Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 01-23-2013, 11:33 PM   #1
bman59
Member#: 344529
2012 Impreza Sport
Grey
Default Plasti Dip on Taillights?
Ok im new to this site so don't hate my question.
How do people on here feel about plastidip on taillights? and has anyone done it before? pictures would be cool too
bman59 is offline   Reply With Quote
Old 01-23-2013, 11:37 PM   #2
ABeastinWRX
Member#: 239469
2004 WRX
Wont this totally cover them? Those tail light paints are designed to let light through.
ABeastinWRX is offline   Reply With Quote
Old 01-23-2013, 11:41 PM   #3
bman59
Member#: 344529
2012 Impreza Sport
Grey
Im not sure, I have just heard of people using it on taillights and I was wondering if it is any good
Old 01-23-2013, 11:44 PM   #4
Pengu
Member#: 341101
2005 STI
World Rally Blue
It would fully cover the tail lights, unless I'm missing something?
Pengu is offline   Reply With Quote
Old 01-23-2013, 11:52 PM   #5
Killerspeed56
Member#: 217073
1997 Impreza Coupe
black
Dont think it would work because the heat of the lamps would probably make the dip peel off. Just a thought. Dunno tho
Killerspeed56 is offline   Reply With Quote
Old 01-23-2013, 11:54 PM   #6
ABeastinWRX
Member#: 239469
2004 WRX
I mean I dont know entirely either but I feel it will cover it and not emit any light through.
Old 01-23-2013, 11:59 PM   #7
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
Yes, if you use any colored spray. If you spray it thin, you will get this nasty rattle can spotty effect, which isn't cool at all. It'll look cheap and rice tastic.
If you use clear plasti-dip matte finish, then it'll just look glazed over and matte finished. If you use glossy, then it'll be clear glossy.
No. Even though plasti dip is flammable, it can withstand heat from exhaust tips, until it is ignited with a live fire.
There's a fking plasti dip thread, why don't you post questions in there?
pho_shizzle is offline   Reply With Quote
Old 01-24-2013, 12:06 AM   #8
jackassofalltrades
Member#: 309550
WGMF 15' Mazda Mz3
02 WRX wagon - Mr. White
If your using regular bulbs for brakes and turn signals, then killerspeed56 is right.
If your taillights are LED's, they will not emit such heat that will in any shape way of form remove the plasti-dip.
I'm not saying that would I recommend doing this however. It is unsafe, mainly for you and the already dumb drivers that are behind you.
They make a certain paint for this that is cheaper in some stores than plasti-dip.
Why not use that? Yes, the paint for tinting taillights is less forgiving, but that is what it was made for.
OR
Instead of messing up your taillights with accidental messes. Try lens covers. Lamin-x is a great vendor for such.
Good Luck.
jackassofalltrades is online now   Reply With Quote
Old 01-24-2013, 12:09 AM   #9
Splatum420
Member#: 264261
2013 STI
Try it out and let us know how it looks. If you don't like it, peel it off. Dipyourcar.com has spray specifically for tinting. Good luck!
Splatum420 is offline   Reply With Quote
Old 01-24-2013, 12:11 AM   #10
Splatum420
Member#: 264261
2013 STI
And it won't mess anything up, just did my wheels, wing, and a few other parts. No issues removing it
Old 01-24-2013, 12:32 AM   #11
crick0234
Member#: 319696
2012 Subaru WRX STI
you can take it apart and plastidip the inside? leave the cover clear.
crick0234 is offline   Reply With Quote
Old 01-24-2013, 06:59 AM   #12
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Look up a product called NITESHADES by VHT. This will give you the spray on, tinted look you're thinking of.
Plasti dip sprayed thin enough to allow light to pass will look like crap. Sprayed thick enough to not look like crap will not allow light to pass. It's your ass, by covering the lights you raise your accident risk 10000%
Tail lights DO NOT generate enough heat to affect plasti dip. Those who keep saying it will be an issue, you are wrong.
Old 01-24-2013, 08:40 AM   #13
scooby1326
Member#: 286827
I believe dipyourcar.com tested plastidip up to 375 degrees. Some people have used it on brakes even though I'm very skeptical on that. There is a plastidip smoke which is made to be translucent so you could try that out.
scooby1326 is offline   Reply With Quote
Old 01-24-2013, 08:44 AM   #14
imprezafreak3
Member#: 184136
2013 WRX
PBP
they make a plasti dip "smoked" that i actually have on the reverse lights of my current vehicle(12' Si). looks ok, wouldn't recommend it for the entire light though.
imprezafreak3 is offline   Reply With Quote
Old 01-24-2013, 09:19 AM   #15
livinthelife62
Member#: 325600
I've used plasti dip smoke to tint tail lights and marker lights with success, I also used glossifier so they didn't look matt. I have also used several light coats of black plasti dip with clear and or glossifier and had good results. Peels off of you don't like it, no issues with heat.
You can also argue this is unsafe due to light diminished output, I have put identical cars side by side with lights on, during day lights are visible, but harder to see running lights, brakes show up fine, at night, very minimal difference noticed.
livinthelife62 is offline   Reply With Quote
Old 01-24-2013, 09:22 AM   #16
leach0789
Member#: 210903
2013 MS3/Turbo Miata
Nitrous Rhodes
Get lamin-x.
leach0789 is offline   Reply With Quote
Old 01-24-2013, 01:48 PM   #17
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
No plasti dip on lights! There's your answer!
garzdos is offline   Reply With Quote
Old 01-25-2013, 09:20 PM   #18
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Dont forget to plastidip your headlights too like I did.
Old 01-25-2013, 09:58 PM   #19
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Vision I want to punch you in your baby maker.
Old 01-26-2013, 03:16 PM   #20
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Old 01-26-2013, 05:38 PM   #21
08subieobs
Member#: 344909
At my shop we plastidip a lot does awdsome on wheels and lights
08subieobs is offline   Reply With Quote
Old 01-26-2013, 08:14 PM   #22
cjwally
Member#: 300446
2012 WRX Premium
SWP Stg 2+ Cobb Pro Tuned
I plastidipz my windshiledz for maximum vizability.
cjwally is offline   Reply With Quote
Old 01-26-2013, 08:22 PM   #23
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
ChesterWRX is offline   Reply With Quote
Old 01-26-2013, 09:07 PM   #24
bugeyesubi
Member#: 338922
2003 Wrx
Sonic yellow
Only plasti dip your lifts if your gonna peel it off
bugeyesubi is offline   Reply With Quote
Old 01-26-2013, 09:11 PM   #25
Trunx
Member#: 341122
2013 wrx
dgm
I've seen people spray light coats on the taillights but it's hard to take off. Unless you spray thick coats on it, it won't peel off nicely. I agree, the vht nughtshades are your best bet. Theyll allow some light through.
Trunx is offline   Reply With Quote
