Old 01-26-2013, 12:20 AM   #1
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Default Supertech buckets
Anyone using the supertech buckets? I'm curious, but apprehensive about the button to shim.
Old 01-26-2013, 02:32 PM   #2
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
I know Joe over at asf likes to use them when he does older jdm stuff like v3/4 heads but I have no personal experiance with them.
spackyscooby is offline   Reply With Quote
Old 01-26-2013, 05:09 PM   #3
mekilljoydammit
Member#: 258151
Part of me has to wonder about using large diameter buckets with custom cams but no experience whatsoever.
mekilljoydammit is offline   Reply With Quote
Old 01-26-2013, 05:40 PM   #4
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
The EZ30R uses that style of shim / bucket combination as well on the intake valves (I don't recall if they use them on the exhaust valves or not). They use them on the intake valves because of the AVLS system and the hydraulic bucket required to make the system work.
I don't have any experience with the supertech bucket setup, but I have never heard anything bad about it.
wrx_driver_2002 is offline   Reply With Quote
Old 01-29-2013, 10:58 AM   #5
calebtharrell
Member#: 242113
2004 STi, 2008 STi
I am using them on my build. MAPerformance built the heads, so for any technical questions, I am sure one of those guys would be able to answer. I only have 800 miles so far, but no problems out of them yet!
calebtharrell is offline   Reply With Quote
