Old 01-21-2013, 10:01 PM   #1
viraju
Member#: 193719
1999 Impreza WRX STI
Rally Blue
Default Sudden Power Loss
While I was driving last week, I felt a sudden power loss. In low and mid RPM's I notice about 25% power loss. The engine Rev's but no power even in first gear and second gear under normal driving conditions. However when I rev the car I can see the boost is reaching to higher levels but power is less. I check the fuel pressure in idle and its 3 bar (No probs with pump). No clutch slip and the clutch is new. The car runs on EMS ECU and MAF sensor is not used. Please let me know your comments.
Thanks in advance
viraju is offline   Reply With Quote
Old 01-21-2013, 10:32 PM   #2
Andrewxxcarlson
Member#: 316415
2006 WRX
Mods list please.
Usually lose of power is the ecu pulling timing due to knock. Can ya get a log?
Andrewxxcarlson is offline   Reply With Quote
Old 01-21-2013, 10:46 PM   #3
Philydrake
Member#: 344430
Are you miss firing in any cylinders?
Philydrake is offline   Reply With Quote
Old 01-21-2013, 10:52 PM   #4
Philydrake
Member#: 344430
Hook it up to a code reader
Old 01-21-2013, 11:11 PM   #5
viraju
Member#: 193719
Rally Blue
No Misfiring or knock at all. Engine runs smooth, It rev's but no power
Old 01-21-2013, 11:20 PM   #6
wrx1392
Member#: 342331
2003 wrx
blue
is it making boost ? could be a boost leak ,also ck the timing belt if it jumped a tooth that could do it ,compression ck would hurt either .
wrx1392 is offline   Reply With Quote
Old 01-21-2013, 11:21 PM   #7
viraju
Member#: 193719
Rally Blue
Originally Posted by Andrewxxcarlson View Post
Mods list please.
Sorry, I dont have a cable to Data log the ECU. However after this issue I increase the octane level from 92 to about 95 or more but no significant change.
Mod List
EMS ECU
2.5 Catless Down/Mid pipe and Exhaust
K&N Filter in Stock Airbox
Engine Built - wiseco pistons 93mm / Eagle Rods / Cosworth Bearing
Excedy Six spring Sports clutch and plate
HKS BOV
HKS Sparkplugs
B
Old 01-21-2013, 11:31 PM   #8
viraju
Member#: 193719
Rally Blue
Yes its making boost but slowly, But my issue is even in very low RPM's (1~2.5) under normal driving conditions its power is less (Ex taking the car out from the gaurage). It feels like clutch plate is gone (But clutch is new and no clutch slip at all). Yeah whould check the compression but I didnt drive the car in high boost for a very long time as I was not well (set to 0.8 bar now for normal driving).
Old 03-23-2013, 07:29 PM   #9
BeratE
Member#: 79596
04 WRX Wagon
JBP
Any resolution to this?
BeratE is offline   Reply With Quote
Old 03-24-2013, 09:23 PM   #10
viraju
Member#: 193719
Rally Blue
Yes Found the issue. The reason was a blocked fuel filter. Replace the filter and also clean the small filter in the fuel pump
