Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 01-27-2013, 12:53 PM   #1
2012SubaruSTI
Member#: 345044
2012 Sti
Default electronic boost control
I have a few questions that may seem stupid to some but we all have to start learning somewhere.. Basically im wondering what upgrades i need if any do i need to properly run an electronic boost controller and what would be safe boost numbers to run on the stock turbo.. As of right now im running an aem cai and soon ap with perrins stage 1 map and a greddy spectrum elite cbe.. One last question... Does anyone have any links for any other companies offering stage 1 maps for the ap... Sorry for the stupid questions
2012SubaruSTI is offline   Reply With Quote
Old 01-27-2013, 12:56 PM   #2
WRB19
Member#: 302898
2008 Evo X
Graphite Grey
Grimmspeed 3 port electronic boost control solenoid and a tune. Maybe 21 psi. Torqued performance has staged maps with EBCS that are more aggressive then cobb.
WRB19 is offline   Reply With Quote
Old 01-27-2013, 01:07 PM   #3
2012SubaruSTI
Member#: 345044
2012 Sti
Thanks... And better maps then perrin?
Old 01-27-2013, 01:48 PM   #4
WRrex12
Member#: 327113
2012 WRX Sedan
DMG
Are you running AEM cai without a tune as of now?
WRrex12 is offline   Reply With Quote
Old 01-27-2013, 01:50 PM   #5
Heedlessone
Member#: 254130
1993 LS1 RX7
That's the only way to do it. Dat cold air is mo' betta'.
Heedlessone is offline   Reply With Quote
Old 01-27-2013, 01:58 PM   #6
2012SubaruSTI
Member#: 345044
2012 Sti
Well i bought my cai and im just waiting to get it.. And i know everyone says to tune for it but i will prob run it without one until i get my ap.. That and theres only 7k on my car and i dont want to void my warrenty right away.. That being said yes i know its a safer tune and will do it eventually anyways..
Old 01-27-2013, 02:05 PM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
First off, fill out your profile. We don't even know what car you have.
Secondly, you're just as likely to "void" your warranty with that intake. (More likely actually) And to add to it, you cannot get your warranty voided. They can DENY you claims if you modified it, but not void it entirely.
You'll want to get a tune specifically for that intake when you do eventually get one. You cannot just flash a map that says X intake if you have Y intake.
To run ANY 3 port bcs you need a tune for it specifically. Adding a new BCS does not up your boost.
Read Unabombers manifesto and start learning before you end up breaking something.
Old 01-27-2013, 02:19 PM   #8
rudymcskoody
Member#: 257618
2006 wrx
aspen white
No....
rudymcskoody is online now   Reply With Quote
Old 01-27-2013, 02:24 PM   #9
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Ahhhh....the folly of youth.
1. Know you have to research the dogcrap out of even the most simple of parts.
2. You are lamenting warranty. If you want a warranty, DO NOT even think of modifying your car. Pay to play is the concept when you futz with your car in the warranty.
3. You have not read any of the sticky threads at the top of this or any forum, do so now.
4. Forget 100% of your old car knowledge as almost none of it applies to Subaru. For instance your stock intake is actually really good, so by putting on an aftermarket you are probably doing unseen harm as it may not throw a code or run rough, but might be running dangerously lean and you usually don't see dangerously lean until the time that the motor lets go and your are staring at a $5000 repair bill.
5. You have a long row to hoe here and it starts with EDUCATED modifications and so far you are failing the educated portion, please return it to stock, decide on your route, educate yourself via here and your tuner (and no this isn't something you can DIY) or just keep it stock.
Old 01-27-2013, 02:31 PM   #10
2012SubaruSTI
Member#: 345044
2012 Sti
I appreciate everyones advice... Thats why im here asking.. I have 12 sti hb.. As per the warrenty i was told by the dealer im allowed a cai and cbe... I do plan to tune but being there are no tuners where im from it will just be ots map.. And i have no plans for boost controllers or boost control solenoids yet.. I just wanted some clarification that i couldnt find from searching forums.. So do you guys not advise i run my cai without a tune even if its only for a month before i get my ap
Old 01-27-2013, 02:36 PM   #11
2012SubaruSTI
Member#: 345044
2012 Sti
I wish it were youth... But no.. just a lack of knowledge.. Hence why im here in the newbie section asking questions
Old 01-27-2013, 02:40 PM   #12
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
Step 1. Read Unibomber's response. Now read it again. That man knows his isht.
Step 2. Ignore that dealer, he is an idiot. Never follow their advice as they have very little say in warranty work. The damage you are risking is real. Worst case scenario, you blow the motor by running lean. That dealer now has to contact Subaru of America (Subaru of Canada in your case) to approve warranty work. Once the dealer tells them you have the CAI that claim will be DENIED as fast as the representative can type it.
Step 3. Correct, DO NOT RUN THE INTAKE WITHOUT A TUNE FOR ANY AMOUNT OF TIME. If there are no tuners in your area, you can get an e-tune. I will not go into specifics, that is for you to research and know if it is what you want or not.
Step 4. RESEARCH EVERY PART YOU WILL PUT ON YOUR CAR.
JSchell1309 is offline   Reply With Quote
Old 01-27-2013, 02:43 PM   #13
2012SubaruSTI
Member#: 345044
2012 Sti
Will do... Thanks for the advice
