Welcome to the North American Subaru Impreza Owners Club Friday September 19, 2014
Old 01-26-2013, 11:38 AM   #1
fantasticfour
Member#: 215453
2000 2.0RSTi
Default Fue smell inside cabin
I'm getting a raw fuel smell inside the car but only when the windows are down or when the sunroof is open. Which leads me to believe it's coming from the engine bay and not the fuel lines inside the car.
I pop the hood and can't see or smell anything by the fuel lines, fuel filter, or injectors. Is there any safe way to find a fuel leak? BTW this started after I swapped the motor so I checked everything that was disturbed during the swap, and replaced every fuel hose while the motor was out. Any ideas? Thanks in advance.
fantasticfour is offline   Reply With Quote
Old 01-26-2013, 02:36 PM   #2
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Are you catless?
i_c_the_light is offline   Reply With Quote
Old 01-26-2013, 05:36 PM   #3
fantasticfour
Member#: 215453
2000 2.0RSTi
Nope , full cats. The smell is raw fuel though, not exhaust so im not sure the cats would make a difference or not.
Old 01-26-2013, 05:37 PM   #4
salvi
Member#: 188132
Have you replaced the fuel lines under the intake manifold? The early subarus had that issue. It usually leaks right under the passenger intake runners.
salvi is online now   Reply With Quote
Old 01-27-2013, 05:32 AM   #5
fantasticfour
Member#: 215453
2000 2.0RSTi
Yup, every hose and seal on the engine was replaced.
Old 01-28-2013, 01:11 AM   #6
salvi
Member#: 188132
The hard and soft fuel lines under the intake manifold?
Old 01-28-2013, 02:39 AM   #7
fantasticfour
Member#: 215453
2000 2.0RSTi
Just the reinforced rubber hoses. All the hardlines were reused.
Any tips on "safely" finding a fuel leak, other than smelling for it?
Old 01-28-2013, 03:21 AM   #8
salvi
Member#: 188132
I would have replaced the hard lines too. The hard lines could have a small enough crack where fuel could leak. You should be able to see/smell the fuel by just having the fuel pump purge.
Old 02-09-2013, 07:54 AM   #9
CRX7
Member#: 31639
99 Impreza
Do you still have your vacuum canister assembly hooked up?
CRX7 is offline   Reply With Quote
Old 02-10-2013, 04:23 AM   #10
fantasticfour
Member#: 215453
2000 2.0RSTi
The canister is physically connected to the fuel tank, but none of the solenoids and valves are hooked up to anything. Would that be the problem? Where should I plug up the lines? I didn't think the canister would vent into the atmosphere if none of the solenoids were powered.
Old 02-22-2013, 11:41 PM   #11
dollar5th
Member#: 324540
Whats the car?
dollar5th is offline   Reply With Quote
Old 02-23-2013, 06:28 AM   #12
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
wash your engine bay with cleaner, if you're leaking fuel somewhere.... at least you won't have to worry about having your car go up in flames till you figure it out.
if you are REALLY smelling fuel, and not buring oil... then you have bookoo problems.
find the leak.
DHRDAN is offline   Reply With Quote
