Old 01-27-2013, 09:37 PM   #1
CuervoVT
Member#: 277303
2004 WRX
Obsidian Black Pearl
Exclamation *Clicking* noise when accelerating and bad boost
I have a 04 WRX, it was retuned with 565 DW injectors (dont know if that matters). Im running stage II and have the boost turned down to 12.5 max.
When i accelerate in any gear i hear a fast "clicking" noise coming from the area around the turbo (left side of engine when facing it). The noise begins when the boost is rising from 10 inHg to 0psi then it stops.
The car has 145k miles on it and i check the oil every other fill up and have it serviced as scheduled.
I am thinking it is a preturbo leak as i never reach full boost anymore. Any thoughts before i start tearing things apart.
CuervoVT is offline   Reply With Quote
Old 01-27-2013, 10:36 PM   #2
alx8283
Member#: 225024
2002 wrx
Boost control solenoid?
alx8283 is offline   Reply With Quote
Old 01-27-2013, 11:14 PM   #3
CuervoVT
Member#: 277303
2004 WRX
Ill look into that too but everything should have been changed out when I got my tune
Old 01-28-2013, 09:49 AM   #4
Jayzwrexx
Member#: 125927
2000 2.5rs
Brp
are you currently running a stock BCS?
Jayzwrexx is offline   Reply With Quote
Old 01-28-2013, 03:29 PM   #5
Member#: 301037
2004 Forester XT
You may be over taxing the stock BCS trying to keep it at 12.5 psi on a stage 2 setup.
art@grimmspeed is offline   Reply With Quote
Old 01-28-2013, 10:27 PM   #6
quazimoto
Member#: 70395
Why would you run less boost than stock?
quazimoto is offline   Reply With Quote
Old 01-29-2013, 10:45 PM   #7
CuervoVT
Member#: 277303
2004 WRX
The car turned into my DD when i bought a bike. But I had a look today, no exhaust leaks and the BCS is fine.
anyother thoughts? valves maybe? or injectors?
Old 02-03-2013, 11:34 PM   #8
CuervoVT
Member#: 277303
2004 WRX
Put my boost back up to 17.5psi this past weekend, still runs the same.
Going to have a shop run some tests later in the week and hopefully have the problem fixed.
Ill post the results
