Old 02-14-2013, 01:01 AM   #26
illesti51
Member#: 346756
2008 STI
Spark Silver Metallic
Nice work Hybrid. Just a little bit of advice try preheating the item before you coat it. Don't get it extremely hot just hot enough where it will stick even without needing an electrical charge. Keep up with the good work!
illesti51 is offline   Reply With Quote
Old 02-14-2013, 01:35 AM   #27
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Thank you. I'm working on the coolent tank top part. But the top of the tank is proving more difficult.
Old 02-14-2013, 11:57 AM   #28
illesti51
Member#: 346756
2008 STI
What are you having trouble with? Ive been powder coating for the past 3 years or so, so if you have any questions feel free to ask
Old 02-14-2013, 12:28 PM   #29
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Just the black oem paint around the rad cap. They have it on there all the way up the neck.
Old 02-14-2013, 01:54 PM   #30
illesti51
Member#: 346756
2008 STI
are you trying to coat over the oem paint?
Old 02-14-2013, 02:13 PM   #31
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Just trying to get the old stuff off. I need to try sand blasting but living in an apartment it's not easy. Paint remover is not very effective.
Old 02-14-2013, 02:29 PM   #32
illesti51
Member#: 346756
2008 STI
yeah I sand blast everything I coat then cleaned it with acetone. If you don't have access to that I know you said you've tried paint remover is that aircraft stripper? That stuff is pretty good sometimes depending on the brand and if its in a spray can or gel styled base
Old 02-14-2013, 03:05 PM   #33
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I wonder if my stipper is too old to be effective.
Old 02-14-2013, 04:04 PM   #34
illesti51
Member#: 346756
2008 STI
It possibly could be. I know if it gets real old its not as effective as it is new. Try a gel based stripper as well, in my opinion its more effective rather than the spray can type. Only downside is it can be a little messier. If you cant get some spots just try sanding it down with a ruff grit sandpaper then make sure to clean
Old 02-14-2013, 09:16 PM   #35
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Good to know. See how it goes. Might have to continue this next week.
Old 02-16-2013, 05:35 PM   #36
magus2222
Member#: 280225
aircraft stripper wont touch powder coat, you have to use powder coat stripper, its twice as caustic as paint stripper.
heres some of my work:
mind you, im also using a 1000$ gun with dpw (digital pulsation wave) board upgrade, multiple filters/separators, and a powder coating oven
its a dual, 2 tone setup. black with a green prism overlay, and a blue with a turqoise flake overlay
i have another engine i did with a chrome base/candy blue top coat, the other part was a hyper mirror black as well.
magus2222 is offline   Reply With Quote
Old 02-16-2013, 05:43 PM   #37
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Your powder coating the engine?
Old 02-16-2013, 07:34 PM   #38
illesti51
Member#: 346756
2008 STI
yeah hes right aircraft stripper wont touch powder coating but it will the oem paint which is what I think he was having the problem with. If you want to remove powder coat I would suggest using industrial b17 stripper. Just don't let it touch you or I promise you'll get burnt
Old 02-16-2013, 11:21 PM   #39
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I was just reading how the top lid to the coolant tank is weak and can break off at the cap neck. Any idea how strong it is or what to avoid?
Old 02-17-2013, 01:33 AM   #40
manys
Member#: 265277
1999 Outback
Legacy
nevermind, I found some info on powder coat strippers..
manys is offline   Reply With Quote
Old 02-17-2013, 06:48 PM   #41
magus2222
Member#: 280225
yes, b17 is the only stuff to use, but make sure when you do, you have LOTS of ventilation and wear a mask, 2 layers of gloves if not gauntlet style gloves. it will burn you very badly if it touches you (ask me how i know....)
Old 02-17-2013, 07:19 PM   #42
Mechie3
Member#: 120152
How do you hold a part to fully powdercoat it? It seems wherever youre holding it wont get covered.
Mechie3 is offline   Reply With Quote
Old 02-17-2013, 08:26 PM   #43
illesti51
Member#: 346756
2008 STI
you have to hang it using S hooks or some kind of wire. I used a lot of welding wire
Old 02-17-2013, 11:11 PM   #44
Mechie3
Member#: 120152
Wouldn't it still not get coated where that wire is touching? Though, if it's a threaded hole it wouldn't matter anyways. I assume you can't touch the powder anywhere until after you've baked it?
Old 02-18-2013, 10:58 AM   #45
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
You could use a bolt then put the wire to that. So to keep the threads clean.
Old 02-18-2013, 05:44 PM   #46
Subikid90
Member#: 239233
1998 LGT
I do this a lot when painting parts. Comes out great every time.
Subikid90 is offline   Reply With Quote
Old 02-18-2013, 06:45 PM   #47
illesti51
Member#: 346756
2008 STI
right it wont coat where the wire is touching. Just find the best place to hang it possibly where the part wont be seen on your car ect. and like hybrid said run a bolt through a threaded hole and hang it from the bolt. your gonna need to plug the holes anyway if you dont then your gonna have to retap them
Old 02-19-2013, 03:02 PM   #48
magus2222
Member#: 280225
if you use a bolt and hang it from there, it makes a perfect place to put the negative wire on to charge the part too!!
as you do more and more powder coating, you find little tricks and faster ways of doing things
oh and yes, that was an entire engine i powder coated, aluminum and iron
Old 02-26-2013, 02:28 AM   #49
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Nearly finished with the coolant tank top. Just finished sand blasting. Looks good. A tiny bit more and I will be ready.
Have you guys scene that new burnt orange color with peril? Looks good. Just have no idea what I would use it on.
Old 02-26-2013, 05:44 PM   #50
mrkyle3328
Member#: 347864
09 legacy
metalic gray
Sick , in trying to find a cheap oven so I can start doing rims
mrkyle3328 is offline   Reply With Quote
