Welcome to the North American Subaru Impreza Owners Club Saturday August 23, 2014
Old 01-30-2013, 11:24 AM   #1
rdieder
Member#: 257818
2007 STi
CGM
Default Big turbo guys, why VTA BOVs over recircualting BPVs?
Why do all you big turbo guys choose a vent to air style BOV rather than an aftermarket big recirc style bypass valve?
Is the "rich" shift a negligible cost for surge? or is there something i'm missing?
I was thinking the recirc style bypass is optimal if you running the stock ecu in any form, ie. opensource, Cobb AP, Utec, aftermarket piggyback, etc..
Even with a fmic, it can be plumbed back into the hotside piping to keep the fmic pressurized, rather than into the turbo inlet (post maf) just to keep consistent with the originl stock subaru design flow.
rdieder is offline   Reply With Quote
Old 01-30-2013, 11:37 AM   #2
207STi
Member#: 197062
1998 Swapped Impreza
black
Most of the guys running big turbos ditch a maf based system all together and go with speed density. Vta is no problem with a SD setup.
207STi is offline   Reply With Quote
Old 01-30-2013, 11:41 AM   #3
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
^ correct. size of the turbo is irrelevant it is the fact they are MAP tuning instead of MAF tuning
07VTRex is online now   Reply With Quote
Old 01-30-2013, 12:12 PM   #4
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
I do it because it sounds bad ass. That and less routing.
...CHUCKLES... is offline   Reply With Quote
Old 01-30-2013, 12:17 PM   #5
rdieder
Member#: 257818
2007 STi
CGM
^haha, VTA does sound badass.
thanks for the replys.
if i go with a Cobb SD tune with a VTA, will my around town mpg suffer? Im guessing that it still would use MAF around town and cruise situations until i trip over into open loop where SD takes over.
Old 01-30-2013, 12:20 PM   #6
...CHUCKLES...
Member#: 149674
2006 LimitLess STI
SGM
If you have a compitant tuner and a nice tune then your MPG should not suffer.
What makes your MPG suffer the most is your right foot.
Old 01-30-2013, 12:45 PM   #7
spintheground
Member#: 239638
2007 WRX TR UGM
02 MR2 EGM
Am I the only one who dislikes the sound of VTA?
spintheground is offline   Reply With Quote
Old 01-30-2013, 12:56 PM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Even without SD, a blow through MAF can be tuned for as well.
KillerBMotorsport is offline   Reply With Quote
Old 01-31-2013, 04:32 PM   #9
Steve.804
Member#: 68647
07 STI
Rotated 35R Jorge Tuned
And it's usually the big turbo guys that do that in order to take advantage of the larger turbo inlet. 4" intake + MAF = no bueno.
I'm running a VTA BOV on my 35R set-up and I'm still using a MAF sensor but that is b/c it's what came with my kit and I was on a time crunch to get it tuned. I have a step-down coupler coming off the compressor housing down to 3".
I plan on doing my engine build soon and one of the things I'll be addressing is using a recirc. valve even though I will be going SD. The noise gets pretty damn annoying and when you have an EWG dumping to atmosphere...how much more noise do you need?
Steve.804 is offline   Reply With Quote
