Old 01-30-2013, 08:27 AM   #1
dnldmelton
Member#: 340314
Default 2005 sti not reaching target boost
I have on 05 sti with short ram intake and 3 in cat back exhaust running 93 oct stage 1. I can't get the car to push more than 8 psi with the normal stage one and I can get 9 psi with the high waste gate map. My waste gate load doesn't go over 75% when full throttle in 3rd gear with I'm pretty sure means its not closing fully and I'm losing boost to the world, I read that you can adjust the waste gate by loosening the lock nut on the solenoid and the turning the rod either clockwise or counter clockwise my question is has anyone done this or have any other ideas as to why I'm not reaching my target boost of 16 psi? No other issues with the motor everything is running like it should across the board and there are zero vacuum leaks. Can someone help me?
dnldmelton is offline   Reply With Quote
Old 01-30-2013, 08:58 AM   #2
tuzzio
Member#: 292532
05 STI
List of mods? Sounds like you have a boost leak somewhere
tuzzio is offline   Reply With Quote
Old 01-30-2013, 10:23 AM   #3
dnldmelton
Member#: 340314
Short ram intake stock down pipe 3in cat back and AP stage 1 as far as motor I'm thinking my wastegate isn't closing fully and needs adjustment
Old 01-30-2013, 11:44 AM   #4
tuzzio
Member#: 292532
05 STI
If I recall properly you can't adjust the wastegate on the vf39. Maybe you have a preturbo leak, header or uppipe
Old 01-30-2013, 11:52 AM   #5
dnldmelton
Member#: 340314
There aren't any leaks that I can find
Old 01-30-2013, 01:16 PM   #6
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Check the boost control hoses.
jebjkey is offline   Reply With Quote
Old 01-30-2013, 01:22 PM   #7
dnldmelton
Member#: 340314
I will check there later this evening and let you know how it turned out
Old 01-30-2013, 01:32 PM   #8
dnldmelton
Member#: 340314
I just thought about it and it wouldn't be those hoses cause my air fuel ratio would be messed up and it's not, what should my waste gate load read at full throttle?
Old 01-30-2013, 01:35 PM   #9
Streetslappah
Member#: 337127
05 STI
Wrb
My brother had the same problem he couldn't boost above 10 psi he bought a new boost control (Grimspeed) and had it tuned and the problem was gone. Maybe it's the hoses on the boost control or the pill on the "t" hoses?
Streetslappah is offline   Reply With Quote
Old 01-31-2013, 08:28 AM   #10
Cobb Tuning
Member#: 4803
There are many reasons why a particular car will underboost compared to the peak target specified in the map. Wastegate duty will not hit 100% - what you are seeing (around 75% at WOT) is around what is expected for the high wastegate map. Some questions:
1. Do you have a version 1 or version 2 Accessport? The version 2 Accessport is the current version with the color screen. If you have the version 2, then try to get a 4th or 3rd gear wide open throttle (WOT) data log from 2500 RPM on up if you can do so safely (see data logging video below).
2. Did you buy the car used? If so, did you ever determine if you were boosting normally when you bought it? Sometimes when you see severe underboost with a used car it is because the previous owner had mods that required removing the restrictor pill or using one with a larger diameter hole. They may remove those mods but not mess with installing the correct restrictor pill. Boost hardware info can be found here:
http://www.cobbtuning.com/Technical-...es-s/70674.htm
3. What brand short ram intake do you have? Although it won't effect your boost issue, you must only use the Cobb SF or stock intake with our off-the-shelf (OTS) maps. Using other intakes could potentially cause engine damage without a custom calibration.
Bill
Old 01-31-2013, 08:41 AM   #11
dnldmelton
Member#: 340314
Video Link: http://www.youtube.com/watch?v=rjEGZ-4dsDYz
Bill
I have the version 2 with the color screen, when I bought the car it was only pushing about 3 psi I replaced the tgv sensor and it jumped up to 7 psi but I had a cylinder misfire, I put the stage 1 tune on and the misfire went away and it ran alot smoother I'm pretty sure whoever had the car before I'm pretty sure had an upgraded turbo and a down pipe and were running a stage 2 I was about to check the pill last night but got called away to an emergency. The short ram looks like some auto zone bull crap and I noticed last night the C clip that should be on the waste gate that connects the solenoid it's not there and it looks like it is welded. Ill have to find a straight enough road to test 4th WOT I live on an island so it's a little tough sometimes lol
Old 01-31-2013, 08:51 AM   #12
Cobb Tuning
Member#: 4803
I would first replace the intake with the proper one (stock or Cobb SF). An unsupported intake can potentially cause major fueling and timing issues. I would also suggest taking the car to an experienced Subaru tuning shop and have them do a once-over on the car (including compression and leak-down test). You want to know what you are dealing with. I would also consider getting all maintenance items checked (that may have not have been completed by previous owner), including spark plugs, fuel filter, etc.
You can get a 3rd gear run instead, if you can do so safely. But, I would replace the intake first and have someone look over the car before doing any more WOT pulls.
Bill
Old 02-01-2013, 05:47 PM   #13
Dillinja666
Member#: 332644
07 STI
It's white
I had the same issue, kinda. Mine was hitting 11-12psi on the stage 1 tune, and for giggles I threw the stage 2 on and it jumped to 13-14. I though it was a boost controller, and replaced it with a stock one but it did not fix it. I figured out later that the cats were plugged when I pulled them off and put a DP on.
Dillinja666 is offline   Reply With Quote
Old 02-02-2013, 09:30 AM   #14
dnldmelton
Member#: 340314
I'm not even hitting that much, and I doubt a clogged cat would cause a 7 psi loss, I'm gonna take a look and see if that pill is in the T hose cause I'm trying to do the easiest things first before I find out I gotta drop some read money into stuff
Old 02-04-2013, 04:30 PM   #15
dnldmelton
Member#: 340314
Thanks to all, I noticed the pill was missing so I ordered all new lines and everything with the pill not too bad so if it doesn't fix it only spent $13 ill let all know how it turns out thanks for the advice
Old 02-04-2013, 05:36 PM   #16
Dillinja666
Member#: 332644
07 STI
It's white
Did you give them a part number or just tell them year make model?
If you want to make sure they order the right one you can use this info.
Model.............................Orifice....P/N#..............MSRP...Notes
2006-2007 WRX-0.8mm...0.0315 ..22326AA260... $4.00~ Line Asembly Pink dot
2007 STI .......................0.0335 ..14447AA140 ..............Line Assembly
1.0mm ..........................0.0394 ..22326AA010... $2.00~
2004-2006 STI ...............0.0430 ..14447AA090... $20.00~ Line Assembly Yellow Dot. 2008 STI 14.5 psi max
2004-2005 FXT-1.2mm ...0.0472 ..22326KA120 ...$2.00~
2002-2005 WRX .............0.0472 ..22326KA120 ...$2.00~ 2008 STI 14.3 psi max.
2005-2006 LGT ..............0.0490 ..14447AA120 ...$16.00~ Line Assembly
2008 STI .......................0.0350~ 14447AA250~ .$85.00~ Line Asembly? Aqua Dot. Determined size from measuring.
Old 02-04-2013, 05:53 PM   #17
dnldmelton
Member#: 340314
I ordered it through the dealership and just gave them the make and model, I got all the hoses and everything that comes with it and the T connections
Old 02-04-2013, 08:18 PM   #18
subieguy87
Member#: 153412
1998 Impreza wrxRS
They told me that part comes with the turbo,and that's the only way they come??
subieguy87 is offline   Reply With Quote
Old 02-04-2013, 09:02 PM   #19
Dillinja666
Member#: 332644
07 STI
It's white
Tell em you want this part number
14447AA090
just say I need this part number don't give em any info.
Old 02-04-2013, 09:07 PM   #20
dnldmelton
Member#: 340314
Ill give them a call back tomorrow morning, I was looking for a part number earlier and I called auto zone with a different one an they could cross reference it ill double check though and make sure that's what I ordered
Old 02-04-2013, 09:16 PM   #21
subieguy87
Member#: 153412
1998 Impreza wrxRS
14447AA090
Info isn't a problem with me as my local dealership is used to selling me wrx parts for my gc. They know about my swap
Old 02-04-2013, 09:24 PM   #22
dnldmelton
Member#: 340314
There isn't a huge market out here, there are only about 10 wrx & sti in the area and I know everyone just about so getting parts in a hassle and even the dealership has to order them
Old 02-05-2013, 01:33 AM   #23
Dillinja666
Member#: 332644
07 STI
It's white
oops sorry subieguy87, I got you and the op switched.
Old 02-05-2013, 06:36 AM   #24
subieguy87
Member#: 153412
1998 Impreza wrxRS
I actually need that same line lol
Old 02-06-2013, 06:47 PM   #25
dnldmelton
Member#: 340314
The restrictor pill was the issue, popped that little pill in there and it was a day and night difference. Forgot to change the high waste gate tune and was pushing 18.5 psi lol once I put the regular tune on there it's down to my target 16 psi, thanks to everyone and there input much cheaper than the route I was gonna go
