#1 |
Member#: 310009
Vehicle:03 WRX MBP |
I have a pretty bad oil leak right under the intake manifold between the power steering pump and pcv. It is not turbo related. I replaced the crush washers to the oil feed and return line hose thinking that would be the problem. Still pools of oil on top of the passenger side block/head. The oil galley seems fine so does the PCV. No coolant in the oil or sludge, typical head gasket symptoms... The motor has about 200 miles on the rebuild. Pretty posotive head gaskets weren't put in backwards. Anywhere else it can b leaking?
***Fixed*** - Oil temp sender not tightened. Currently facing another problem though. The car smokes like mad at idle. It's definitely oil and add cent amount is being consumed. The car doesn't seem to be making less power, but oil pressure seems a little low. I just want to know what causes burning oil and smoking at idle only.
#2 |
Member#: 192147
NESIC
Vehicle:2007 STI EfiLogics 422whp 421wtq fpgreen |
When I put my built engine in one of the rubber breather line couplers split when I slid it on the block and did the same thing your describing.
#3 |
Member#: 5810
Vehicle:2001 S366 2.5RS |
Ps pump leak. Rear housing orings die and piss all over the top of the head... Common. $30 gets a seal kit from Subaru
#4 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
^^^ That's what I was thinking, too.
#5 |
Member#: 76974
Vehicle:2005 CGM STI 10.03 @ 135 |
Is it slightly in front of the intake manifold? If so check the stock oil pressure sending unit.
#6 |
Member#: 304696
#7 |
Member#: 310009
It's oil not PS fluid. It goes from the back of the block by the oil galley plug to the front between the ps pump and alternator. Where is the oil sending unit? In the front near the alternator? Trying to get a good idea where to look before I pull the intake manifold.
#8 | |
Member#: 76974
#9 |
Member#: 310009
#10 | |
Member#: 5810
#11 |
Member#: 265277
Vehicle:2002 18g Hybrid Black on black |
clean the existing oil, start the car and look for the leak until you see where it's coming from.
Sounds stupid but it's better than guessing |
#12 | |
Member#: 310009
I believe I have found my leak... It was rather warm out today and decided to go out and check it out more thoroughly. Removed the alternator and sure enough I found the oil sender unit to be fairly loose. I moved quite freely with a crecent wrench. I tightened it up a bit and now crossing my fingers. Thanks MD05STI for the help and advice |
#13 |
Member#: 322939
Vehicle:10 WRX 96 LSi |
Has anyone had issues sealing the valve covers? I have an issue with the passenger side only. I am on the second gasket, and still have seepage all around the cover. Any pointers on getting this to stop would be greatly appreciated. It is an extremely small amount but it kinda stinks dripping on the uppipe
. Im gonna pick up another gasket today. |
#14 | |
Member#: 310009
![]() Make sure your mating surfaces are completely cleaned and free of oil. Apply light coat of specified gasket sealer. Make sure your half moons are not loose (if they are they should get gasket sealer as well). Try and use new bolt cover washers. I dont believe gasket sealer is neccessary for the spark plug o-rings. Lastly make sure your gaskets are on correctly ![]() |
#15 |
Member#: 322939
Sorry it looked like a good place to put it.
![]() Thats what I tried to do last time. I dont believe my motor has the half moons you spoke of, and no washers. The bolts are flanged. I may have gotten a bad gasket twice . I tried with and without sealant. I will try again with. The manual says no sealant. Thanks for the reply. |
#16 |
Member#: 340333
Vehicle:1997 Impreza OBS 2.2 Blue |
Is there a good chance the PS is leaking all the way to the back of the engine, passenger side?
