Old 01-29-2013, 01:06 AM   #1
Sidewinderpb
Member#: 312048
2011 BMW e92 335i
BSM
Default Stage 1 stock 93 26psi?
So I was on a road trip up to Vermont, and had pulled over into a parking area. Upon leaving, I ripped through 2nd and 3rd to get onto the highway. When I looked at my AP, it said I hit 26.2 lbs of boost. Pretty sure that I shouldn't be going that high. I'm running a stock setup with the OTS Cobb stage 1 93 octane map. Problem?
Sidewinderpb is offline   Reply With Quote
Old 01-29-2013, 01:28 AM   #2
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
log and report back. your not any LWG OR HWG right? should be topping out @ 16psi on stock 1 93 no intake
JAMM0N is offline   Reply With Quote
Old 01-29-2013, 09:43 AM   #3
cmiovino
Member#: 134005
2004 WRX Premium
That's way too high. Dangerously high... if it's a true reading.
Test it again (as much as you'd want to avoid hitting those numbers, but you'll have to confirm it). If you're boosting that high, going to a LWG or HWG isn't going to change it that much. It's more of a finer tuning deal with 1-2 psi.
Old 01-29-2013, 10:39 AM   #4
1wrxtra
Member#: 316364
2012 WRX
Were you looking at the "Boost" parameter, or the "Boost Target" parameter?
1wrxtra is offline   Reply With Quote
Old 01-29-2013, 12:27 PM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
Relative vs absolute pressure?
Old 01-29-2013, 12:36 PM   #6
Sidewinderpb
Member#: 312048
2011 BMW e92 335i
BSM
That was the boost target. Let me know if I've been looking at the wrong thing lol - I'm a nub with all of this. It's the nwg map. I've got to find some time to run logs.
Old 01-30-2013, 09:38 AM   #7
Cobb Tuning
Member#: 4803
Hi there. The boost target is what the map is attempting to hit, after all compensations, not what you are actually hitting. 26 psi is not a normal target, however, in 1st gear, there is a compensation that we modify that increases the boost target extremely high to artificially aid in boost response in 1st gear. You can't overboost in 1st gear, so this is a way to improve response in that gear with no downsides.
Take a look at our data logging video below which will explain how to data log and some of the more important parameters:
Bill
