Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-21-2013, 07:36 PM   #1
ehiddenidentity01
Member#: 279169
2004 impreza wrx sti
wrb
Default 04 sti leaning out
04 sti leaning out with any kind of boost bad. fuel pump is good fue pressure regulator good no leaks. runs fine in closed lood but when it goes to open lood it just gets stupid lean. thinking fuel pump controll unit. any thoughts?
20g
850cc injectors
walbro 255
ewg
happened all of a suddon
ehiddenidentity01 is offline   Reply With Quote
Old 01-21-2013, 08:08 PM   #2
AuthenticAMD
Member#: 212239
2008 Legacy Spec B
QSM (stage 3.5)
Not very descriptive. Are you tuned? If not then that is why it's leaning out. Could be post MAF leak causing you to lean out as well.
AuthenticAMD is offline   Reply With Quote
Old 01-21-2013, 08:44 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
could you list when the parts were installed?
