Old 01-21-2013, 08:35 PM   #26
2011scoobywrx
Member#: 344372
2011 wrx
blue
****! thanks for the advice people. I did realize there was a concern so thats why i brought it up. My next question is should i just buy a cobb intake and cobb tuner and set it to stage 2?
2011scoobywrx is offline   Reply With Quote
Old 01-21-2013, 08:36 PM   #27
2011scoobywrx
Member#: 344372
2011 wrx
blue
how would i test the boost gauge? it does make a noises sometimes lol and light flickers from red to greenish...
Old 01-21-2013, 08:39 PM   #28
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
so you dont have an accessport?
BigRob74 is offline   Reply With Quote
Old 01-21-2013, 08:40 PM   #29
2011scoobywrx
Member#: 344372
2011 wrx
blue
No, the car came with nothing.
Old 01-21-2013, 08:42 PM   #30
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Where is the boost gauge sensor hose? I don't see a t-section on your BPV hose for one, which is typically where one would hook up to. Take a pic of as much of the hose that connects to the top of the BPV.
Mr Wrex is offline   Reply With Quote
Old 01-21-2013, 08:52 PM   #31
2011scoobywrx
Member#: 344372
2011 wrx
blue
its there
Old 01-21-2013, 08:57 PM   #32
2011scoobywrx
Member#: 344372
2011 wrx
blue
Old 01-21-2013, 09:00 PM   #33
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
you better hope there is some sort of tune on the car
Old 01-21-2013, 09:03 PM   #34
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
rather than replace the parts you have and buy an accessport to put a tune on it,
take the car to a tuner and get it tuned for the parts you've got.
stay the hell away from boost until you can get this sorted out. Even if it turns out to just be a bad gauge, you need to be sure that the thing is tuned. Intake and exhaust + No tune = no bueno.
aerosaaber is offline   Reply With Quote
Old 01-21-2013, 09:10 PM   #35
2011scoobywrx
Member#: 344372
2011 wrx
blue
I agree. I will take it to Titan Motorsports here in Orlando. Im sure it is tuned cause wouldnt the a/f be crazy and would pull like ****? Someone put some money in it before me and i think they went with a very aggressive tune. All im trying to do is reduce the boost for longevity, not that its drives crazy or anything. I will report back with my findings!
thanks again
Old 01-21-2013, 09:13 PM   #36
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Is it me or are those boost hoses hooked up incorrectly? Kinda hard to see from the pic which hose is for the sensor (who the hell hooks one up there?!)
Old 01-21-2013, 09:20 PM   #37
thebigevilfoot
Member#: 253836
2008 AW e90 M3
2011 WRX 350/365- sold :(
+1
That location does not look right. Also, I would either get an AP and test the boost from that, or re-route the boost guage to the proper location and check again, and on top of those two things I would get a proper tune. As many have said before, stay away from boost 25 is pushing the limits of a lot of stuff.
thebigevilfoot is offline   Reply With Quote
Old 01-21-2013, 09:37 PM   #38
bad mutha
Member#: 106747
04 forester xt
crp
find someone other than TITAN, check out PRS, or REV WORKS.
bad mutha is offline   Reply With Quote
Old 01-21-2013, 09:38 PM   #39
bad mutha
Member#: 106747
04 forester xt
crp
where did you buy the car?
Old 01-21-2013, 09:43 PM   #40
TwoFifty
Member#: 261764
2003 Impreza WRX
First thing you need to do is verify that your boost gauge is reading correctly, I do not believe for one minute your stage 2 WRX is actually pushing 25psi.
TwoFifty is offline   Reply With Quote
Old 01-21-2013, 10:00 PM   #41
2011scoobywrx
Member#: 344372
2011 wrx
blue
Car was bought from a chevy dealership and they didnt know much about the car. I would like to get in touch with the owner of it so i could ask but not easy to get that info. or is it?
If I were to buy a map created by perrin for my intake, could i use the Cobb ap to load it on my car? and set up a new tune?
Id like to just buy the cobb ap and use a shelf map or one that perrin created. They say if my dp is catless, it could cause over boosting issues. i believe there is a cat on the dp tho
Old 01-21-2013, 10:06 PM   #42
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
OP your top photo of the "t" behind the turbo goes to the boost solenoid. The second photo shows the BPV. Follow the small tubing coming off the BPV and see if theres a "t" somewhere in that line. Most people tap into that line for the boost gauge. btw push the tubing up tighter on the barb and put a cable tie on it to make sure it doesn't pop of.
nmlittlebigman is offline   Reply With Quote
Old 01-21-2013, 10:23 PM   #43
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
like others said take it to a shop and let them see what you got on the car 1st. the accessport is going to cost you 500 bux, and then you could run the ots maps, but im not sure cobb has one for a perrin intake. or you get a map from torquedperformance.com, but you would need a tatrix cable to load it onto the car.
Old 01-21-2013, 10:27 PM   #44
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
its there
Looking at this photo, it appears that the t-fitting is connected to the turbo, but not the IWG. What hose is connected to the IWG? Could you take a better angled photo of this area? I'm kinda curious to see what hoses are connected to those two nipples.
Old 01-21-2013, 10:30 PM   #45
2011scoobywrx
Member#: 344372
2011 wrx
blue
ok soo....this looks like it is the boost gauge wiring? goes into firewall and has a hose end that goes into the "T" in the next pic
the hose off the bpv goes into a braided thicker line that i cant follow
Old 01-21-2013, 10:42 PM   #46
2011scoobywrx
Member#: 344372
2011 wrx
blue
I looked and the hose is connected to inlet of turbo loops around to wastegate and then into the "T" where another hose goes under the manifold..
Old 01-21-2013, 10:49 PM   #47
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
One port on the boost controller should go to the turbo inlet and the other to the t-fitting which attaches to the turbo and IWG. This is a different boost controller, but the hoses are run the same:
hose hookup
Old 01-21-2013, 10:58 PM   #48
adevney
Member#: 271383
2012 WRX Sedan
All I see is a CAI and DP. It also looks like you have the stock boost controller, which I'm sure sucks to hold that kind of boost. You should get it up on a lift to check what other parts, if any, the previous owner slapped onto there. Like bigrob stated, the stock TMIC and BPV weren't designed those high boost levels with their plastic bits.
FWIW, I have a TP stage 3+ build and several other parts and I'm only doing 22psi on stock internals. I'm expecting the engine to give out fairly soon.
You're expecting your TP stage 3 car to "give out"? You should be fine.
adevney is offline   Reply With Quote
Old 01-21-2013, 10:59 PM   #49
WRrex12
Member#: 327113
2012 WRX Sedan
DMG
Why don't u check the boost using a simple tool like the torque app for cell phones?
WRrex12 is offline   Reply With Quote
Old 01-21-2013, 11:02 PM   #50
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Aggressive tune and I have more than just the parts required for the stage 3 TP tune (EWG, pnp header, etc etc)... our pistons aren't invincible ya know
