Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 02-07-2013, 02:27 AM   #26
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Originally Posted by Bluefoton View Post
it'd be nice to clear that up once and for all. So 642s for EJ251 and 770 for EJ253? Is there any difference in between coolant passages on the head in these two N/A engines?
Phase 1 dohc is -610, which is a thicker MLS gasket
Phase 2 sohc to somewhere around 08-09 should use -642, which is the 04-06 turbo gasket. So that includes the 251 and 253 I think.
09 ish and up already have the -770 MLS gasket in them, which is the same thickness as 642 but has different cooling passages.
I think the change was whenever they started putting avcs or avls or whatever it is on the n/a 2.5s.
jamal is offline   Reply With Quote
Old 02-07-2013, 12:50 PM   #27
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
I believe that year would've been 05 in USDM, if not 06 for sure.
Sir-Knight is offline   Reply With Quote
Old 02-09-2013, 02:02 PM   #28
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Aren't coolant passages supposed to match the holes in the head/block? If the head design didn't change in between 07-08-09, why would the HG differ?
Old 02-09-2013, 03:16 PM   #29
jamal
Member#: 71875
98 Legacy GT
my wheels fit
Yeah, the head design did change. If avcs was added in 05-06 I guess that's not when it was, but I remember seeing an 09 or '10 outback with the new -770 gaskets.
There's a picture of it here:
http://forums.nasioc.com/forums/show....php?t=2155089
Old 02-12-2013, 11:30 PM   #30
cdwahl
Member#: 144605
2007 2.5i Wagon
Satin White Pearl
What about for valve cover gaskets, will the dealer have MLS?
I need to replace my valve cover gaskets and I am not excited to install the same ones that failed after 60-90k...
cdwahl is offline   Reply With Quote
Old 02-13-2013, 01:36 AM   #31
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
The valve cover gaskets are not steel. So you can't get any mls valve cover gaskets. The oem ones work fine as long as you follow the fsm and also make sure all surfaces are clean when installing.
rhino6303 is offline   Reply With Quote
Old 02-13-2013, 11:35 PM   #32
cdwahl
Member#: 144605
2007 2.5i Wagon
Satin White Pearl
So you think that they failed because they weren't installed properly at the factory?
Old 02-14-2013, 01:26 AM   #33
rhino6303
Member#: 181314
05 Legacy GT RBP
They are a wear item. Getting 90k out of the valve cover gaskets is great.
Old 02-17-2013, 11:36 AM   #34
MikeC5
Member#: 104702
95 Legacy
Green
So has anyone used the 11044AA642 (MLS) gaskets on an 2.5 NA? Specifically, for a 2002 engine.
MikeC5 is offline   Reply With Quote
Old 02-17-2013, 12:32 PM   #35
rhino6303
Member#: 181314
05 Legacy GT RBP
Yes. It has been done a lot on 2.5 n/a motors all the way up until they changed the coolant chamber designs.
Old 02-17-2013, 01:11 PM   #36
walhalla
Member#: 333084
how much is compression is effected
walhalla is offline   Reply With Quote
Old 02-17-2013, 01:43 PM   #37
Bluefoton
Member#: 141373
2008 2.5i-hatch -
0.1 increase in CR
