Old 01-22-2013, 02:53 AM   #1
Hammelcamel
Member#: 344275
2008 WRX
Rally blue
Default Fuel Economy question
Hey all,
Just as a forewarning, I am new to:
a) the Subaru family,
b) manual transmission cars, and
c) forum-based communities,
so please bear with me.
I know that you don't buy a Subaru for gas mileage, you buy it for reliability, AWD, and in many cases, speed, but I am curious - do you get better gas mileage (in your experience) while in low gears (1-3) or high gears (4 and 5)? Just trying to optimize my fun-ness and spend less time at the pump. If I can't, I'm fine with having to fuel often, just wonderin'.
Also, thanks for being my Subie brothers / sisters!
-Gunther
Hammelcamel is offline   Reply With Quote
Old 01-22-2013, 03:19 AM   #2
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
If you're driving in city traffic with stop lights/signs you will get poor gas mileage, that's a given. You'll get the best mileage driving on the highway where you can use the higher gears.
Bottom line is, you gotta pay to play.
Frankh21 is offline   Reply With Quote
Old 01-22-2013, 03:36 AM   #3
mfmunh
Member#: 307040
2012 WRX
I own '12 WRX hatch; I find it that i get better milage shifting under/around 2500 rpm And staying under 2800 on high ways. I get 26/27 mpg thats with 80% highway 20% city.
OEM crossbar +yakima forklift + fairing = 23/24
OEM crossbar + forklift = 25
Ive recently got the Perrin wing riser and I've notice i get better milage when i "let loose". I will test this theory a bit more.
mfmunh is offline   Reply With Quote
Old 01-22-2013, 04:03 AM   #4
Hammelcamel
Member#: 344275
2008 WRX
Rally blue
Sounds great guys, thanks for the insight.
Old 01-22-2013, 08:32 AM   #5
Loyale93
Member#: 91347
'13 XV Crosstrek,
1050 Triumph Speed Triple
If you learn about how a transmission works, the answer will be obvious. I recommend checking out www.howstuffworks.com and read their article on how a manual transmission works.
Bottom line, in higher gears, your engine makes fewer revs per tire rotation (speed) when compared to the lower gears. So it's using less fuel per mph. That said, if you start in 5th gear, the engine will lug about until you get up to speed, which isn't going to work well. Driving with my revs somewhere around 2800 (regardless of gear) nets me the best mpg.
However, you should fill out your profile, so we know what type of car you have. If it's a turbo, that all goes out the window. well, the 2800rpms anyway.
Loyale93 is offline   Reply With Quote
Old 01-22-2013, 08:38 AM   #6
Mattygb2128
Member#: 344472
I have an auto trans and was wondering if there was any kin of regearing i could do to get better MPG?? Not that mine terrible..just curious.
Mattygb2128 is offline   Reply With Quote
Old 01-22-2013, 08:40 AM   #7
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
If you are interested in MPG, google hypermiler and look for tips. In the end, your right foot dictates your MPG. http://forums.nasioc.com/forums/usercp.php? needs to be filled out as we have no idea what you drive. KNOW that cruise control should always be used as it is 7000% smarter than you in most cases. Know the sticker highway MPG figure? They get that from using cruise control. This is especially true in turbo models as high gear + boost is more fuel effecient than low gear + no boost which is contrary to what 98.5% of Subaru owners think.
Old 01-22-2013, 08:42 AM   #8
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
No. The cost would kill you if it could be done which it can't. The only thing you COULD do is to change tire size which will affect your apparent final drive. By size I mean height of tire, so if you had 60 series tires and swapped to 55 series this would affect MPG, but I'm not smart enough to how taller or shorter tires will affect MPG, but shorter ones make you accelerate faster is all I know.
Old 01-22-2013, 08:45 AM   #9
Loyale93
Member#: 91347
'13 XV Crosstrek,
I'm sure there is. Probably gearing you could swap, or solenoids you could change. But honestly, the amount of money you'd spend on that probably wouldn't pan out for an extra 1mpg.
Quick and dirty calculation: at $3/gal of gas, driving 20,000 miles per year.
If you increased your gas mileage from 23mpg to 25 mpg, you would save $100 a year.
Old 01-22-2013, 08:54 AM   #10
Mattygb2128
Member#: 344472
I figured it was something like that. Thanks guys!
Old 01-22-2013, 08:58 AM   #11
Aknight55
Member#: 307518
2004 E55
Actually a bit over $200 a year.
Aknight55 is offline   Reply With Quote
Old 01-22-2013, 09:03 AM   #12
DearDiaryJackpot
Member#: 343041
2013 wrx limited
metallic silver
At the end off the day. It all depends on your right foot. Yes, You can change shift at 2500 to help but how fast do you get there... that's what makes the difference.
DearDiaryJackpot is offline   Reply With Quote
Old 01-22-2013, 09:09 AM   #13
Jack ffr1846
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
$208.70 (approximately)
Subaru autos (non-CVT) suck down the gas. For 3 years, my wife drove an 08 Outback n/a auto and I drove an 08 LGT manual. Although I had an extra 75hp, I regularly got 27mpg. She's almost never broken 22. Autos are not mileage options.
Jack ffr1846 is offline   Reply With Quote
Old 01-22-2013, 09:18 AM   #14
Mike05wrx
Member#: 314747
2005 WRX
back on my stage 2 tune, i averaged about 26-28 mpg on the highway. now that i'm stage 3, on the highway i average about 24-26. still fairly decent. it really depends on how you drive, staying out of boost is the best way to save on gas
Mike05wrx is offline   Reply With Quote
Old 01-22-2013, 11:21 AM   #15
LUMBERZACK
Member#: 340009
2007 Impreza WRX STi
Crystal Gray Metallic
The most my car has ever gotten was 28 mpg, I was driving at 45mph the whole tank basically and never stopped. Indian reservation highway speed limits are deathly slow. On my commute for school at stage 1, I would get 22-23mpg and at stage 2 I get 24-25mpg
LUMBERZACK is online now   Reply With Quote
Old 01-22-2013, 11:22 AM   #16
Loyale93
Member#: 91347
'13 XV Crosstrek,
Damn my WPI education!!
Old 01-22-2013, 11:24 AM   #17
Jack ffr1846
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Musta gone downhill after I left......
Old 01-22-2013, 11:26 AM   #18
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Subaru Fun = (fuel consumption) x arbitrary constant. They're uttermostly and directly proportional.
Old 01-22-2013, 12:40 PM   #19
SpamBot
Member#: 287534
Gearing and mileage with an auto - hmmm, without going too deep, the answer is: yes and no. Depending on what trans, year, and model you have (I'm going to assume a non-CVT) there are various final drive ratios that will fit the transmission. There is nothing in the control system (solenoids, valve body, or TCM) that can change the ratios. But, the question is, what type of driving do you do? If you do primarily highway, you select a gear that will allow the engine to run at it's "happy" RPM for the speed you drive. Put that same ratio into a car driven primarily in stop and go city traffic, and your mileage will suffer. Don't forget, you'd also have to change your rear differential to match the front, or bad things happen. Very bad things.
Can it be done? Sure. Is it worth it? No. Good driving habits will yield better MPG numbers a lot cheaper than gearing changes. You may not want to go to the extremes of some of the hyper-mileage drivers (and I know one) but just following some of their suggestions for throttle management will surprise you.
SpamBot is offline   Reply With Quote
Old 01-22-2013, 03:58 PM   #20
mhoerath
Member#: 131379
2003 354 ftlb@3k rpm
justablue hatch
I get 25 mpg city driving, and a heavy foot and 350 ft lbs/280 whp. Did not buy and mod the car for fuel efficiency.
My wife's brand new CVT 2.5l outback gets 24 city driving. Haven't been on a road trip yet but think it will get 30-32. My daughter wanted gas mileage and she has a Yaris, great design if you want 40-45 mpg.
big diff is premium vs regular gas, turbo vs. NA.
mhoerath is offline   Reply With Quote
Old 01-22-2013, 09:18 PM   #21
comeshot731
Member#: 344559
95 240sx
Not sure if mentioned before but
TIRE Pressure is very important to check.
This can reduce mileage alot not to mention tire wear.
comeshot731 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 12:24 AM.
