Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Old 01-24-2013, 10:54 AM   #1
42Autosports
Vendor Sales Rating: (6)
Member#: 257297
2002 H6
Default OE Quality Replacement Wheel Bearing and Ball Joint Kits! Coated Option Available!
Subaru OEM Wheel bearing replacement kits
Wheel bearings on Subaru's need replacing from time to time and when compared to dealer pricing, this OE quality replacement kit can save you $$$.
We have been using these bearings and seals in all of our subarus since 2005, they work great and they are priced even better. Bearings come pre-packed but we recommend repacking with the provided grease.
To order please visit our website here: www.42Autosports.com or click the provided links below for each kit.
Once your payment is received your order will ship within 1-2 business days.
93-07 Impreza 2.5 + WRX Front, 04 STi Front: $85 Shipped
Koyo Wheel Bearing
OE Wheel Seals x2
Axle Nut
One 100gram tube of Lubro Moly Long Life Wheel Bearing Grease will be included with every order!
Kit also fits all Legacy 1990-2004, All Baja, and all Forester 1998-2008.
Click HERE to order 93-07 Impreza 2.5 + WRX Front, 04 STi Front bearings!
93-07 Impreza 2.5 + WRX Rear: $95 Shipped
Koyo Wheel Bearing - Tapered Bearing**
OE Wheel Seals x3
Axle Nut
Click HERE to order 93-07 Impreza 2.5 + WRX Rear Bearings!
**The factory bearing is a standard radial ball bearing in the rear. The Koyo is a tapered roller bearing which is MUCH more resistant to wear when exposed to increased lateral loads that most of us subject our cars to...
Now offering 4 wheel bearing kit for 93-07 Impreza + WRX at a bargain price!
Includes:
2x Front Kit - Koyo Bearing, OEM Inner Seal, OEM Outer Seal, Axle Nut, High Temp Grease
2x Rear Kit - Koyo Bearing, OEM Inside Inner Seal, OEM Inside Outer Seal, OEM Outside Seal, Axle Nut, High Temp Grease
Fits 1993-2007 Impreza and WRX, 1990-2004 Legacy, All year Baja, and 1998-2008 Forester
Click here to get your low price on all 4 bearings!
04 STi Rear: $100 Shipped
NTN Wheel Bearing
OE Wheel Seal x3
Axle Nut
If you are already doing the bearings...we also offer ball joints at a reasonable price. You guys might get a kick out of these.
Sankei 555 Ball Joints: $32 each when purchased with wheel bearings.
Because someone asked further down in the thread - general installation and torque info:
For the fronts torque axle nut to 162 ft-lb
For the rears torque axle nut to 137 ft-lb
Procedure - Either Front or Rear:
Remove Knuckle From Car
Remove Dust Shield
Press Hub From Knuckle
Pry Out Seals
Remove Retainer Clip - On fronts clip is outside, On rears on inside
Press Bearing Out - On fronts press outwards, On rears inwards
Remove ABS Tone Wheel From Hub (If Equipped)
Press Bearing Race From Hub - Use bearing splitter
Clean Everything
Grease New Bearing With Supplied Grease
Press New Bearing Into Knuckle
Install Retainer Clip
Install Outer Oil Seal
Re-install ABS Tone Wheel (If Equipped)
Press Hub Into Bearing/Knuckle
Install Rear Oil Seal(s)
Re-install Knuckle On Car
Torque New Axle Nut to Proper Spec Listed Above
Stake Axle Nut
If you're doing a lot of bearings on your own cars, or have lots of friends and want to split the costs, it's not too pricey to get a 12 ton press and a few monster 3/4" drive sockets that are the correct diameter for pressing the bearings/hubs. Obviously there are special tools for that purpose, but they are quite expensive. Most of the tools needed can be sourced from Harbor Freight or Northern Tool.
__________________
[/URL]
42Autosports is offline   Reply With Quote
Old 02-07-2013, 05:00 PM   #2
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-10-2013, 08:25 PM   #3
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-13-2013, 12:20 PM   #4
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-16-2013, 01:21 PM   #5
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-16-2013, 03:15 PM   #6
Omegared99
Member Sales Rating: (2)
Member#: 277965
2007 WRX
Grey
PM'd sent
Omegared99 is offline   Reply With Quote
Old 02-19-2013, 10:47 AM   #7
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-21-2013, 05:04 PM   #8
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 02-25-2013, 03:13 PM   #9
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 03-02-2013, 07:46 PM   #10
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 03-13-2013, 01:18 PM   #11
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 03-18-2013, 04:46 PM   #12
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 03-29-2013, 10:11 AM   #13
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 04-05-2013, 12:31 PM   #14
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 04-11-2013, 10:32 AM   #15
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 04-17-2013, 04:52 PM   #16
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 04-23-2013, 07:33 PM   #17
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 04-29-2013, 01:32 AM   #18
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 05-01-2013, 05:07 PM   #19
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 05-06-2013, 02:55 PM   #20
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 05-10-2013, 10:38 AM   #21
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 05-16-2013, 01:40 PM   #22
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 05-21-2013, 05:59 PM   #23
42Autosports
Member#: 257297
2002 H6
Bump!
__________________
[/URL]
Old 05-30-2013, 10:11 AM   #24
42Autosports
Member#: 257297
2002 H6
Don't trust your safety to low quality bearings. We only use the best.
__________________
[/URL]
Old 06-04-2013, 09:27 AM   #25
42Autosports
Member#: 257297
2002 H6
Best parts for the lowest price around, right here.
__________________
[/URL]
