Old 01-29-2013, 06:36 PM   #1
Prusienski234
Member#: 332204
Default 08 2.5i lightweight crank pulley
I was wondering if it was alright to install a light weight crank pulley on my 08 2.5i hatch? Am I gona need a special tool to get the old pulley off?
Prusienski234 is offline   Reply With Quote
Old 01-29-2013, 08:28 PM   #2
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
I don't think you'll need a special tool, a few of my friends have them and have mixed feelings, the rpms drop a lot faster with a light weight it seems like
alt14 is offline   Reply With Quote
Old 01-29-2013, 11:00 PM   #3
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
No special tool needed, just a big breaker bar and someone holding the brakes.
Counterfit is offline   Reply With Quote
Old 01-30-2013, 02:32 AM   #4
Tomato_88
Member#: 204277
Dark Gray Metallic
I am on my mobile so I can't see your profile. Automatic or Standard transmission?
Tomato_88 is offline   Reply With Quote
Old 01-30-2013, 02:59 AM   #5
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Break crank nut loose
Loosen alt and ac tensioners
Remove belts
Remove stock pulley by wiggling
Replace with LW pulley
Replace belts
Retension belts
Torque crank nut to 132 ft/lbs
cal_look_zero is offline   Reply With Quote
Old 01-30-2013, 07:35 PM   #6
Prusienski234
Member#: 332204
Standard trans
Old 01-31-2013, 12:25 AM   #7
iommichild
Member#: 194990
2008 OBS
Steel Silver/Spark Silver
No special tools needed, and you honestly dont need another person to hold the brakes. I just put it in 5th and jammed a 2x4 on the brake when I did mine. the breaker bar is an ABSOLUTE must though!
iommichild is offline   Reply With Quote
Old 01-31-2013, 02:03 AM   #8
Zordos
Member#: 165121
it's a stretch fit ac belt on the 08+ so no tensioner. i got my crank pulley off without putting anything to hold the brakes, just had it in 3rd gear with a long breaker bar
Zordos is offline   Reply With Quote
Old 02-01-2013, 01:58 AM   #9
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
Which pully did you use? I'm planning to put one in when I do my timing belt kit and head gaskets in a few months. I have been looking at grimmspeed and perrin.
Bababou is offline   Reply With Quote
Old 02-01-2013, 10:08 PM   #10
Zordos
Member#: 165121
I just took my pulley off to do my timing belt. Might consider getting an lwp down the road
