Old 01-30-2013, 10:33 PM   #1
TXSoobieNoobie
Member#: 345103
2004 WRX Limited
Black/Black
Default 2.0L WRX 04 Compression Test...Low Numbers
So Im looking at buying a car and I took it in for a compression test before I bought it.
The car has just under 80k miles and looks to have been pretty well taken care of, but from reading around, almost everyone has compression numbers around 145-150
My numbers were 133, 134, 136 and 138.
I really like the car and the price is right, so I want to pull the trigger, but I dont want to make a mistake.
My tuner said it needed a tune (TBE, STI Uppipe, CAI) as it was running a little rough, but otherwise he gave it the thumbs up.
I know this is still within the service range, but should i take this as a sign the car isnt running as well as I thought or am I worrying too much?
Thanks.
TXSoobieNoobie is offline   Reply With Quote
Old 01-31-2013, 01:34 AM   #2
04ScoobyWtf
Member#: 287974
If you trust your tuner then pull the trigger
1. Tuner
2. Internet
04ScoobyWtf is offline   Reply With Quote
Old 01-31-2013, 01:35 AM   #3
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I don't like that the car is running rough but the numbers are close enough. I would also do a leak down.
Old 01-31-2013, 08:40 AM   #4
cmiovino
Member#: 134005
2004 WRX Premium
My concern would be how long it's been running with those parts and no tune.
Old 01-31-2013, 08:49 AM   #5
shano
Member#: 223839
2004 WRX
Java black
Ditto on the above comment.
Although you may be able to use that as a "price negotiator" and score a really good deal and it may turn out alright. Worst comes to worst.... stroker/twin scroll/avcs build?
shano is offline   Reply With Quote
Old 01-31-2013, 09:03 AM   #6
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
If it's running a tbe and cai untuned, I more then likely would run from this deal. The 04+ models have to be tuned with those upgrades. Earlier years can get away with it.
04wrxhart is offline   Reply With Quote
Old 01-31-2013, 10:40 PM   #7
Member#: 301037
2004 Forester XT
As far as the compression numbers, as long as they are above 125 or so and are grouped close together you should be fine.
You do need to get it tuned for sure.
art@grimmspeed is offline   Reply With Quote
Old 01-31-2013, 10:45 PM   #8
TXSoobieNoobie
Member#: 345103
2004 WRX Limited
Black/Black
thanks for the help everyone
decided to pull the trigger on the deal and just "drive it like a grandma" until I can get it tuned. will post before/after dynos.
Old 04-22-2013, 11:49 PM   #9
TXSoobieNoobie
Member#: 345103
2004 WRX Limited
Black/Black
Motor blew.
So much for that.
Old 04-23-2013, 12:22 AM   #10
corvallisbattery
Member#: 333030
'05 WRX
Really!? What happened??
corvallisbattery is offline   Reply With Quote
Old 04-23-2013, 01:44 AM   #11
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Two months no tune?
Old 04-23-2013, 08:20 PM   #12
TXSoobieNoobie
Member#: 345103
2004 WRX Limited
Black/Black
Clutch started slipping on dyno. Car went down for that. Then once I had about 500 miles on it, I took it in to get tuned. Made like 210/230 or something like that. Car blew on the way to work from getting it tuned March 7th and has been sitting since.
Old 04-23-2013, 08:22 PM   #13
Member#: 301037
2004 Forester XT
Sorry to hear that. Judging from the numbers it was not very healthy for the tune. Surprised the tuner did not notice anything
Old 04-23-2013, 08:24 PM   #14
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
What about it blew? Spun bearing, piston, timing belt skip?
2gnt2wrx is offline   Reply With Quote
Old 04-23-2013, 08:56 PM   #15
TXSoobieNoobie
Member#: 345103
2004 WRX Limited
Black/Black
Those numbers are too far off from what many similar setups dyno'd. It was around 198/210 on the basemap.
Spun bearing.
