Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 01-25-2013, 07:25 PM   #1
chris07sti
Member#: 177312
2005 STI
Aspen white
Default Help identify hose
I was looking over my engine bay and found that this hose looks to be cracked in many places. I assume it needs replaced and is not just an outer layer. What part number is this or what is it called? thanks!
chris07sti is offline   Reply With Quote
Old 01-25-2013, 07:44 PM   #2
xsv141
Member#: 231904
2007 WRX
UGM
looks to be a fuel line....correct me if im wrong but im pretty sure that is it
xsv141 is offline   Reply With Quote
Old 01-25-2013, 07:45 PM   #3
ringe
Member#: 49998
2007 WRX CT Stg 2
If it's the same hose in the 2nd pic with the fuel rail dampeners, that's a fuel line. Definitely replace it, ASAP, along with the others if they're suspect.
ringe is offline   Reply With Quote
Old 01-25-2013, 09:22 PM   #4
chris07sti
Member#: 177312
2005 STI
Aspen white
yes its the same hose in the second pic. wow, ok ill get that fixed this weekend. What part should I ask for at the auto store ? or part number from Subaru? is there a diagram of all the fuel hoses so I can check them all? thanks for the info.
Old 01-25-2013, 09:39 PM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Goto Subaru and have them pull up the diagram. Or take the hose off, find fuel grade hose of the same INSIDE diameter, and use that.
FYI, you need to depressurize the system to even begin to get that hose off.
Old 01-25-2013, 09:56 PM   #6
chris07sti
Member#: 177312
2005 STI
Aspen white
alright thanks. I have the APS Inlet and went on their website to see if I can get a replacement line. But if any fuel line will work, ill try the local store. to depressurize, I can just open gas cap and let the car sit overnight, correct?
Old 01-25-2013, 10:24 PM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
A turbo inlet has nothing to do with a fuel line.
Instructions on how to do it are floating around here somewhere.
Old 01-25-2013, 10:32 PM   #8
ringe
Member#: 49998
2007 WRX CT Stg 2
Incorrect. Just pull the fuse for the fuel pump, or access the top of the pump via the rear seat and unplug it (I can't recall if the pump has a dedicated fuse or if it shares it with something else...); start the engine; after it stalls, continue cranking for a few seconds until it has clearly given up on the idea of starting. After that any fuel in the lines will be depressurized.
Old 01-26-2013, 12:00 AM   #9
chris07sti
Member#: 177312
2005 STI
Aspen white
Actually, the FPR is relocated with the APS inlet and they give you new hoses. I looked up the install directions and diagram online.
http://www.airpowersystems.com/wrx/intake/install.htm
Ok thanks, I followed a how to on here about installing injectors and it said remove fuel cap and sit overnight to relieve pressure. I will do what you recommend. thanks
Old 01-26-2013, 12:32 PM   #10
ringe
Member#: 49998
2007 WRX CT Stg 2
If that works for others, you should give it a shot. The worst that would happen is a short burst of fuel at about ~40psi. Just hold a rag over the line when you remove it, and wear eye protection.
Old 01-26-2013, 02:16 PM   #11
chris07sti
Member#: 177312
2005 STI
Aspen white
It might, but didnt want to risk it, just unplugged the green connector at passenger kick panel and tried to start it a couple times. Only a little fuel in the line, and not under pressure. Picked up replacement hose at autozone with same diameter and pressure rating for 4.00/ft.
Old 01-27-2013, 07:22 AM   #12
badxmpl
Member#: 19944
06 WRX wagon
gray
i agree
badxmpl is offline   Reply With Quote
