Old 01-30-2013, 07:08 PM   #1
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Default Suba03ru's Build *Pics* Rev Works Closed Deck-Precision-AMS
!@#$%Updated as of April 7th, 2016!@#$%
Hello,
I have been on the forums for about 8 years now and have mostly used it for the classifieds, but now its time to post a build journal. My last setup prior to this last deployment made apprx 350whp/350tq. I was still running a stock block and a stock location turbo and E85 for fuel. Nothing happened to the motor or car, however the quest for more horsepowers was calling. Upon purchasing the car a few years ago from a single owner my first upgrades were suspension, BC coilovers, Whiteline sways f/r, TiC bushings, mounts, etc.
Stay tuned for updates and photos. Any feedback or input is welcome. I will entertain valid points but I'm not a fan of E-Thuggin, Keyboard Gang Bangin', etc, so if you don't have anything nice/constructive/valid to say, don't say anything at all.
Mod List Prior to Teardown(for the most part)
VF43 w/ port work
Fuel rails, lines, walbro intank, w/ 1300cc injectors
Ported Intake manifold, Throttle Body and TGV Deletes
Blitz Nur Spec Exhaust
Bellmouth Downpipe
EWG up pipe w/ TiAl 38mm V-band
DC Sports exhaust manifold
COBB SR intake
Gimmick turbo inlet
Spec stg 2+ Clutch
COBB Accessport with a Tune from Mikey Botti of PhatBotti Tuning.
These are the big things that really made the difference in the car, obviously there are dozens more small things but those are the big ones.
Additions/New Items on the new build:
***Update as of April 2016***
Rev Works Closed Deck Block
-New OEM STi Block Halves
-New OEM STi Crankshaft
-Wiseco 9.0:1 Pistons
-Manley Forged H-Beam Rods w/ARP625+ rod bolts
-ACL Race Bearings
-11mm STi Oil Pump
Rev Works Stage 2 Heads
-Stage 2 Port Work
-GSC Valves
-GSC Beehive Springs and Retainers
-BC 280 Cams
-P&L Head Breathers
Additional Motor/Turbo Componenets
-2200cc RCI injectors
-TiC/MAW Composite TGV's
-Fluidampr Pulley
-AMS 750R Rotated kit w/ PTE turbo, TiAl 44mm EWG, catless downpipe, v-banded all around
-Aeromotive FPR and a 2L swirl pot with a Walbro feeding it and then a Bosch 044 feeding the injectors.
-Crawford AOS
-Mishimoto X Line radiator with fan kit and Zerosports Thermostat
Input is welcomed. The goal for the car is roughly 500whp with high 400's in torque. Fuel will be E85 again and the purpose is to compete in time attack/road racing.
Last edited by suba03ru; 04-07-2016 at 10:58 PM. Reason: Photos added, title change.
suba03ru is offline   Reply With Quote
Old 01-30-2013, 07:15 PM   #2
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Preppin' for teardown
Day 1 progress crappy cell pic
Let it drain all night
Apprx Day 2/3
Tearing down spare set of 2.0 heads, will be machined to match the 2.5 combustion chamber
Old 01-30-2013, 07:18 PM   #3
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Finally some room to work. Subaru motor bays are so ridiculous. There are hoses, lines and cables everywhere! Cruise control, AC, and a couple other small items will no be going back in.
Old 01-30-2013, 11:16 PM   #4
Fir3Fighter
Member#: 316780
2003 Impreza WRX
Good luck on you're build! Very excited to see how it ends up!
Fir3Fighter is offline   Reply With Quote
Old 01-30-2013, 11:33 PM   #5
wrx1392
Member#: 342331
2003 wrx
blue
Question for you ,if you dont mind ...what is that hunk of purple alum on your head ...some kind of tool ? your list looks great gonna be awsome .after looking again ...is it a spring compressor?
wrx1392 is offline   Reply With Quote
Old 01-31-2013, 12:40 AM   #6
Nuke209
Member#: 108089
2003 WRX
NF Performance
valve spring compressor
bolt down where the cam caps are
Nuke209 is offline   Reply With Quote
Old 01-31-2013, 02:19 AM   #7
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
looks like 50% of the motor mounts came out with the engine
907Bum is offline   Reply With Quote
Old 01-31-2013, 06:31 AM   #8
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Correct, it is a valve spring compressor, very handy tool to ave if you do a lot of Subaru head related work.
Old 01-31-2013, 06:32 AM   #9
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Yea the motor mounts were very frustrating. They have only been in for a few thousand miles and one of them would only break free from the motor and not the chassis.
Old 01-31-2013, 11:29 AM   #10
KpT KiM
Member#: 242422
375 whp on an STI turbo? Do you have a dyno plot? Just curious as I haven't seen numbers that high with that turbo.
Build looks good though.
KpT KiM is offline   Reply With Quote
Old 01-31-2013, 11:51 AM   #11
AK907TRE
Member#: 230886
02 wrx,in a coma
loaned a 2001 rs coupe
e-thuggin... good luck on the build bro.
AK907TRE is offline   Reply With Quote
Old 01-31-2013, 12:54 PM   #12
kakarot09
Member#: 182375
08 Sti
Wrbm
What sort of power do you expect to make? Are you running this only on pump gas or on race gas, e85? The rods I have mentioned BC I beams tons of times now. I think they are more than strong enough for this type of setup and won't break the bank. However Manley came out with a new H beam the H-tuff that looks very good for the money too. For bearings pretty much all of them have had success. I've used acl and clevite personally and also used one company for rods and another for mains and they've all worked just fine. That said I'm in the process of building an engine for a customer now that I'm using the King xpg bearings and that's what I picked for my personal car also. I really like the full 360 groove design for better rod oiling. I can't offer any experience with cams except BC 280's which a friend picked up about 40whp on an FP red with over stock cams. Maybe call a couple shops and ask what they think. I know a couple have tested cams. I like the fluidampr and the rest of the build looks fun.
kakarot09 is offline   Reply With Quote
Old 01-31-2013, 01:21 PM   #13
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
I would like to be around 500whp and mid 400's for torque, howver, I'm not a number chaser as much as a porsche and corvette chaser on the track. So endstate numbers dont matter as much to me as overall performance and useable power. This build will be strictly run on E85 w/ the potential to do a tune on race gas later. I dont know if the 1300cc injectors can be stretched that far, guess it will be up to the tuner. I have been greating results running E85 as has everyone I have talked into running the Jesus Juice. I have heard about the Manley I Beams as well as their new H-Tuff. I think I may go with the H-Tuff, if I can find a little more info on them. King XPG bearings you say? I'll see about ordering some. I like the cost effectiveness of the BC cams, however there are many quality cam makers out there. We'll see on the cams.
Old 01-31-2013, 01:22 PM   #14
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
I mistakenly wrote 375, i meant to write 350/350. I dont have dyno plot info currently, we had the boost @ 24psi however that wasn't very efficient on the VF43. For the current tune it was dialed in at 22.
Old 01-31-2013, 07:17 PM   #15
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Tossing around the idea of pinning or sleeving the block after talking with the engine builder today. Power goals don't necessarily warrant either and the bores are clean and don't need to go bigger but that extra piece of mind is always nice. Any arguments to justify the cost either way?
Old 01-31-2013, 07:46 PM   #16
bigbenp
Member#: 216142
'04 & 11 STi's
'10 & 14 Foresters
Are you porting & building your own heads after they're decked?
bigbenp is offline   Reply With Quote
Old 01-31-2013, 08:31 PM   #17
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
That's the intent, yes. I plan on getting the combustion chambers machined to match the 2.5 and decked at the machine shop then I will port and assemble.
Old 01-31-2013, 09:35 PM   #18
bigbenp
Member#: 216142
'04 & 11 STi's
'10 & 14 Foresters
I'm stoked dude, subscribed and in the same city. If you need an extra wrench, PM me!
Old 01-31-2013, 09:36 PM   #19
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Will do. Cam bolts are stuck on the exhaust cams.....any suggestions?
Old 01-31-2013, 09:40 PM   #20
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
drill em
Old 01-31-2013, 09:43 PM   #21
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
Originally Posted by Paul View Post
drill em
And then replace them with the hex head bolts from newer models?
Old 01-31-2013, 11:24 PM   #22
kakarot09
Member#: 182375
08 Sti
Wrbm
Spray some PB blaster all over the bolt, hit the bolt with an impact gun for several seconds repeat process and then try a big breaker bar again. Doesn't have to be a strong impact just enough to vibrate. I used a little 12v 1/4" drive last time and it worked. I've also drilled them before I tried that.
Old 02-01-2013, 12:19 AM   #23
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
I have snap-on hardened 10mm hex socket and a 1/2" breaker and a can of map gas for those f******
Then when that fails a carbide bit. Have fun
Flat 4 Motorsport is offline   Reply With Quote
Old 02-01-2013, 01:29 AM   #24
kakarot09
Member#: 182375
08 Sti
Wrbm
lol. I've twisted my snap on 10mm bit before. Those things are on there! I broke a couple loose much more easily the way I mentioned above though. I was pretty surprised. I weight around 185 lbs and I've hung off of my 1/2" breaker bar before trying to get those things off LOL
Old 02-01-2013, 08:28 AM   #25
suba03ru
Member#: 214982
2003 WRX-Rotated
Closed Deck, E85
I think I'm at the carbide bit point. I've snapped three wrenches, two sockets, and I've tried a big breaker bar and I weigh 230 and no joy. I'll try the impact for the good vibes today lol.
