Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 01-30-2013, 05:30 PM   #1
nate_fisher
Member#: 270482
2011 turbotek fxt
11.85@117 4eat xt record?
Default TMIC gasket?
I have a perrin knock off torqued solutions tmic on my 2011 forester xt (08+ wrx/legacy fitment) and i use a hand cut cork gasket for the turbo to tmic flange with great success on my td04, vf52 and now my 20g. Untill last night when i was doing a pull and blew it out at around 24psi on my 44lb per min turbo. What is every one else using for the gasket on theres and is there a better option? It came with a thick plastic gasket but i could not see that being a good option and had trouble with it leaking on my vf52 should i try that again. For now i am going to cut another cork gasket but just wondering what the other 08+ guys are using these days.
nate_fisher is offline   Reply With Quote
Old 01-30-2013, 06:27 PM   #2
Shayhan27
Member#: 205906
05 WRX
CGM
Do you feel the plastic one will not seal? Without looking at it and just taking a short in the dark I am wondering if you put a thin layer of rubber cement on each side and let it dry if it would work better
Shayhan27 is offline   Reply With Quote
Old 01-30-2013, 08:08 PM   #3
holyjoetart
Member#: 232986
07 Legacy GT
Is there a groove for an o-ring, like the perrin?
holyjoetart is offline   Reply With Quote
Old 01-30-2013, 09:33 PM   #4
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
Most people use the chevy water outlet mr. Gasket brand gasket. I can't remember the number. Google legacy gt Mr. Gasket intercooler gasket.
rhino6303 is offline   Reply With Quote
Old 01-30-2013, 11:56 PM   #5
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Yep, I would use some high temp gasket maker. I just applied it to the plastic spacer they provide and it sealed fine.
xluben is offline   Reply With Quote
Old 01-31-2013, 09:34 AM   #6
nate_fisher
Member#: 270482
2011 turbotek fxt
Sounds good i may try the plastic one again or look into the mr gasket thermostat gasket and no it does not have the spot for the oring like the perrin.
Old 01-31-2013, 12:37 PM   #7
nate_fisher
Member#: 270482
2011 turbotek fxt
Actually the mr gasket water outlet gasket seems to pretty awsome looking so i think that will be my next gasket.
Old 02-02-2013, 05:58 PM   #8
nate_fisher
Member#: 270482
2011 turbotek fxt
Well the mr gasket chevy v8 thermostat gasket is a perfect fit and good quality made of metal with a silicone o ring middle. But of course i broke the threads on yet another turbo over tightening the tmic to turbo gasket. I always feel like i can get one more turn on it and then snap so luckely i had a longer bolt and it was long enough to catch and it tightened down just fine.
Old 02-03-2013, 10:37 AM   #9
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
i know the feeling. i stripped my front flange bolt on my vf52 putting the perrin spacer in place on my tmic. i got longer bolts at a hardware store and they went all the way down through. its good now. my first perrin o ring was distorted and melted in the tmic.
424wrx is offline   Reply With Quote
