Old 01-30-2013, 04:25 PM   #26
eg33GC
Member#: 206851
99 V4
EJ20K RS
Originally Posted by i_c_the_light View Post
Would it be safe to assume an N/A 7/8/9 have the same rods as their turbo counterparts?
I am not sure, but I know the USA n/as use the same old weaker rod
eg33GC is offline   Reply With Quote
Old 01-30-2013, 04:25 PM   #27
eg33GC
Member#: 206851
99 V4
EJ20K RS
Originally Posted by Jarrod164 View Post
I have a 550 tune as well and yes it's great. I just have been doing a lot of reading and would like an ej207 I think with a bigger rotated turbo. I want to be pushing 350+ whp. You won't get that out of the G/K I'm sure.
So then I'm now hearing that the ver5/6 has the ej207 so I'm wondering if I should pick one of those up instead of looking for a front clip for the same price heh.
Do some research. The 5 and 6 207 are no stronger at ALL than a g/k. Read the reasons why.
Old 01-30-2013, 06:31 PM   #28
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Do those new rods even fit to a centre thrust crank?
i_c_the_light is offline   Reply With Quote
Old 01-30-2013, 06:51 PM   #29
eg33GC
Member#: 206851
99 V4
EJ20K RS
all 52mm rods fit 52mm cranks with an ej
Old 01-31-2013, 12:22 PM   #30
Jarrod164
Member#: 253937
1995 WRX
I'm finding it tough to gather info on the ver5/6 engines. Doesn't seem like there's a lot of swapping going on with those and we're not importing them yet. Though it'd be a long time after we import before anyone probably works on/tunes them.
Thinking the version 8 ej207 would be best then for my 350whp needs, swapped into my 93 impreza L heh.
Jarrod164 is offline   Reply With Quote
Old 01-31-2013, 12:31 PM   #31
polaks
Member#: 305714
I know what you mean there is very little information about the version 5's and the type r's too....
polaks is offline   Reply With Quote
Old 01-31-2013, 04:07 PM   #32
ShinjiML
Member#: 257231
2002 WRX Stage II
So the v5/6 type ra has forged rods but cast pistons?
ShinjiML is online now   Reply With Quote
Old 01-31-2013, 04:39 PM   #33
simer1228
Member#: 171039
99 RSTi TypeRA LTD
Black Diamond Pearl
other way around, forged pistons & cast rods.
FYI, I know a thing or two about the v5/6 STi's
quoted for truth.
simer1228 is offline   Reply With Quote
Old 02-07-2013, 09:40 AM   #34
Modollenroc
Member#: 243499
If I'm not mistaking the only difference between the v5 and v6 207 is that Subaru issued a clutch upgrade but after you've changed it out then I suppose there's no difference at all. And if I'm not mistaking the lack of lubrication in the crank is why the 20K isn't preferred over the 207 because they are somewhat prone to spinning bearings. The v7/8/9 has AVCS which the 5/6 doesn't. iirc
Modollenroc is offline   Reply With Quote
Old 02-07-2013, 10:45 AM   #35
Jarrod164
Member#: 253937
1995 WRX
AVCS is supposed to be godly haha. And I'm sure tuning for the 7/8/9 is a lot easier because it can be done with a tactrix cable. You can flash the ecu without having to go to an expensive aftermarket.
I think my new goals are to put in an ej20k into my 93 impreza because those engines are damn cheap. Then slap in rob's new tune when it's ready
Old 02-07-2013, 06:31 PM   #36
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
all factory rods are forged..just not pretty..
Old 02-07-2013, 06:59 PM   #37
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
More like the K's got a vastly more aggressive tune hence the bearings getting a pounding.
Old 02-23-2013, 04:26 AM   #38
czaviar
Member#: 260862
1999 type R ver.6
white
Try this, you will only need to run Google translate: http://drischnie.homeip.net/www.suba...eza.de/STi.htm
czaviar is offline   Reply With Quote
Old 04-13-2013, 06:15 AM   #39
WelDun1
Member#: 249130
0095 Ver5 STi Type R
All ver5/6 STi have forged pistons and rods. *EDIT*Ver 5/6/7 ej207's have Forged Pistons, and the Ver 8/9 ej207's have Cast hypereutectic pistons.
I'm in the middle of a ver5 Type-R swap right now. It's the best engine I've ever owned! I like the ver5/6 ej207's, and I'm thinking about putting some Ver9 Heads on my Ver5 Type-R. If you replace the rods and bearings on the ver5/6 207 when you get it, they are bad ass engines.
WelDun1 is offline   Reply With Quote
Old 04-14-2013, 04:47 AM   #40
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Originally Posted by WelDun1
All ver5/6 STi have forged pistons and rods. All ej207 have forged pistons except the ver7, which have the hypereutectic pistons.
I'm in the middle of a ver5 Type-R swap right now. It's the best engine I've ever owned! I like the ver5/6 better than the other ej207, but that's just me. Most will say that it doesn't get better than Ver7, and that's just bcuz of AVCS.
Your information doesn't stack up at all.
Old 04-14-2013, 04:56 AM   #41
WelDun1
Member#: 249130
How do you figure? There so many threads on here plus links to brochures on the forged pistons in the Ver5/6 ej207... So what doesn't stack up?
Old 04-14-2013, 05:28 AM   #42
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
The amount of misinformation that floats around the place makes me not take anything for granted. How long was it that people thought that the EJ22T (which is actually designated EJ22B according to my own research and what was stamped on a set of 2.2 turbo HG I had purchased - if I'm wrong, somebody tell me) had forged pistons and that all GC8 engines had CD blocks.
Old 04-14-2013, 07:36 AM   #43
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
All EJ20K STI engines and all EJ207 engines have forged pistons up to 2005. After that they were hyperteutic cast. The stronger rods came in the 2001 and later EJ207 STI engines.
Marnix is offline   Reply With Quote
Old 04-14-2013, 08:26 AM   #44
Gyver
Member#: 185473
1999 JDM Impreza STI
Coolgrey
Nope, just forged pistons on the v5/6
Nope, the v7 had forged pistons also, the ver8 onwards have hypereutectic pistons. I know because i recently replaced my jdm sti ver5 shortblock to a jdm sti ver8 and did a lot of research.
The version 8 jdm bottom end is the toughest of them all, but the v9 had better heads.
Gyver is offline   Reply With Quote
Old 04-14-2013, 02:52 PM   #45
WelDun1
Member#: 249130
Sweet, thanx for correcting me. I thought they all did except 7 or 8 having the hypereutectic. My point was that the ver5/6 weren't cast.
Old 04-14-2013, 08:22 PM   #46
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I did my own Googling and pictures are enough for me.
Old 04-15-2013, 08:55 PM   #47
NICO TURBINE
Member#: 15445
1986 Leone STi EJ22T
JDM White
NICO TURBINE is online now   Reply With Quote
Old 04-15-2013, 09:05 PM   #48
eg33GC
Member#: 206851
99 V4
EJ20K RS
dude, you cant ask v7 driveline swaps prices for a super high mileage v4...
Old 04-15-2013, 10:51 PM   #49
NICO TURBINE
Member#: 15445
JDM White
Dude learn in what your getting first ! Your getting a complet car not bits and piece from a Jdm supplier !
Do you even know what it takes to get every single piece of wire
From a Jdm supplier ? With everything like the dash and hubs Knuckles let alone the rare 5mt and that diff and the rare rear hubs not mutalated ?
No you don't but I do because I buy these things every day !
Your v7 comes with motor tranny diff and what options like brakes for 7k + !! Your v7 has been raped out the car and sitting for 2months in a box from people that no nothing about cars taken apart with saw !!
Come talk to me when you do your home work ! I live in the heaven of the Jdm suppliers..
Do your home work
Old 04-16-2013, 03:29 PM   #50
AgentJ17
Member#: 306411
1995 STi RA
Yeah, I mean anyone who chops the axles instead of simply popping out the roll pin and undoing the axle nut to remove them, snips wiring instead simply undoing it at the connector, and slashes lines/hoses instead of properly undoing them is so stupid on so many levels. They're not saving themselves any money by taking these "shortcuts", they're just needlessly devaluing their own products.
But unfortunately, that's what you're buying from these suppliers.
AgentJ17 is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 07:04 PM.
