Old 01-24-2013, 08:56 AM   #1
06stijoe
Member#: 133412
06 STI
Default Any ideas????
I just built my 2.5 and had the machine work done at a reputable shop in my area. I had the block bored and sleeved. Polished the stock crank. Went with Manley turbo tuff rods, cosworth pistons and ACL race bearing. I also had the heads freshened up with a valve job. I installed the engine and it runs fine except I have a tap on the right bank. It sounds like a mis adjusted valve but I checked the lash and its all in spec. I also ran compression and pressurized the cylinder to make sure I don't have any bent valves. Everything looks good but I still have the tap. Can anyone help me with this please? I plan on trailering it to the machine shop to see what they think within the next few weeks but I figured I'd hit you guys up first to pick your brains. I appreciate any suggestions.
06stijoe is offline   Reply With Quote
Old 01-24-2013, 10:16 AM   #2
wrxadam05
Member#: 84070
2015 Fiesta ST - E30
500whp GRB STI
Right bank... Top of Head, bottom of head? Front of head, back of head?
wrxadam05 is offline   Reply With Quote
Old 01-24-2013, 12:38 PM   #3
06stijoe
Member#: 133412
06 STI
It sounds loudest on the valve covers. Does anyone know the valve lash specs? I've seen several tolerances and I'm not sure which ones to go by.
Old 01-24-2013, 02:01 PM   #4
wrxadam05
Member#: 84070
500whp GRB STI
.008i / .010e
Old 01-24-2013, 07:13 PM   #5
Serkan
Member#: 180514
2004 Sti
Did you check the lash after you bolted the heads on the shortblock or before ?
Serkan is offline   Reply With Quote
Old 01-24-2013, 09:08 PM   #6
06stijoe
Member#: 133412
06 STI
I checked it after I started the engine and heard the rattle. I'm thinking they're too far out of spec now that I got the tolerances. I have an exhaust valve that's .014. Is that enough to rattle?
Old 01-24-2013, 09:48 PM   #7
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
What cams in it?
Old 01-24-2013, 10:17 PM   #8
06stijoe
Member#: 133412
06 STI
Heads and cams are stock. Just had a valve job done.
Old 01-24-2013, 11:09 PM   #9
Subikid90
Member#: 239233
1998 LGT
Yes that will do it
Subikid90 is offline   Reply With Quote
Old 01-24-2013, 11:14 PM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
OE 257/255 lash specs
.0079" +- .0008"
.0138" +- .0008"
FuJi K is offline   Reply With Quote
Old 01-24-2013, 11:32 PM   #11
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
Also depends on if you used assembly lube or oil. If you used oil, clearance will be tighter. I allow +/-.002 either way.
14 thou is definitely to much clearance.
Flat 4 Motorsport is offline   Reply With Quote
Old 01-25-2013, 09:15 AM   #12
06stijoe
Member#: 133412
06 STI
So why do some say .008i .010e and others say .008i .014e which equals the .20mmI and .35mmE?
Old 01-25-2013, 09:20 AM   #13
wrxadam05
Member#: 84070
500whp GRB STI
I always build with the specs I gave you, and my motors are always quiet. On my car with GSC S2's I assembled with same numbers and was still silky smooth.
Old 01-25-2013, 05:11 PM   #14
Serkan
Member#: 180514
2004 Sti
Edit : nevermind
Old 01-25-2013, 06:39 PM   #15
wrx1392
Member#: 342331
2003 wrx
blue
forged pistons will make a bit of noise too.
wrx1392 is offline   Reply With Quote
