Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 09-17-2002, 11:23 AM   #1
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Default Drove to work on my link today.
Finally working to the point that I trust it to take me places.
pinging if I step on it in the higher gears. Need to do the o2 swap so my sensor is more accurate to start tuning with.
Midwayman is offline   Reply With Quote
Old 09-17-2002, 11:47 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I'm going to have to check out your map sometime.
I've got mine tuned to the point of making great power (outran a stock Si last night up to like 85-ish... thats pretty much unheard of in a near-stock RS) without pinging other then occasional tip-in, and still cruise isn't too bad. I can get just under 17mpg on my current map, though considering I drive it hard, thats pretty decent.
Old 09-17-2002, 11:51 AM   #3
mykrrrr
Member#: 733
'13 Focus ST
Talking
When's the Midwayman 2.5 RS-t EVO 2 coming out Brian??? Any target date yet???
-mykr.
mykrrrr is offline   Reply With Quote
Old 09-17-2002, 12:09 PM   #4
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Its real near the base map right now. I still deciding on where to set the master fuel value and then starting my line tuning, but I need my o2 swapped before I can do much more.
At idle im reading the rich side of stoich and thats on the second o2.
As far as when the turbo goes in? Im hoping late oct-early november. Alot depends on how confident I am with tuning. Once it gets cold it wont be much fun out in the garage.
Old 09-17-2002, 12:10 PM   #5
mykrrrr
Member#: 733
'13 Focus ST
Unhappy
Yikes!!! I'd better stop dreaming of turboing my RS and either get a Toyota Prius, Honda Civic Hybrid or a Golf TDI...I need MPG similar to my car now. Even now I think the MPG is low.
I hate cars...
-mykr.
Old 09-17-2002, 12:27 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Myk - You've never driven with me, have you?
Old 09-17-2002, 12:37 PM   #7
mykrrrr
Member#: 733
'13 Focus ST
I think once but I did drive yer car when we did my suspension that one nite @ Action Audio with Donnie.
What's the average MPG of a "sanely" driven RS-t???
-mykr.
Old 09-17-2002, 12:47 PM   #8
kyledooley
Member#: 1055
2005 No legacy for u
It's a diesel
23 mpg all day in town.
30-32 mpg on extended highway cruising.
As for the sanely driven part, we'll leave that up to the courts...
Kyle
kyledooley is offline   Reply With Quote
Old 09-17-2002, 01:39 PM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I used to get 20-21mpg around town while beating on my car while it was RS-T. The best mpg I've ever gotten on the highway was around 29mpg and that was in stock form.
Old 09-17-2002, 08:49 PM   #10
Marcin
Member#: 2874
2005 CGM WRX WGN
Jorge Tunned BattleWagon
Good job Brian.
My LinkPlus arrived toady.
It's Bed-Mounted
Marcin is offline   Reply With Quote
Old 09-17-2002, 09:23 PM   #11
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Woo woo Brian. So that is what you wanted to show me..
2 things.
Datalog your car on the stock ECu and get a timng map with relation to rpm and MAP.
Tune for more timing at lower MAP readings and higher RPM.
1 thing for Marcin.. We don't want to know what you do in bed!
Revision is offline   Reply With Quote
Old 09-17-2002, 10:06 PM   #12
Marcin
Member#: 2874
2005 CGM WRX WGN
Andrew why are you always bringing up the sick ***t.
You are just wrong, you need profesional help.
Old 09-17-2002, 10:26 PM   #13
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
wow, I get about 15mpg on average....
btw nick, you have a part very few "near stock" RS's have, in that flywheel, that can contribute some as well
Akirasoft is offline   Reply With Quote
Old 09-18-2002, 01:32 AM   #14
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Yah, it was my first spin out with the ecu working properly. Dont suppose you can help me out some this weekend? Will the obd-ii logger pull the timing map out? Keeping the stock ecu in the car "just in case" Also its hard to start the car. Wonder if I need more or less crank enrichment?
2 things.
Old 09-18-2002, 01:35 AM   #15
Marcin
Member#: 2874
2005 CGM WRX WGN
How was the drive itself, how would you describe the way the engin was running. Do you still have a lot driveability of issues?
Old 09-18-2002, 01:43 AM   #16
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Well, its hard to start right now, and knocks if I get into the throttle too much, but otherwise is running smoothly. (And idles perfectly!)
Old 09-18-2002, 01:49 AM   #17
Marcin
Member#: 2874
2005 CGM WRX WGN
Does the knock sensor reacts to the knocking? I hope you get the issue resolved.
Idles perfecly, now thats unheard of.
Old 09-18-2002, 02:55 AM   #18
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
most knock sensors will not pick up ping, pinging is just pre-igintion...and most knock sensors are tuned to ignore light pinging(audible pinging) it's the pinging you don't hear that the knock sensor is worried about.
jermey
Old 09-18-2002, 08:39 AM   #19
Revision
Member#: 242
MY05 PSM GGA !STOCK
For starting enrichments let me give you an example:
10% extra fuel on starting.
200% extra fuel depending on coolant temp. Full 200% if coolant is -30 deg C or less ramping down to 0% extra fuel at 80 deg C.
Old 09-18-2002, 02:33 PM   #20
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Exclamation I want/need an ECU
Midwayman- Do you have the plug-in link? Link or Link plus?
Scoobyslack1 is offline   Reply With Quote
Old 09-18-2002, 10:18 PM   #21
Marcin
Member#: 2874
2005 CGM WRX WGN
PnP Link Plus
Old 09-18-2002, 10:19 PM   #22
Revision
Member#: 242
MY05 PSM GGA !STOCK
Marcin.. Be like Brian.. Plug in the dinkin Link already...
Old 09-18-2002, 11:10 PM   #23
Marcin
Member#: 2874
2005 CGM WRX WGN
I just need to hookup the EGT gauge to the power and the probe(probe installed today).
Also I need to run that Vac to the Maf sensor.
But all that is useless since I don't have a laptop.
Old 09-18-2002, 11:15 PM   #24
Revision
Member#: 242
MY05 PSM GGA !STOCK
Marcin.. Be like Brian.. Buy his other laptop...
(Don't forget to rice it out with all kinds of stickers and Subaru Blue paint)
Seriously, if you need help. Just ask.. We can blow up your car like some of the best tuners in the country.
Old 09-18-2002, 11:26 PM   #25
Marcin
Member#: 2874
2005 CGM WRX WGN
I knew I could count on you guys.
After next payday, I'll be getting a laptop. I don't have enough spending money at this time.
DAMN! Wanted to work on the car today (bees v2.0) Texas25RS Texas Impreza Club Forum -- TXIC 22 06-06-2005 01:24 PM
I really want to work on my car tonight but don;t know what to do. suggestions? Eric SS Off-Topic 25 11-30-2002 02:52 AM
Worked on my Wagon today Family Truckster New England Impreza Club Forum -- NESIC 2 06-30-2002 12:56 AM
Worked on my car today 20mm Hawaii Impreza Club Forum -- HIIC 4 04-03-2002 02:51 PM
Did some work on my WRX today... NiceguyOnSubySt Hawaii Impreza Club Forum -- HIIC 13 01-17-2002 11:44 PM
