Old 01-23-2013, 04:21 PM   #1
Wavemandan
Member#: 341351
2007 Sti
Pearl White
Default Aux audio button non-existent
I have a 2007 Sti sedan and I have an aux port but I can't get the oem head unit to turn to it.
Wavemandan is offline   Reply With Quote
Old 01-23-2013, 05:15 PM   #2
Wavemandan
Member#: 341351
2007 Sti
Pearl White
This is really irritating. Someone's gotta know this.
Old 01-23-2013, 10:46 PM   #3
chris07sti
Member#: 177312
2005 STI
Aspen white
you should just be able to push the AUX button. From your title, do you not have that button? if not you probably have a older head unit.
OR
chris07sti is offline   Reply With Quote
Old 01-24-2013, 08:15 PM   #4
Wavemandan
Member#: 341351
2007 Sti
Pearl White
I have an older head unit. So I have to get a new one?
Old 01-26-2013, 12:30 AM   #5
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Most likely explanations:
A) Your STi originally had a different OEM HU (with aux capability --that feature was added in 2007 Impreza models), but the previous owner removed it for some reason and replaced it with an older model.
B) Yours is the one that originally came with your car, and someone used an aftermarket accessory to add aux. Could be an FM modulator (where you must tune to a certain FM station, and possibly need to flip a hidden switch to activate/deactivate), or a hack soldered inside the HU. Pull out your HU and see where the aux cable goes.
Is it a factory aux jack (where the ashtray would be)?
What is the model number printed on the front of your HU?
SVXdc is offline   Reply With Quote
Old 01-27-2013, 01:56 AM   #6
SlowCB7
Member#: 343576
2005 Saab 9-2x Aero
It also could be the Jazzy Engineering factory add-in aux input, that's what I have. If that's what it is you'll need a silent CD and it should just play over the CD channel
SlowCB7 is offline   Reply With Quote
