Old 01-25-2013, 05:59 PM   #1
mckinnon99879
Member#: 314199
2013 WRX
ISM
Default Can we ebrake?
I havent gotten a straight answer, will it **** the differentials or not? The snow finally got us here in NJ. The salesman said i can but that doesn't mean i actually can. 2012 impreza sport
mckinnon99879 is offline   Reply With Quote
Old 01-25-2013, 08:50 PM   #2
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
The VC in the manual won't like it.
For the CVT, it depends on what the computer does when you pull the handbrake.
Commander Keen is offline   Reply With Quote
Old 01-25-2013, 11:18 PM   #3
EnforcerPSU
Member#: 76849
2011 WRX
Rally Blue
Yes. You can use the ebrake. It's not going to tear anything apart. Just don't make a habit out of it.
EnforcerPSU is offline   Reply With Quote
Old 01-26-2013, 10:55 AM   #4
09subi2.5i
Member#: 331636
09 impreza
paprika
you dont need a handbrake to drift awd in the snow. and if standard trans then dont.
09subi2.5i is offline   Reply With Quote
Old 01-27-2013, 01:55 AM   #5
subaru604
Member#: 219225
2013 Impreza
Dark Grey Metallic
What you mean standard trans?
Also, how do you drift awd in the snow without handbrake? hehehehe....
subaru604 is offline   Reply With Quote
Old 01-27-2013, 02:00 AM   #6
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
I've heard its worse on the auto than the standard trans. Would it actually damage the standard if you didn't overuse it? From what I've been made understand from Subaru techs using the e-brake can increase wear long term but won't directly cause any damage.
Dirt Bringer is offline   Reply With Quote
Old 01-27-2013, 09:14 AM   #7
Zeeper
Member#: 299286
2015 WRX CVT
If you are looking for "go ahead, doing donuts and e-braking (no matter the trans) is totally fine" you hopefully won't get that answer here.
I did a couple of rounds in a local lot one night. It was fun. I wouldn't do that regularly, because it is abusing a car I plan on keeping.
You can abuse your car, but don't expect that to come with no mechanical wear and tear on the differentials or brakes.
If it is only abused occasionally, it is still abuse, but probably won't result in a problem for you.
If are like the other guy on the thread who wants a TSB because his e-brake clunks when he pulls it while in motion, that ain't gonna happen either. The solution to eliminating that clunk is to stop pulling the ebrake while in motion.
Zeeper is online now   Reply With Quote
Old 01-27-2013, 12:24 PM   #8
ans2k
Member#: 315631
2012 Impreza Sport
If it is only abused occasionally, it is still abuse, but probably won't result in a problem for you. However it is still adding wear and tear to the mechanical parts.
this guy gets some up points!
ans2k is offline   Reply With Quote
Old 01-27-2013, 12:47 PM   #9
Dirt Bringer
Member#: 340297
Ice Silver
Not to mention pulling the e-brake on anything other than dirt, grass or snow can put some pretty massive stress on wheel bearings. In fact I can't think of any reason you would ever pull it on anything other than those types of terrain, and even then just to provoke a tailslide...which can be done (at higher speeds) with throttle and steering... Its fun to spin the car 180 degrees. It doesn't really accomplish much though ultimately.
Old 01-28-2013, 02:14 PM   #10
pauli133
Member#: 233261
2005 Outback XT
with two hands and your right foot.
pauli133 is offline   Reply With Quote
Old 01-28-2013, 02:31 PM   #11
soobie doo
Member#: 324017
2012 Impreza 2.0i
Ice Silver Metallic
-Turn of traction control.
-Make sure you're not near any curbs or other things you don't want to hit, especially if you aren't sure exactly how the car will respond.
-Go around a turn with lots of gas.
In the 5 speed, you can hang the tail out pretty far on loose surfaces. I dunno about the CVT.
soobie doo is offline   Reply With Quote
