Old 01-29-2013, 12:09 AM   #1
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Default DIY Powder Coating thread
So I am starting this thread as I want to see where other DIY people are with powder coating.
So here is an example of my recent work. A Chrome base coat with a blue candy top coat. This is my first time doing a two stage powder coating.
I am using a Craftsman Powder Coating gun from eBay for $35. With a $35 toaster oven from Costco. Using Chrome and blue powder coating from eBay $20
Old 01-29-2013, 12:15 AM   #2
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Looks great. Makes me want to get a home setup. Was it fairly easy to do?
I--RIDE--BIKES is offline   Reply With Quote
Old 01-29-2013, 12:31 AM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
It was not that difficult if you understand the process. Clean, paint with chrome, bake 15 min. Paint blue, fully bake 30 min. Total time about 1 to 1.25 hr.
What you don't see is I got a little heavy and the powder run once in the oven. As you can see the blue came off the bolt down in a tiny spot. Also I have a shop where I had to hook the grounding strap. At the top, the blue didn't cover and it was a bit thicker where the powder pooled. Nothing that will be noticed one it's installed. Overall not bad for my 3rd time powder coating and my first time doing a candy.
Yet I still am not sure what color to make the top. Any suggestions?
Old 01-29-2013, 11:24 AM   #4
ADaughen
Member#: 333348
2000 Forester S
STM
Careful, a local started out this way as a hobby... now, it is almost a full time job, with a walk-in oven. He can do motorcycle and ATV frames, axles, etc. Only thing he can't do is full size frames/bodies.
He said the most time intensive part is prepping the part. If it isn't clean, bare metal, it will not adhere well.
If I had a spare 220v outlet in the garage, I would already be doing this with a freebie oven I was offered a while back.
ADaughen is offline   Reply With Quote
Old 01-29-2013, 12:49 PM   #5
jonow6
Member#: 315903
2006 Saab 9-2x
Cheers to powder coating!
I've been powder coating for a short while. Initial setup is a bit expensive (in order to do a wide range of part sizes as well as proper prepping), but its sure nice to be able to do.
jonow6 is offline   Reply With Quote
Old 01-29-2013, 12:54 PM   #6
jonow6
Member#: 315903
2006 Saab 9-2x
An example of a part I made up and powder coated
Old 01-29-2013, 03:48 PM   #7
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
I got a used harbor freight powder coat oven (18x18x18 on the in side) and a power coat gun. I just need to get a sand blaster and I will be ready to give this a try.
AFBeefcake is offline   Reply With Quote
Old 01-29-2013, 11:47 PM   #8
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
That HB oven is 220v? I have been looking for 110v solutions.
Old 01-30-2013, 01:28 AM   #9
fenderpicks
Member#: 287694
2011 WRX
Hey OP, i want to ask you.
What do u use to prep the part, and how do u spray the powder on the part when u are ready?
Do u have the ground it, so the powder will stick to the part?
PS: I have a basic EASTWOOD powder coat system.
FOr some reason i can never to 2 stage coating, i BARELY manage to get a perfect appearance with single color paint, and when i try to do candy color, i could NEVER get the 2nd powder to stick with the 1st
fenderpicks is offline   Reply With Quote
Old 01-30-2013, 04:04 AM   #10
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Cleaning was a clean rag and brake cleaner. It was pretty clean but needed that perfect clean. Yes I grounded it on a hole. Your gun is simular to mine I think. When doing a 2 stage only bake it half way. Then do the candy color. Candy can also be added to real chrome as well.
Old 01-30-2013, 09:22 AM   #11
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
Its 110v
Old 01-30-2013, 09:57 AM   #12
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Oh cool. I might consider that then. Kind of wishing I could find something in the 20in range. Like an old lab oven. There used to be one that was made by dispatch that was double door 110v. More then large enough to do an intake manifold.
Old 01-30-2013, 12:23 PM   #13
fenderpicks
Member#: 287694
2011 WRX
How does your ground look like?
Because mine has a ground and i have to hold down a button while i spray for my gun.
I usually do it in my backyard to shoot the powder. And for some reason sometimes the powder goes on good, sometimes it doesnt....
I cant figure out why lol
Old 01-30-2013, 01:25 PM   #14
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
My powder gun has a small alligator clip.
You problem might be that switch doesn't work all the time. Might take a multi meter and check it out. If it was me I would cut the switch out and wire it direct to a clip.
Old 01-30-2013, 01:34 PM   #15
fenderpicks
Member#: 287694
2011 WRX
lol i would if i knew how to...
im not good with electrical....
Do u have a spray booth or some sort?
I was looking it up yesterday and saw people use a big plastic box with a metal rod inside and a vaccum hooked up on the back...
i was thinkking maybe i need a box or something
Old 01-30-2013, 03:59 PM   #16
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
The electrical is not that bad. What you want to do is make sure it's connected all the way through when you push the button. So turn the multi meter to where it make sound when both leads touch. Then touch each end. If it beeps. It's good. But if you move the wire and it turns off it has a connection issue.
me spray booth or anything serious equipment. No way. I basically backup my car in the garage. Laid down plastic trash bag on the floor and put my little oven on my coffee table thing. Taped the bag down. Sprayed chrome. Baked 15 min. Spray blue. Bake fully. The best trick I found is how you spray it. It has to be even and thick but not too think to cause running when you bake it. But like I said above, this is only my 3rd item I have ever done. Yet the 1st candy color.
Old 01-30-2013, 04:01 PM   #17
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Don't cause to much air flow or it will mess with your powder hitting the item well.
Old 01-30-2013, 05:11 PM   #18
fenderpicks
Member#: 287694
2011 WRX
How many psi do u put the gun to?
Old 01-30-2013, 05:36 PM   #19
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Oh well maybe we don't have the same gun. As mine has no compressor connection. I have a simple craftsman gun. You plug it in, put your powder and attach the ground. It blows like a hair drier on low. I only spent about $35. It works great considering.
Old 01-31-2013, 01:35 AM   #20
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
This is what I was talking about how you don't want to put to much on. As it will bleed like paint when you bake it. Good thing it won't be scene.
Old 02-01-2013, 12:59 PM   #21
Boost is Best
Member#: 102858
15' WRX
ISM
Awesome Thread! Subscribed for more!
Boost is Best is offline   Reply With Quote
Old 02-03-2013, 10:56 PM   #22
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I installed the coolant tank and it looks great! Tried to do the top but the paint is on there pretty good. So I'm working on it.
A friend told me a tip. Using stove cleaner will remove anodizing. So cusco strut bar here I come.
Old 02-04-2013, 06:11 PM   #23
brendan04wrx
Member#: 167494
04 STi
psm
just subscribed too. I have a ton of parts to Powdercoat and don't like paying others to do work for me. just need to collect the tools so I can join in on this
brendan04wrx is offline   Reply With Quote
Old 02-05-2013, 08:34 PM   #24
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
Videos would be awesome! Who's brave enough to video their work?
arco is offline   Reply With Quote
Old 02-06-2013, 08:31 AM   #25
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
yea see my ghetto way of doing my powder coating.
