Old 01-26-2013, 01:26 AM   #1
stsdude2
Member#: 307161
2008 wrx
Default Po132? 08 wrx
I got this code. Checked it in my Cobb and tried to clear it, it came right back. For a little bit the car was acting strange when not under boost in first gear, it hesitated a bit I'm not too sure how to describe it, it was almost like a misfire but not as bad, then it stopped doing that but was pouring exhaust out. Is my front o2 sensor most likely bad? I have a fairly built car, pretty much everything is brand new, I am not sure if the shop replaced my o2 sensors during the build though, which would mean they had 50-100k miles on them depending on whether the previous owner had then replaced at any point.
stsdude2 is offline   Reply With Quote
Old 01-26-2013, 02:40 AM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
It could be a vac leak, It could be a bad injector, It could be an exhaust leak, it could be a fuel pressure problem. You better check it out before you buy a 02 sensor.
Old 01-26-2013, 03:33 AM   #3
stsdude2
Member#: 307161
2008 wrx
Don't think it's a vac leak, boost gauge read Norm vacuum, still hit target boost, felt pretty much just as fast
