Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 01-26-2013, 07:15 PM   #1
freezingcoffee
Member#: 209894
2005 STi
Default Does anyone have a crank pulley tool I can borrow/rent?
I need to get my crank pulley off to investigate a weird sound coming from my timing belt area....
freezingcoffee is offline   Reply With Quote
Old 01-26-2013, 07:22 PM   #2
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Try putting the car in gear, putting the parking brake on, and having someone stand on the brake while you use a breaker bar and pipe extension (if necessary) to break it loose. It's worked for me every time except one, and I won't tell you what I did that one time because it was moronic.
Good luck.
tibug is offline   Reply With Quote
Old 01-26-2013, 07:27 PM   #3
freezingcoffee
Member#: 209894
2005 STi
I probably need someone on the brakes then... last time I removed the crank pulley the engine was out of my car at my parents house in Virginia and my dad just used his heavy duty Snap-on impact gun. He also tightened it with the same impact gun....
Old 01-26-2013, 07:37 PM   #4
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Oh ouch that might be a bit over-torqued then lol. No biggie.
I don't usually have someone to help me, so what I did is I took a piece of wood and jammed it tight between my driver's seat and the brake pedal. Just cushion the piece of wood on the seat side so it doesn't damage your leather/cloth. Last time I actually used the case for my torque wrench to do the same thing.
You COULD use the starter bump method. This involves you using a breaker bar with a long pipe extension. You put the socket on the bolt, slide the pipe extension over the breaker bar, and lay the pipe extension on the ground on the DRIVER'S side. Go ahead and crank the car once very quickly. You should only have the key in the "start" position for like 1/10 of a second (just one quick crank), then turn it back off. Don't start the car. Go around and see if the bolt has loosened.
Old 01-26-2013, 07:45 PM   #5
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Old 01-26-2013, 07:49 PM   #6
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
Where are you? I have a 950 foot pound impact gun that I can direct run from my garage compressor. Maybe break it loose, then tighten it to more human torque.
Old 01-26-2013, 07:54 PM   #7
freezingcoffee
Member#: 209894
2005 STi
Billerica, MA. I also managed to snap the inlet of my radiator in the process.... The car is in my garage here if anyone wants to help..
Old 01-26-2013, 09:22 PM   #8
freezingcoffee
Member#: 209894
2005 STi
w00t, I got it off! I had a 18" breaker bar, but that wasn't enough. I was looking around for a pipe for leverage and saw my snow shovel, I took off the handle of the snow shovel and used the pipe of the shovel.
So 6th gear + e-brake all the way up + long ass pipe = crank pulley bolt off.
Old 01-26-2013, 09:53 PM   #9
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
Old 01-27-2013, 05:10 PM   #10
Down_Shift
Member#: 115457
66 Grown up subaru
AW on red
Advance auto or autozone. Free rental..
Down_Shift is offline   Reply With Quote
