Old 01-27-2013, 11:37 PM   #1
Kalvus5
Member#: 332400
2002 Subaru WRX
Default stage 1/2 problems with MBC?
Hey guys I'm looking to purchase an AP at some point. My car has a TurboXS MBC with a dual setup- 15 psi/17 psi. (I never really use 17 psi unless I'm showing it to my friends) I also have a PDE uppipe. My goal is to get an AP, then at some point down the line get a downpipe and go stage 2 ( catted downpipes are expensive!) When and if I go stage 1 or 2, does having a manual boost controller mess anything up? Will I have to take it off in order to go stage 1 or 2 or will I simply have to download and use another tune other than the stock stage 1/2 that comes with the AP? Also, while I'm asking this question, if I only want to go stage 1/2 should I get the v1 AP or the V2 accessport? I'm planning on getting it used and although on threads people say to get the V2, if I'm only gonna use it a couple times, is it worth the high price tag? thanks.
Kalvus5 is offline   Reply With Quote
Old 01-27-2013, 11:47 PM   #2
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
the mbc will just cap the boost at what ever it is ...so if your stg 2 tune for the cobb ap is suppose to hit 19psi it will only hit 17 but if i remember right stg 2 is around 17 psi anyways
Shortpersonbk is offline   Reply With Quote
Old 01-28-2013, 01:46 AM   #3
Kalvus5
Member#: 332400
2002 Subaru WRX
ok thanks and should I look for a V1 or is the V2 that much better in your opinion? I might just wait until one pops up for a good deal..
Old 01-28-2013, 08:57 AM   #4
Cobb Tuning
Member#: 4803
Hi there. The MBC is not compatible with our off-the-shelf (OTS) tunes for the Accessport. Our maps require that the engine control unit (ECU) be in full control of boost. With an MBC, that is definitely not the case. Depending on how it is set up, the ECU would have no control and you can end up with high partial throttle boost, overboosting and other potential problems that the ECU would have no control over. An MBC is not a necessary mod - the ECU has no problems controlling boost.
You could get a custom tune for the Accessport that would potentially work in spite of the MBC. But, that is still not recommended. For safety/reliability reasons, you should really allow the ECU to control boost fully.
We would highly recommend the version 2 Accessport. You will gain many benefits, including data logging from the device itself (this is huge - very easy to get logs to make sure everything looks good as far as boost, knock, etc.), live gauge monitoring (for monitoring boost, etc. live on the device),
launch control feature, recent ground-up new maps for 02-05 WRX, free AccessTUNER Race self-tuning software, and more.
Bill
Old 01-29-2013, 02:30 AM   #5
Kalvus5
Member#: 332400
2002 Subaru WRX
Bill
Thanks for the reply! The MBC came on the car so I'm not really sure what the procedure is to put it on or take it off. Does the engine simply go back to factory boost if it is taken off? or is it more tricky then that? Also one more question. If I were to get an accessport for my 02 WRX, then a few years down the line buy an sti, could I still use the same accessport if I unmarry it to the 02 and apply it to the sti? Thanks for the help.
Old 01-29-2013, 10:13 AM   #6
Cobb Tuning
Member#: 4803
Yes, you will need to put it back to the factory set-up. You can get an idea of what that entails here:
http://www.cobbtuning.com/Technical-...es-s/70674.htm
If you have a local Subaru performance tuning shop, they should be able to easily do this for (obviously for a fee), although you may have to purchase a few parts (such as the length of hose with the restricter pill in it from dealer).
The version 2 Accessport for the 02-05 WRX (SUB-001) will only work with those cars. But there is a strong used market for version 2 Accessport, so you shouldn't have any problem selling it.
Bill
