Old 01-28-2013, 08:29 PM   #1
s14blktop
Member#: 306332
2011 wrx(hatch)
metalic gray
Default bloush dom 3.0xtr input. like or dislike
I am looking at getting one can someone give me great feed back that has one and if u had one and then got rid of it for any reason. My goals are just over 400 whp without ragging the turbo out
s14blktop is offline   Reply With Quote
Old 01-28-2013, 08:41 PM   #2
u n STI????
Member#: 149895
2007 sti
white
i've got iton my 07 sti so far everything is good
powerband is great
u n STI???? is offline   Reply With Quote
Old 01-28-2013, 08:52 PM   #3
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
Great turbo, a little large for daily driving imo. will need at least 850 cc injectors, larger fuel pump, larger topmount or a frontmount intercooler, larger intake possibly. Forged pistons are recommended for this power level imo.......do it now or fix it later when she breaks....your choice.
I run straight meth inj w 93 pump on mine. Putting out anywhere btwn 390 and 415 hp depending on temp and dyno. Going on 4 yrs w mine
Good luck
krambte79 is offline   Reply With Quote
Old 01-28-2013, 08:55 PM   #4
WRXSteye20008
Member#: 175565
2014 Sport Premium
Satin White Pearl
For a Dom 3 you will have to go FMIC, TMIC will not do for that application. I would suggest calling Mike at Blouch Turbo, he is a great guy and will help you with any question you may have.
WRXSteye20008 is offline   Reply With Quote
Old 01-28-2013, 09:02 PM   #5
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
This is not true. I run a larger top mount + 100% meth just fine for the past 4 yrs. I would agree that a frontmount would be more ideal for this size turbo but not the only option.
Old 01-28-2013, 09:09 PM   #6
WRXSteye20008
Member#: 175565
2014 Sport Premium
Satin White Pearl
I realize that as I run a Spearco TMIC as well on my built motor, but ideally a FMIC is the way to go, but as mentioned, not the only option, but a better one.
Old 01-28-2013, 09:15 PM   #7
s14blktop
Member#: 306332
2011 wrx(hatch)
metalic gray
Yeah I have the process west top mount , 1000cc inj. In tank 300lph , water meth , and aem intake with perrin turbo inlet pipe with tomei eq header and ewg tial 38mm. So with all this I want a bigger turbo and as of right now the dom3.0xtr seems really nice. Thanks for yhe replys so far
Old 01-28-2013, 09:51 PM   #8
WRXSteye20008
Member#: 175565
2014 Sport Premium
Satin White Pearl
It's Blouch by the way, not Bloush
Old 01-28-2013, 11:04 PM   #9
s14blktop
Member#: 306332
2011 wrx(hatch)
metalic gray
Thanx for the spelling lesson!
Old 01-29-2013, 12:24 AM   #10
subaru fan
Member#: 127910
04 STI silver
What other turbos are you looking at that compare? I'm kind of in the same boat as you I can't decided which turbo would go and my build is pretty similar to yours
subaru fan is offline   Reply With Quote
Old 01-29-2013, 12:44 AM   #11
DerickRyoung
Member#: 178050
02 hybrid-wrx
psm
If you aren't running forged pistons and again still having a TMIC (yet the best one in my opinion) and not a FMIC, I would check out the bragging rights thread for the Dom2.5xtr seems to make really good power and better for DD. Other person stated they have a TMIC but are running meth I thought which gives you an advantage and lower intake temps. Which s14blktop also has meth and thus probably fine with TMIC also its a process west not a TXS.
I own a Dom3xtr and though I am happy with it, I have a fully built longblock and cams so its in my rpm range. It spools quicky for a non-twin scroll 30-35r ish. And I like the turbo but I did have a problem with Blouch. I noticed oil consumption and then had the turbo taken off to find carbon build up down the downpipe and in the exhaust housing. Then shop stated serious shaft play (back and forth direction). They charged me $700+ to replace the billet CHRA (center housing). So I have mixed emotions yet it works great now. Also, before rebuild when I would turn off car I could hear the turbine spinning/winding down with a harsh sound and now its rebuilt it still spins/winds down but much quieter and not so harsh sounding. Lastly running it on a stock bottom may work, but for how long? If you don't plan on doing a built motor down the road I would say this is the wrong turbo, personally. But if you are looking into the those options eventually then I say its a great turbo.
Thats my :2cents:
DerickRyoung is offline   Reply With Quote
Old 01-29-2013, 02:28 AM   #12
Pitcrew91
Member#: 271718
2005 STi
Cant really give any input yet as ive had my car for a month and it has summer tires on it..
05 STi
unknown if engine is built(assuming stock)
Dom3
APS 725 FMIC
TDC 816cc injectors(custom, getting new ones come spring most likely)
255lph
Stock headers and u-p, 4in turboxs dp-invidia Race
had it retuned safely for 20psi, tuner says its putting about 374whp down.
With that said, the guy who tuned my car, and quite a few of friends all agree its a great turbo for a stock engine. Ive read 400whp is the turning point where your going to wanna consider a spare engine, or building your current engine. Overkill is better than no car.
Pitcrew91 is offline   Reply With Quote
Old 01-29-2013, 06:49 AM   #13
roadtrip1098
Member#: 185688
2006 STi
WR Blue
I'm looking at a 2.5XTR for my STi. Motors not built yet, the plan is to talk my wife into a WRX/STi that way as I upgrade, her car will get the hand-me-downs. She's pretty psyched about it.
roadtrip1098 is offline   Reply With Quote
Old 01-29-2013, 04:39 PM   #14
Shayhan27
Member#: 205906
05 WRX
CGM
I just got mine installed. Will be getting it tuned Thursday on e85. I have a front mount. I'm on a hybrid with cams. On my initial tune with 18 lbs of boost I made 300. Should be at 400 with the e85 and 340 Ish on 91. The torque curve is steep. Of boost it runs great. It does want to go part 7k rpm. I will post up my final numbers Thursday. I love this turbo though.
Top mount was selected for safety, and a built short block is in the works for the very near future.
Shayhan27 is offline   Reply With Quote
Old 01-29-2013, 05:46 PM   #15
s14blktop
Member#: 306332
2011 wrx(hatch)
metalic gray
I am deffinatly aware of the engine and its fragile pistons. I am going into this set up knowing that ultimatly ill have to rebuild the engine. I also have a wrx with the 5spd so with longer gears it should be nice on the streets. I dont plan on running a hi psi tune all the time. But I will post numbers once we get an all wheel dyno in alaska..
Old 01-29-2013, 06:05 PM   #16
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You'll need to look into a transmission swap as well, or at least stronger gears in your 5 spd. You should budget at LEAST $10k for supporting mods in addition to the obvious (fuel, tune, etc.). That should cover your impending engine failure and blown transmission.
Old 01-29-2013, 06:26 PM   #17
Shayhan27
Member#: 205906
05 WRX
CGM
That's about what I'm into mine with the 6 speed swap and front Brembos. This is not including my new short block build. Figure like this
2k turbo
1k front mount
5k tranny clutch and install
1k injectors, intake, fuel pump, installed.
1k misc labor and tune.
Old 01-29-2013, 10:04 PM   #18
s14blktop
Member#: 306332
2011 wrx(hatch)
metalic gray
Yeah you guys are right but just like any build unless your super rich u build as u go. And once it happens ill address the problem with better parts.
Old 01-29-2013, 10:20 PM   #19
Member#: 51961
2005 STi
2012 WRX
Honestly, if your goal is 400 whp, you never should have bought a WRX in the first place. This is the reason the hundreds/thousands of "wrx vs sti" threads on NASIOC exist, to let potential buyers know when they should buy one model versus the other. If your goals are 400+ whp, it would be unanimous to NOT buy a WRX. Anyone who votes otherwise doesn't know what they're talking about.
At this point you're looking to pay more in drivetrain modifications to support that power than it would cost to sell your car and buy an STi, literally. You should seriously step back from the situation and reconsider if you want to go through with this on your current car versus selling it and buying an STi.
Old 01-30-2013, 12:36 AM   #20
subaru fan
Member#: 127910
04 STI silver
soooo any way........ what are some other turbos out there...
soo far dom3xtr,dom2.5
what about the fp green?
and i agree if you are choosing to run a top mount, prepare to run into mad heat soak. so step up to e85 and even meth???
any one have any fuel ideas? like injectors they are running with " X " turbo and how many miles they get to a full tank of e85?
thank youss for any input
Old 01-30-2013, 12:48 AM   #21
scoobasaurusrex
Member#: 255114
2007 wrb wrx wagon
93oct vf43 ewg
I would take any of the FP's any day over the dom's... Just better all around turbos in my opinion. OP, as others have said, I hope you have deep pockets if you're doing this on an otherwise stock drivetrain. You're essentially turning your engine and trans into a ticking time bomb by doing this, even on a conservative street tune. Not to say that it can't or hasn't been done, but just be prepared for what is going to become a matter of time instead of "if".
scoobasaurusrex is offline   Reply With Quote
Old 01-30-2013, 01:42 AM   #22
Shayhan27
Member#: 205906
05 WRX
CGM
I disagree. That's kind of a big blanket there. I like blouch because they have a great track record of customer service and taking care of thier warranty work. Fp has a pretty good trackrecordas well. I do believe that blouch has taken the edge with the changes they have make on the xtr center and compressor wheel.
Old 01-30-2013, 01:53 AM   #23
DerickRyoung
Member#: 178050
02 hybrid-wrx
psm
^ I think it just depends on what someone wants. If you want a street monster or a track monster? Is the car to be gutted and caged? Are you going to upgrade everything beyond the STi's threshold then I say a WRX is perfect. The STi to me is a generally tuned to perfection from the factory one could argue "why even touch it at all?" If you just want a street monster then yeah an STi would win, but I have a bugeye because I am going to cage the car and strip it down. Easier for me to swallow then a $35k car getting stripped and replacing every part I bought or financed. Not trying to argue or defend, just giving perspective BTW. I still agree with your point, just wanted to throw out my idea.
^Agreed, I thought the FP were journal bearing but maybe their technology has caught up I am not sure and only here bad things about them. Everyone makes this claim about the 5 speed failing, but I did the 6 speed swap and that failed me as well. So I had that rebuilt which cost me $$$ and I did the DCCDPRO controller. I have gone through it all between my tranz probs to being on 4th motor but 1st built one.
Ultimately it seems the OP is aware of issues and plans on building the motor eventually, if so, then I would say this turbo has the capabilities to make the power he may desire.
Old 01-30-2013, 07:49 PM   #24
Member#: 51961
2005 STi
2012 WRX
That's true. There are basically three levels to modding:
1) less than WRX drivetrain's breaking point
2) greater than #1, but less than STi drivetrain's breaking point
3) greater than #2
For #1, a WRX is fine. For #2, an STi is clearly the better choice. For #3, again a WRX is probably a better starting platform since you're going to have to swap out everything anyway. To me, it sounds like the OP fits into #2, but I could be wrong.
Old 01-30-2013, 09:24 PM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i believe it is a 100% total waste of time to buy a wrx with the thought of highly modding it
if you are wanting to make more power than the 6mt will take then you are modding the wrong platform...or better be willing to spend $$$,$$$
and YES...that is 6 figures....unless you do ALL your own work
and you'd still get yer ass handed to ya by a gtr with a few lil mods
IMO....wanting to highly mod any subaru is a fools errand...they just arent a good platform for most to mod
