Old 01-27-2013, 04:22 PM   #1
SlowTrackImpreza
Member#: 262692
1999 GC ej217 WRB
22b widebody built fp red
Default Any good email AEM ems tuners, or one in hampton roads VA?
read post two please
Any good email base AEM ems tuners, or one in hampton roads VA?
quick rundown,
AEM EMS4
honeywell gt-101 cam/crank sensors
sti coil packs
blah blah.
car runs and drives...just pig ass rich. A buddy and i made a base map from scratch since the AEM ones dont even get the car even close to started.
soooooo.... I am just needing a drive around and occasional fun tune until the spring when temps stabilize and I get a true to heart 5 hour tune.
I am familier with other engines and tuning them fine, i just dont know the optimal timing curves on an ej207
SlowTrackImpreza is offline   Reply With Quote
Old 06-24-2013, 10:09 AM   #2
SlowTrackImpreza
Member#: 262692
1999 GC ej217 WRB
ok, bumping this up, I had an oil pickup failure on the 207, so i had to junk almost everything except the block...and only the block lol.
Now, since I have changed so much I can get it to kind of putt putt putt trying to start. I need someone who does email/online remote tuning of some sort, I know i have to pay, and im completely willing to. Every local person doesnt tune subaru except for one guy and he doesnt do aem...I'm a sad panda
general rundown of whats on it. I'll post my map later on tonight.
ENGINE:
ej207 block
ej205 heads
ej205 cam and crank trigger wheels
version 6 ej207 sti cams
2004 WRX side oiler 4 port crank (240 part#)
Wiseco 8.5:1 pistons
Eagle H beam rods
ACL bearings
ARP head studs
Tomei timing belt guide
Gates racing timing belt kit
Cometic head gaskets
08 STI 11mm oil pump
Greddy 180* oil cooler thermostat
CX racing external oil cooler
ej207 headers
External wastegate uppipe
Tial 44mm external wastegate open dump
FP Red 8cm ball bearing turbo (similar to garrett gt3076)
AC delete
PS delete
Turbo back 2.75" custom exhaust with espiler axel back.
12"x32"x3" CX-Racing front mount intercooler
Turbo xs rfl blow off valve
ECU/ELECTRONICS/GAUGES:
Omni power 3bar map sensor.
BRAND NEW optima redtop
AEM EMS4 full stand alone with 96" flying lead harness.
Run on speed density/MAP sensor
06 sti individual coil packs
Haltec/Honeywell GT-101 cam/crank sensors (hall effect)
AEM UEGO wideband feeding into EMS4
Autometer boost gauge
Autometer oil pressure gauge (good oil p, reads ~90 when cranking)
Autometer tachometer
FUELING:
TLF 800cc sidefeed injectors
Infiniti QX-56 330lph fuel pump
STI fuel pump hanger/surgetank
Thanks ahead of time to anyone who may help.
Old 06-27-2013, 11:01 AM   #3
Layvon
Member#: 195711
STi 04/05/06/07
PM Junior2jz.
Layvon is offline   Reply With Quote
