Old 01-26-2013, 11:13 PM   #1
m1r4g3
Member Sales Rating: (2)
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
Default Perrin Air Oil Seperator Install/Review
I have been fortunate enough to acquire a new Perrin Air Oil Seperator. Install was a breeze. This install is for a 2006 STi. Keep in mind that this is how i have routed and there are different ways to do it based on taste. I also installed it when i swapped tgv's so it was a bit easier to reach some things.
Here it is
First thing you do is assemble it according to the above diagram. the only difference is that I swapped the crankcase vent and the right valve cover vent. One thing to note is that the two coolant fittings are the ones that are closest together.
If you need to adjust the location of the fittings, there is a allen bolt on the bottom. just loosen it and rotate the lower assembly.
Next, find a mounting solution that is right for you. I picked the passenger strut tower. If you have a fmic, the pitch stop bolt is a good spot too.
Remove the intercooler and metal pipes. This gives you all the room you need to route the lines and reach the crankcase vent.Now you remove the current crankcase vent hose and leave the small 2 inch hose at the port. Assemble and attatch the crankcase fitting and oil return fitting to this hose. Be sure to have the oil return fitting turned in the direction of the picture.
Measure and cut appropiate lengths of hose and route them how you want.
Follow one of the hoses(one of the hoses that came off of the metal tubes that were attatched to your intercooler) to the valve cover. Remove and replace with appropiate length hose that will reach your aos.
Passenger Side
Drivers side, i have found that ziptieing the line to the firewall was the best way to route it.
m1r4g3 is offline   Reply With Quote
Old 01-26-2013, 11:14 PM   #2
m1r4g3
Member#: 220476
WRB & SWP
Remove the throttle body and locate the pcv hose. Remove it and install enough hose to reach the intake. Install the one way valve that connects the pcv hose to the aos outlet hose. (mine doesnt have it because it is in the mail)
Reinstall throttle body.
On the throttle body is two coolant lines (in/out) It doesnt matter which one but unhook one, connect the straight connection and run it to one of the coolant fittings.
Run a hose from the other coolant fitting to the nipple where you unhooked the oem coolant line. Now everything is installed.
Reinstall intercooler and enjoy.
REVIEW:
Awesome quality that is expected of Perrin. There isnt a set price so stay tuned Install wasn't difficult. I would suggest a turbo heat shield with this because where I mounted it, would get really hot/maybe melt some hose. I will be back in a month or so to see if it actually worked. i have installed everything new after the turbo so i will be able to see any oil resudue.
Old 01-27-2013, 02:09 AM   #3
murrdogg24
Member Sales Rating: (44)
Member#: 50586
04 WRX
Flappy bird edition
are you sponsored by Perrrin???
murrdogg24 is online now   Reply With Quote
Old 01-27-2013, 03:48 AM   #4
m1r4g3
Member#: 220476
WRB & SWP
Nope, i know a guy named Jeff.turns out he is really nice
Old 01-28-2013, 12:35 PM   #5
knoxville1
Member#: 248436
2000 2.5RS V7 STI
Sedona red pearl
somebody loves perrin :/
knoxville1 is offline   Reply With Quote
Old 01-28-2013, 04:11 PM   #6
kh15
Member Sales Rating: (25)
Member#: 132400
looks great! Can't wait for some real world reviews buy actual customers (not saying your review doesn't count!) perrin +1
kh15 is offline   Reply With Quote
Old 01-28-2013, 07:35 PM   #7
m1r4g3
Member#: 220476
WRB & SWP
^^^^ even though it doesn't look it, i am not biased and will be the first one to let people know if something is wrong with it
also I plan on running the 1/4 mile a couple of times and hopefully do a local auto x
Old 01-29-2013, 11:03 AM   #8
traction
Member Sales Rating: (14)
Member#: 32016
2010 CRV EX-L
Polished Metal
How much fall does the drain return line have? it looks like it sits way low.
traction is offline   Reply With Quote
Old 01-29-2013, 12:34 PM   #9
m1r4g3
Member#: 220476
WRB & SWP
We will see how much of an affect it has on drain. If it just pools in the line i will shift stiff around
Old 02-11-2013, 11:51 AM   #10
fizzyl
Member Sales Rating: (8)
Member#: 103490
06 STi
Any updates? I'm very ready to buy this thing.
fizzyl is offline   Reply With Quote
Old 02-17-2013, 06:24 PM   #11
m1r4g3
Member#: 220476
WRB & SWP
small update, i revieved the valve for the pcv hose. here is how it installs. green is the valve and yellow is the y fitting.
and no oil in the inlet return hose
the only downside is that i wish the pieces were a neater install.
Old 02-18-2013, 07:06 PM   #12
StackSmasher
Member Sales Rating: (4)
Member#: 316928
2012 STI limited
awesome. I would say I cannot wait for this to come out but I doubt it is soon. they cant seem to even stock their shelves currently. been waiting over a month for a reverse lockout lever.
StackSmasher is offline   Reply With Quote
Old 03-21-2013, 05:21 AM   #13
t6nis1234
Member#: 316906
2001 Impreza WRX 2.0
Any updates with in last month?
t6nis1234 is offline   Reply With Quote
Old 05-03-2013, 10:27 AM   #14
henria86
Member Sales Rating: (1)
Member#: 303849
2004 Forester Xt
Silver stg2
Bump Any Word??
henria86 is offline   Reply With Quote
Old 05-03-2013, 06:14 PM   #15
PERRIN_Chris
Vendor Sales Rating: (0)
Member#: 186665
2014 BRZ
The air oil separator is ready for sale! They're not on our website yet, but you can order them over the phone. MSRP is $469.99.
PERRIN_Chris is offline   Reply With Quote
Old 05-03-2013, 09:10 PM   #16
Purdue22
Member Sales Rating: (3)
Member#: 348413
Are you going to have an initial group buy?
Purdue22 is offline   Reply With Quote
Old 05-04-2013, 10:47 AM   #17
StackSmasher
Member#: 316928
2012 STI limited
Ouch.. gonna have to see this thing in action before I drop that kind of cash. On another note. Almost everything on my car is perrin. You guys should just give me one to review :P
Old 05-06-2013, 11:10 AM   #18
PERRIN_Chris
Member#: 186665
2014 BRZ
We probably aren't going to have a group buy on it, but if you give us a call to order it, we can give a discount for NASIOC members!
Old 05-06-2013, 11:25 AM   #19
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
Was the level of the drain outlet taken into account compared to reviews of the crawford aos when this was in development? I think this is key for TMIC equipped cars.
kenliu84 is offline   Reply With Quote
Old 05-06-2013, 07:45 PM   #20
PERRIN_Chris
Member#: 186665
2014 BRZ
Yes it was, it will have to be mounted above the crankcase vent, and not have any kinks in the lines to allow oil to be drained back into the engine. There's plenty of room in the engine compartment on the pass side even with the TMIC installed to mount this part.
Old 05-07-2013, 08:44 PM   #21
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
Ok so where to start, Its an AWESOME product.
First, would suggest the "pitch stop" mounting location.
Second, the genneral routing to the lines is good. I like the method not involving "Ting" the vents together.
Third, it's made by Perrin . . . What have they ever made that didn't work well?
Scuby04STi is offline   Reply With Quote
Old 06-16-2013, 06:39 PM   #22
panel
Member#: 352704
1965 Vw panel van
EJ20 Turbo Swap/convo
and no oil in the inlet return hose , the only downside is that i wish the pieces were a neater install.
m1r4g3 , Can you tell me if you are using the PCV valve and where was this line connected to? I think your yellow line one goes to the top of the AOS but just confused on where the other one goes to. Thanks!
panel is offline   Reply With Quote
Old 06-21-2013, 11:46 PM   #23
m1r4g3
Member#: 220476
WRB & SWP
you install enough hose on the circled area to reach the intake which is also the green hose in the previous pic
Old 07-01-2013, 07:55 PM   #24
panel
Member#: 352704
1965 Vw panel van
Thanks for the reply. Sorry to ask such newbie questions. Looks like you retain your PCV valve (line extended to intake) but then there is a one-way check valve in the system also?
Old 07-04-2013, 11:06 PM   #25
m1r4g3
Member#: 220476
WRB & SWP
redundancy, i just did what jeff told me to do with it.
