Old 01-31-2013, 01:32 AM   #1
JOHN2011WRX
Member#: 290367
2011 wrx
Default 2011 Wrx Stage 1 Logs
I got a 2011 wrx with catback and turbosmart hybrid bov set to vent to atmosphere. i just flashed cobb stage 1 and everything looked good. After a couple days my A/F learning 1 started fluctuating between values when car is idling or in gear but no throttle is being applied. It has been gradually increasing over the past days, its gotten as high as 3.91 and as low as -.8. Can you guys take look, n tell what might be going on.
Hear are my 3rd gear pulls from when i first flashed and then the other ones.
https://docs.google.com/spreadsheet/...4TGRtQXc#gid=0
https://docs.google.com/spreadsheet/...LOFFQWmc#gid=0
https://docs.google.com/spreadsheet/...CWU52REE#gid=0
JOHN2011WRX is offline   Reply With Quote
Old 01-31-2013, 01:36 AM   #2
JOHN2011WRX
Member#: 290367
2011 wrx
oh yea its running ACN91 MTv300
Old 01-31-2013, 09:31 AM   #3
Cobb Tuning
Member#: 4803
You'll need to set the permissions to public in order for anyone to view the logs.
A/F Learning 1 can move around quite a bit. There are actual 4 values that make up this monitor, with 1 of the 4 being applied at any given time (based on airflow). As long as you are within around +/- 5%, you are fine. If you are well outside of that at any time (say +/- 8% or worse), then there's most likely some kind of fueling related issue.
Bill
Old 01-31-2013, 07:11 PM   #4
JOHN2011WRX
Member#: 290367
2011 wrx
Old 01-31-2013, 10:36 PM   #5
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
still not viewable.
bluemax189 is offline   Reply With Quote
Old 02-01-2013, 01:32 AM   #6
JOHN2011WRX
Member#: 290367
2011 wrx
Old 02-01-2013, 02:43 AM   #7
JOHN2011WRX
Member#: 290367
2011 wrx
The logs are now available. Can you please review
Old 02-01-2013, 09:37 AM   #8
Cobb Tuning
Member#: 4803
Everything looks good in this log. Enjoy!
Bill
Old 02-01-2013, 03:30 PM   #9
JOHN2011WRX
Member#: 290367
2011 wrx
Bill
THANKS FOR LOOKING.
THE A/F LEARNING IS GOING UP. ALSO WHEN AT IDLE FOR ABOUT 5-10 MINUTES IT CAN GO UP TO 7.0-9.0 BUT AS SOON AS I STEP ON THROTTLE IT GOES BACK BELOW 3.0.
I DID ANOTHER 3RD GEAR PULL.
https://docs.google.com/spreadsheet/...3cGhsMEE#gid=0
Old 02-01-2013, 03:42 PM   #10
Cobb Tuning
Member#: 4803
THANKS FOR LOOKING.
Can you get a log showing the 7-9% A/F Learning 1? In this log (and the other one) there are not those more extreme values.
Bill
Old 02-01-2013, 08:08 PM   #11
JOHN2011WRX
Member#: 290367
2011 wrx
TURNED CAR ON AND LET IDLE FOR ABOUT 5 MIN
https://docs.google.com/spreadsheet/...4SjVnRmc#gid=0
AFTER IDLING FOR ABOUT 10 MIN, A/F LEARINING WAS AROUND 10 WHEN I GIVE IT THROTTLE IT STARTS TO GO DOWN
https://docs.google.com/spreadsheet/...uaEJDOVE#gid=0
TOOK THE CAR FOR A DRIVE THIS IS 1-3RD GEAR
https://docs.google.com/spreadsheet/...VNU9NX2c#gid=0
Old 02-02-2013, 10:46 AM   #12
Cobb Tuning
Member#: 4803
You are running the stock intake, correct?
I would say that you probably have an intake tract leak. This lets in unmetered air that causes the car to go lean and therefore A/F Learning 1 increases to compensate (in this case +10% is extreme). Your best bet is to get a pressure or smoke test of the intake tract done. This can be done by various shops (although I would try to stick to a Subaru performance shop). If you have an air compressor, you can also build your own pressure test rig (search for DIY pressure test here on Nasioc).
If you find a leak and fix it, then reset your car's ECU via the function found in the troubleshooting menu of the Accessport. Then do additional data logging to confirm. A/F Learning 1 is actually determined from 4 stored values that are determined/applied based on different airflow ranges -> A/F Learning 1 A,B,C,D. You can view all these at once by simply logging them or viewing via live data (so you won't have to actually drive to hit all 4 ranges).
Bill
