Old 01-22-2013, 01:55 PM   #1
BDesh
Member#: 324324
2005 STi
CGM
Default Suddenly Leaning out at WOT
Ok so I have finally completed my new build with break-in miles and final tune complete.
Link to mods and final tune:
http://forums.nasioc.com/forums/show....php?t=2453554
Im running E85 and have had my car out twice in the last two weeks since this tune. We tuned the car to see 11.8-12.2 AFR at WOT.
I havent changed a thing with the car, It did have a couple really cold starts. Now at WOT im starting to see 12.4 -12.6. The car runs great, the AFR's are great in normal driving conditions. Just seems to lean out above 5500RPM's
Im just looking for advice on where to start. Could I have fouled a plug? or maybe my fuel pump is dying.. We did max out the Wolboro 255 on the above tune on 21psi, which I thought was low.
Advice appreciated!
BDesh is offline   Reply With Quote
Old 01-22-2013, 03:19 PM   #2
Tripintaz
Member#: 245218
2013 STI Limited
What are your learned long term fuel trims at?
Tripintaz is offline   Reply With Quote
Old 01-22-2013, 05:15 PM   #3
BDesh
Member#: 324324
2005 STi
CGM
Where can I find my learned long term fuel trims in AEM software?
Old 01-22-2013, 08:47 PM   #4
BDesh
Member#: 324324
2005 STi
CGM
Ok I did some more testing and the AFR's at WOT throttle were avg. 11.9 to 12.3 with the occasional jump to 12.5 or 12.6 for a split second then dropped back down to avg. 12.3.
What could be causing the spit second jumps?
Old 01-23-2013, 12:19 AM   #5
Tripintaz
Member#: 245218
2013 STI Limited
A post maf boost leak is one possibility. If you figure out how to read your fuel trims it might shed some light on things.
