Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-24-2013, 07:29 PM   #1
myblusti
Member#: 337871
2010 5-door STI
blue/gold
Default vehicle speed sensor???
where is this wire located. ive been searching for almost 2 freaking hours and cannot find an ecu pinout to save my life. and please dont show me the dang subaru tech info site unless you can show or tell me ewhat im looking for because ive already paid to join and didnt find what i was looking for. im beyond aggravated at this point. can anyone help???
myblusti is offline   Reply With Quote
Old 01-25-2013, 12:16 AM   #2
blessthekellen
Member#: 273859
MY98
WRX
As posted by SVXdc
Vehicle Speed Signal (VSS) and reverse gear can both be found in the passenger footwell, in locations similar to those shown here:
Forester 2009 / Impreza 2008 wiring for VSS, Rear Gear and +12V Ignition On
Applies to 2008-2013 WRX and STI, 2008-2011 Impreza, and 2009-2013 Forester
In Impreza/WRX/STI, you can see the connector with the VSS wire without needing to remove any trim panels. Factory wire color is PINK/GREEN.
On 2012-2013 Impreza (not WRX or STI), VSS is pin 19 on the factory 20-pin radio harness. Reverse gear is pin 16 on the 16-pin aux harness. Parking brake is pin 15 on the 16-pin aux harness.
It seems that nearly all recent Subarus have the reverse gear wire in similar spots in both footwells (going to the respective rear light clusters), and the factory wire color is always BROWN/YELLOW.
ADDED: When talking about wire colors, the first color is the main or dominant color of the wire. The second color is the stripe(s). So PINK/GREEN is mostly PINK with GREEN stripes. On factory wiring diagrams, that's shown as PG (no slash).
List of Subaru's abbreviations here (first one I could find quickly. Note that it's not safe to assume BLACK is ground, especially if there is also a stripe).
Factory wires often also have dots. Those are usually not mentioned or documented.
blessthekellen is offline   Reply With Quote
Old 01-26-2013, 12:22 AM   #3
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Here's the link to my post that blessthekellen quoted: post (the embedded links there still work)
SVXdc is offline   Reply With Quote
