Old 01-28-2013, 05:42 PM   #1
SJwrx
Member#: 14970
1997 GF8
multi
Default ABS code 25: before I order an ABS unit
Hello again my friends,
Long story short I bought a 2002 WRX over the weekend with 195,xxx miles on it on the ultra cheap ($2050), so suffice it to say, it has a few 'issues'... one being a stubborn ABS code 25.
Initially when I bought the car it had the ABS light on, SES (CEL) on, low coolant, and so on... so what do you do? Pull off at Chevron, fill all the fluids, do a battery reset for 30 minute and see whats left over.
ABS light was still on, so the mystery continued. I came home, pulled up the service manuals, and found how to read the codes (two long, 5 short = 25) and have ABS code 25 (right rear ABS sensor electrical fault).
Cleared ABS codes via test procedure, code 25 is instantaneously back... me thinks an electrical issue.
The connectors end up being under the back seat, check voltage and ohm the wiring out, 4.7v and 18 ohms.... 18 seems a but high so of course, you compare to another corner... the left rear corner has the same values...hmmm.
So I took apart the RR just in case of something 'odd' happened in between connectors at the RR ABS sensor and the chassis harness (under back seat), nothing.
As one last check I uplugged both LR and RR ABS sensors just to see if the ABS unit was monitoring them all, re-read codes, still only ABS code 25 (even with the LR also unplugged, should have triggered another 'open circuit' fault).
... from this tests I'm concluding the ABS ECU is biased on the RR, hence the permanent fault. Differing opinions?
-Richard
PS. I dont have an oscilloscope, only a Fluke 88 just FYI.
SJwrx is offline   Reply With Quote
Old 01-29-2013, 11:51 AM   #2
SJwrx
Member#: 14970
1997 GF8
multi
Nobody in a whole day?
-Richard
Old 01-29-2013, 03:12 PM   #3
jamal
Member#: 71875
98 Legacy GT
my wheels fit
You need to check the code with a code reader. I'm pretty sure you can't count flashes like with ODB1 cars.
And it is likely a wheel speed sensor is unplugged or loose or damaged or something.
jamal is offline   Reply With Quote
Old 01-29-2013, 10:27 PM   #4
SJwrx
Member#: 14970
1997 GF8
multi
As per the Subaru manuals you can, as on said "screenshot".
Thanks for the input though
Old 02-01-2013, 06:51 PM   #5
WiRX
Member#: 205930
If you need a unit I have two I could give you a deal on one of them.
WiRX is offline   Reply With Quote
Old 02-02-2013, 10:36 AM   #6
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
I hope by "ABS unit" you mean new wheel speed / abs sensor for the right rear corner as that's what your trouble code seems to identify as the problem. I expect the sensor to be a whole lot cheaper and a lot less PITA to replace.
Scooby921 is offline   Reply With Quote
Old 02-02-2013, 12:46 PM   #7
SJwrx
Member#: 14970
1997 GF8
multi
I was initially leaning that way too, simple code = simple repair. So come to find out the previous owner had the sensor replaced... no dice. I have the receipt and have visually verified the part is "newer" in comparison to the other sides.
Plan of action, switch the ABS sensors from left to right (rear), clear the code, and see if the fault 'travels'
