by chance share the same gaskets ?
Old 12-02-2013, 04:57 PM   #17
ShawDizzle
Member#: 118902
08 WRX Premium Sdn
Spark plugs changed in recent past? Could just be bad plugs
ShawDizzle is offline   Reply With Quote
Old 12-02-2013, 05:21 PM   #18
BeastianSTI
Member#: 310506
2005 WRX STi
Silver, Sexy 'n Raspy
Interested in hearing what the resolution to this one is ... similar issues here.
BeastianSTI is offline   Reply With Quote
Old 12-02-2013, 05:26 PM   #19
Razgeiz
Member#: 358782
2013 STi
Dude... calm yourself this is clearly a spontaneous issue that only rears itself when cold. STOP DUMPING MONEY INTO IT. when you ask a question on here how about waiting for an answer before asking then immediately taking it to a shop so they can just swap out parts with no real knowledge of the issue. How about this. You have aftermarket parts on the car without a tune I'm assuming. Try returning to stock! Get stock air box and go back to the stock up pipe. OR GET A TUNE FOR THE PARTS. I can tell you though the CAI is netting you nothing at stock turbo level and without a tune. And almost nothing with a tune.
You can thank me later.
Razgeiz is online now   Reply With Quote
Old 12-02-2013, 09:56 PM   #20
jakub911
Member#: 44919
2005 Subaru Baja T
Spark plug were done last winter, it didn't help. Car has the stock intake, I do have a cat less upipe , installed a few years ago. Im open to all options it could be the up-pipe. I haven't put any money in the car this winter, when warm it runs perfect.
Old 12-02-2013, 11:07 PM   #21
Razgeiz
Member#: 358782
2013 STi
Have you cleaned the maf?
Old 12-04-2013, 12:19 AM   #22
jakub911
Member#: 44919
2005 Subaru Baja T
Yes MAF was cleaned about a year ago.
Old 12-04-2013, 01:16 AM   #23
JonnyV2889
Member#: 197384
2006 WRX Ltd
Really? I try to do mine every oil change.
JonnyV2889 is offline   Reply With Quote
Old 12-04-2013, 02:29 AM   #24
Andrewxxcarlson
Member#: 316415
2006 WRX
Overkill and risk damage id feel.
Andrewxxcarlson is offline   Reply With Quote
Old 12-04-2013, 09:07 AM   #25
Razgeiz
Member#: 358782
2013 STi
What's wrong with the factory set intervals for maintenance? Other than the oil change intervals even my local tech disagrees and says it should be no more than 3k. But I digress.
