Old 01-27-2013, 09:54 PM   #1
tyrel.boyce
Member#: 270178
2002 Subaru WRB
380HP stock motor HTA68
Default Speed Density
I know recently that cobb just came out with speed density for the wrxs and i am curiouse if anyone has dne this setup yet? i need to know what is all needed to run speed density ther than getting rid of your stock MAF.
tyrel.boyce is offline   Reply With Quote
Old 01-27-2013, 10:30 PM   #2
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Searching brought up nothing.
wrxsubiemod is offline   Reply With Quote
Old 01-27-2013, 11:17 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Nothing extra is needed to run SD on a typical setup. High boost setups will require a MAP sensor that can read up to their target boost, but that's it. You do NOT want to get rid of your MAF sensor either, since SD is heavily dependent on IAT, which is integrated with your MAF. In fact you will want to re-locate your MAF sensor so that it is between the intercooler and the throttle body (if it isn't already) unless you've already installed an aftermarket IAT sensor in the manifold.
Old 01-27-2013, 11:31 PM   #4
rocketperson7
Member#: 283968
2003 WRX
MBP
why somebody who owns an '02 would want Cobb's SD instead of the Carberry ROM baffles me
rocketperson7 is offline   Reply With Quote
Old 01-27-2013, 11:34 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
you can wire the iat sensor into the maf wiring and ditch the maf sensor. Hello 4inch intake.
btw, probably should have this in the tuning section.
scby rex is offline   Reply With Quote
Old 01-28-2013, 08:29 AM   #6
Nuke209
Member#: 108089
2003 WRX
NF Performance
Live tuning
Supported by many tuners (who tunes using cobb)
Nuke209 is offline   Reply With Quote
Old 01-28-2013, 01:32 PM   #7
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Originally Posted by Nuke209 View Post
Live tuningSupported by many tuners (who tunes using cobb)
That makes tuning SD a breeze.
Old 01-28-2013, 03:22 PM   #8
belaud
Member#: 224449
2012 Kit B STI
Midnight ???
Having your IAT as close as possible to your throttle body is the way to go, you'll have very inaccurate temperature readings using the MAF situated right in front of your filter, best way to go if to find a P&P IAT, or re-wire in an IAT with the MAF harness.
You will also want to get a new MAP sensor that is much more capable than your stock one.
From what I understand, Cobb's SD also has a hybrid function where idling uses MAF, while x+ RPM uses SD, might want to contact them on how it works on further detail.
belaud is offline   Reply With Quote
Old 01-28-2013, 06:46 PM   #9
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
You could buy a used V1 AEM standalone for around 500 bucks, map sensor 60 bucks and an AIT kit 60. Then you'll be set to do damn near anything you want. OR find out what your local tuner prefers to use.
But all that is needed to be speed density is : MAP, AIT, and Wideband o2 sensors.
I run nothing, but standalone's so I am bias. (I personally don't like the AP, but that's just me)
...CHUCKLES... is offline   Reply With Quote
Old 01-28-2013, 08:16 PM   #10
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Position your IAT like this ......
binjoau is offline   Reply With Quote
Old 01-29-2013, 12:57 AM   #11
tyrel.boyce
Member#: 270178
2002 Subaru WRB
okay thanx guys
Old 01-29-2013, 12:46 PM   #12
scby rex
Member#: 104878
02 wrxbastardchild
My tuner wanted the iat right after the I/c. Might want to contact the tuner you going to use.
Old 01-29-2013, 03:44 PM   #13
abrumlev
Member#: 197920
2005 Legacy GT
ABP
Binjoau was tuned by MPS. I'd say it's probably there for a reason lol.
Wishing someone would get opensource SD on 32 bit ECU's so I don't have to drop 500 on a AP
abrumlev is offline   Reply With Quote
Old 01-29-2013, 03:48 PM   #14
Member#: 51961
2005 STi
2012 WRX
You mean like this?
http://romraider.com/forum/viewforum.php?f=37
I've been running it for a while now on my 05 STi, works great. Looks like support for the 05 LGT was added in November 2011.
Old 01-29-2013, 04:10 PM   #15
abrumlev
Member#: 197920
2005 Legacy GT
ABP
*Climbs out from under rock*
Thanks dude ill read into it!!
Old 07-07-2013, 06:19 PM   #16
tyrel.boyce
Member#: 270178
2002 Subaru WRB
Everything was planned to go SD but now im having some kind of issue with my car going rich now, right when I hit boost my wideband will just peg 10. checked for vacumn leaks and fixed a couple but still hasent changed.
Old 07-07-2013, 11:43 PM   #17
Juice66
Member#: 340526
2004 WRX STi
HTA86
Beautiful piping. Are those meth jets next to IAT?
And is that custom piping for reverse lgt manifold or a mps kit?
Juice66 is offline   Reply With Quote
Old 07-07-2013, 11:54 PM   #18
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Very nice
Old 07-08-2013, 12:02 PM   #19
TheBoz
Member#: 64397
2006 WRX STI
Steel Gray
The hard part with putting your AIT sensor above the engine, is that it will heat soak. So you could see 140* temps on your AIT when your air charge is really only 110*. Pretty soon I am going to get a few new bungs welded into the intercooler pipe and change the location of my AIT sensor and test which one is the best.
I think right after the intercooler will be the best spot, but I don't have any data to support that yet.
TheBoz is offline   Reply With Quote
Old 07-08-2013, 01:53 PM   #20
sidewayz
Member#: 5810
2001 S366 2.5RS
I have mine and all of my customers mounted in the intake behind the throttle body. Heat soak is t anymore than if it was in the pipe. In fact I feel it's more accurate
sidewayz is offline   Reply With Quote
Old 07-08-2013, 05:08 PM   #21
bebesito21
Member#: 176128
5862 ...baby boosted
Live tuning
Thank you...i was starting to think i was the only one that saw the huge value in this. The OS crowd poo poos on anything not OS lol
just wish the sample rate was higher on the COBB but i guess it already uses too many resources and the stock ecu cant keep up
my iat is mounted in the intercooler pipe just before the throttle in a nice straight section.
bebesito21 is offline   Reply With Quote
Old 07-08-2013, 07:46 PM   #22
kellygnsd
Member#: 32669
LINK G4 hybrid STi
The intake manifold?
I have mine directly in the mani right here and it heat soaks horribly. I might move it to the IC pipe pre-TB and compare the readings but my IM gets so damn hot that it skews the readings artificially high.
Old 07-08-2013, 08:04 PM   #23
05_wRex
Member#: 170097
2007 WRX STi PTE6266
Lol.
Mine is in the charge pipe about 4-5" upstream from the throttle body. Hot restarts after sitting for a little bit can be a little funky. Some extra start decay took care of it for the higher iat temps.
Btw, vipec is insanely awesome.
05_wRex is offline   Reply With Quote
Old 07-08-2013, 08:55 PM   #24
sidewayz
Member#: 5810
2001 S366 2.5RS
I have my personal one up higher. Soak isn't a problem with mine. Ill have to post some logs
Old 07-09-2013, 12:48 AM   #25
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
ETS puts the bung about 6" prior to TB as does COBB when installing from scratch and other tuners I have seen do similar. I don't know if that's because on cars with IAT stock, that is the "usual" location or if it's actually the best spot, just something I've noticed over the years.
Tyrial is offline   Reply With Quote
