Old 01-27-2013, 07:59 PM   #1
blackpearl2.5
Member#: 116923
02 02WRX wagon WRB
04 2.5RS JBP
Default 02 wrx stereo problem
hey all, been awhile since ive been on here, sooo, i just picked up an 02 bugeye wrx wagon, has a kenwood ddx7015 stereo installed and it works untill i hit a bump then it loses all power and shuts off and stays off. i can pull the radio fuse in the cabin and it does nothing, then i pull the clock/cabin fuse under the hood and when i start the car the stereo works again untill i hit a decent bump then it shuts off again... wtf!!! i checked the wiring to the stereo and all looks good. nice and clean install job.. im stumped on this one . i wanna install my subs and amp but wanna figure out why the stereo is doing this before i do. any suggestions would be greatly appreciated..
blackpearl2.5 is offline   Reply With Quote
Old 01-27-2013, 08:33 PM   #2
OW79
Member#: 292792
2005 Impreza RS
Hi blackpearl, I am not a car stereo expert (although I've installed some) nor am I a Kenwood expert, but I am an electronics professional (technologist) so I know a thing or two about electronics. My guess is, being a two or three year old radio (I assume this because you most certainly did not just install this radio in a used car you just bought), the contacts inside the unit are defective. The (wave) soldering they do in electronics is so skimpy on sodler sometimes, you wonder how it can withstand any kind of shock.
Furthermore, my friend had a Kenwood radio, and only after a couple of years, he had a similar problem to your radio. Sure enough when I opened it up, the power/output connector was loose on every pin. Lucky for him, the sodler pads were not lifted (meaning the copper had not delaminated from the PCB) and I was able to simply resolder all the pads. the radio worked fine afterwards.
It very well could be that you have this problem in your radio.
Just open it up and look at those connections. If you can "jiggle" the connector and see the pins moving in the solder, well, you have your answer... You'll need to be technically competent to solder these back on.
You might want to use Lead-free solder as I am sure that all these consumer electroncis companies have went lead-free since about six years or so.
You can post back here with pictures if you like, I can help you determine exactly what you're looking at.
By the way, I thought the bug-eye Subarus started in 2003?
OW
OW79 is offline   Reply With Quote
Old 01-28-2013, 06:49 AM   #3
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
Originally Posted by OW79 View Post
<snip>
OW
Nope, '02.
John
Guzzi 1 is offline   Reply With Quote
Old 01-28-2013, 07:47 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The wiring may "look" good but there could still be a bad connection. Do a "wiggle test" with the harness to try and duplicate the problem. Tap on the radio and smack the console around it, see if it flakes out. If the problem does turn out to be internal in the radio there isn't much you can do and it will have to be replaced, but before you take that step you want to confirm that it isn't a simple wiring issue.
Old 01-28-2013, 01:12 PM   #5
blackpearl2.5
Member#: 116923
02 02WRX wagon WRB
04 2.5RS JBP
Thanks for the replies, I pulled the stereo last night, checked all the wires closely and the only thing I could find was the front driver side speaker wire wasn't connected, so I re attached it. Then I attempted to take it apart but couldn't get down past the cd/dvd player.. Damn double dins lol.. So I put it back together and put it back in the car. It works now but only time will tell if it shuts off again.. Might just have to buy a new one, and I haven't even tried the dvd player yet.. Smh..
Old 01-28-2013, 10:36 PM   #6
surchk
Member#: 333968
MPB
just a thought, ive got a ddx318 (lower end doubledin compared to the excelons) I had it in my 2004 4runner, every once in awhile if I hit a big enough bump it would cut off and I couldnt for the life of me figure out why. After i bought my 02 wrx and installed it i NEVER had the issue again with that unit.
Fuses and everything else was good, i had to reset the cars power by turning the key to the right, which you can do in that generation 4runner (if you turn the key again in the wrx if the cars already running i believe the starter would engage)
The only thing that changed was that I removed the bypass relay (which allows you to have dvds play while the car is in drive, i had that setup so my little cousins can watch their movies if we went on long drive in the lcds i had in the back). I check out the relay turns out it was faulty AND some some of the wires werent connected properly (to the 4runner harness). Maybe if there was a bypass wired up that could be your problem?
surchk is offline   Reply With Quote
Old 01-29-2013, 12:21 PM   #7
blackpearl2.5
Member#: 116923
02 02WRX wagon WRB
04 2.5RS JBP
could be... so far its been working fine since i pulled it out and messed with it.. ive been hitting all kinds of bumps i can find, smacked the dash around a bit lol, still working. figures as soon as i convinced the wife i needed a new one the damn thing works perfect.. lol. might gete a new one anyway because i want one with bluetooth so i can listen to my phone on it and use the gps for nav.
