Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 01-30-2013, 03:39 PM   #1
4Cornered
Member#: 229028
1984 GL 4WD Wagon
Default Poor performance while cold
I was finally able to reproduce a problem reported by my wife with our 1984 GL. When the car is cold (left out in roughly 25 degrees for 8 hours) it starts fine, runs OK in 1st and 2nd gears, but won't pull 3rd until the temperature guage shows it has reached normal operating temperature. Once normal operating temperature is reached, car runs normally. I've done an initial check of vacuum lines without any leaks being detected. This car has a Hitachi carb which has a number of termperature dependent parts. Any suggestions on what order to troubleshooting?
4Cornered is offline   Reply With Quote
Old 02-18-2013, 01:09 AM   #2
Kevint143
Member#: 332258
1979 BRAT
alpine green/black
My 79 brat did this same thing...I bought a weber
Kevint143 is offline   Reply With Quote
Old 02-18-2013, 01:32 AM   #3
kingbobdole
Member#: 85055
1989 XT-6
That sounds almost normal, those old hitachi carbs are not usually very cold friendly. First thing to look at is to see when the choke opens. It's meant to enrichen the fuel mixture when cold, but it stays closed too long it can be an issue.
kingbobdole is offline   Reply With Quote
Old 02-27-2013, 07:01 PM   #4
argonsoon
Member#: 348503
Mine does something totally different, when its cold it doesnt like to shift out of first gear :P
argonsoon is offline   Reply With Quote
Old 02-27-2013, 07:54 PM   #5
TurboneX
Member#: 21676
RX 02Foz90XT692SVX
Try changing the gear fluid.
TurboneX is offline   Reply With Quote
