Old 01-25-2013, 07:10 PM   #1
gabelikefaria
Member#: 316383
2005 impreza wrx sti
aspen white
Default Cobb accessport question
Hey guys I just ordered an accessport and I'm aware that Cobb has stage 2 maps but my car is a little more than stage 2. Any where to download custom maps or just recommend taking it to a tuner? Thanks if anybody can guide me
gabelikefaria is offline   Reply With Quote
Old 01-25-2013, 07:11 PM   #2
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Mods list would help...
RoadKillDMD is offline   Reply With Quote
Old 01-25-2013, 07:20 PM   #3
imprezafreak3
Member#: 184136
2013 WRX
PBP
If you're past stage 2 I hope you have a tune on your car already. And no there's nothing custom for maps on the AP, they come with OTS(off the shelf) maps and are made for really only stock cars to be flashed to stage one or a turbo back and flash to stage 2. If you're "past" that, than I would highly recommend taking your car to get a pro tune. Hope this helps.
imprezafreak3 is offline   Reply With Quote
Old 01-25-2013, 07:52 PM   #4
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Pro tune or E-tune are your only options past stage 2.
JSchell1309 is offline   Reply With Quote
Old 01-25-2013, 08:02 PM   #5
Blusubman
Member#: 304059
06 WRX
World Rally Blue
Pro tune if your ballin. Jk jk but really too piggy back you should have a tune all ready if you have more then a stage 2. Ie bigger turbo bigger injectors ext. And I pray your not running anything I said without a tune.
Blusubman is offline   Reply With Quote
Old 01-25-2013, 09:06 PM   #6
LUMBERZACK
Member#: 340009
2007 STi
48W
Yea man, you should probably just fork out some cash and get it tuned professionally, even the Cobb maps aren't the greatest because every car takes mods differently. The maps are basic maps to get you by for the time being until you get a protune. So one guy might get 269whp off of a Cobb (OTS) map and another guy might get 280whp off the same map with same mods. The best way to take full advantage of your mods is to get a protune as everyone else has recommended.
LUMBERZACK is offline   Reply With Quote
Old 01-26-2013, 02:15 PM   #7
gabelikefaria
Member#: 316383
aspen white
I have stage 2 cams port and polished heads spt intake turbo back exhaust Walbro 255 stage 2 clutch. Lightweight flywheel and those are the major components I believe. On 20lbs right now
Old 01-26-2013, 02:24 PM   #8
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
So how are you currently tuned? What do you expect to gain with the AP?
Old 01-26-2013, 02:46 PM   #9
gabelikefaria
Member#: 316383
aspen white
It was tuned at 18 lbs open source before the clutch flywheel and fuel pump and it put down 320whp
Old 01-26-2013, 02:47 PM   #10
gabelikefaria
Member#: 316383
aspen white
Well I'm asking what do you think the ap will make a difference?
Old 01-26-2013, 03:29 PM   #11
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
You didn't exactly research before you buy did you?
With the mods you listed, you will need someone to do a protune on the vehicle and load it to the AP. AKA you wasted money if you were already tuned.
Old 01-26-2013, 03:29 PM   #12
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
No, the AP provides an easy User Interface to switch maps along with a few other perks (logs, CEL reading, etc.)
But where you have and need a pro-tune for the mods on your car... probably not really worth it unless you want the code reading stuff.
Glad to hear you did your research first before buying. Well done!
Loyale93 is offline   Reply With Quote
Old 01-26-2013, 03:54 PM   #13
Member#: 51961
2005 STi
2012 WRX
All of which can be done with open source as well, which he's already running. The fact is he just spent $600, and still needs to spend another ~$400, to end up in the exact same place he's already in.
Sarcasm?
Old 01-26-2013, 04:21 PM   #14
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
Never said Open Source didn't. Just making sure he understood what he was getting.
Sarcasm?
Ooooohhhh... what's sarcasm?
Yes, sarcasm.
Old 01-26-2013, 04:52 PM   #15
gabelikefaria
Member#: 316383
aspen white
I got the ap for 300 I mean the car was already open source tuned what's the difference between that and pro tuned? I got a guy that could probably run me a tune for a good price. But wouldn't stage 2 map help? Or make a difference ?
Old 01-26-2013, 05:00 PM   #16
JSchell1309
Member#: 321321
Tuxedo Black
Wtf, have you read any of the replies here? Cobb OTS Stage 2 tune is a DOWNGRADE from your open source tune. Your vehicle is already tuned for all your parts, why in the hell do you want to remove that and put on a generic tune that will damage your vehicle with its current parts?!
I don't think you fully comprehend what the AP does or how your car is tuned. I would do a ton if research before you severely damage your vehicle.
Old 01-26-2013, 05:00 PM   #17
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
I think the above...
Answers this question. You definitely have more than what the Cobb OTS Stage 2 map allows for. so the OTS maps aren't going to do anything for you.
Did you read up on the AP before buying? I mean really, these are all fairly simple things that you could have saved $300 on.
Old 01-26-2013, 05:23 PM   #18
pauli133
Member#: 233261
2005 Outback XT
You need to talk to your tuner.
pauli133 is offline   Reply With Quote
Old 01-26-2013, 05:24 PM   #19
gabelikefaria
Member#: 316383
aspen white
Ok I'll
Go to tuner when I receive it and have him tune it for me no big deal. Thanks guys
Old 01-26-2013, 05:25 PM   #20
gabelikefaria
Member#: 316383
aspen white
I mean the car isn't running 100% since I first got it I'm the third owner. I feel like it needs a re tune
Old 01-26-2013, 06:44 PM   #21
Member#: 51961
2005 STi
2012 WRX
Yes, sarcasm.
Just making sure, it can be hard to pick up through text sometimes...
Old 01-26-2013, 06:45 PM   #22
Member#: 51961
2005 STi
2012 WRX
OP - read this:
http://forums.nasioc.com/forums/show....php?t=2339845
You need a custom tune. Whether that custom tune is done through opensource or AP makes absolutely no difference. What you SHOULD have done, is find a tuner you respect and trust, and see whether or not they tune OS vs AP. If they only do AP, THEN you buy one, not before.
Old 01-26-2013, 08:25 PM   #23
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
Clarification? Do you know the mods 100%? Are you sure it's tuned at all? What makes you think it's not running right?
I have a feeling you should be saving money right now instead of wasting it on an AP.
