Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 01-31-2013, 09:28 PM   #1
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Default +2mm Rods
Who currently has these available, and what are the prices? I am looking for something appropriate for the 500-600 WHP range. Probably mate them with a Manley stroker piston with a 26cc dish
I know MPS has badass Suoer H-beams for $900, and is working on another budget +2mm for the summer time
3MI has some but I am not sure specifically what...aside from the Honey Badger, which are way more than I need or can afford.
I noticed ASF Machine used to sell these, or something similar, but I have found no info on them. http://www.catpep.com/searchengine/s...00&parttype=43
aboothman is offline   Reply With Quote
Old 01-31-2013, 10:25 PM   #2
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
iirc pauter also offers +2mm rods.
john 1badSTI is offline   Reply With Quote
Old 01-31-2013, 10:52 PM   #3
Matty_STi
Member#: 333602
2012 STi
If I remember correctly the honey badger rods are 300M alloy not 4340. The regular +2 rods I believe are cheaper.
***dont hold me to this and I'm sure Micah will pop in at some point***
-Matt
Matty_STi is offline   Reply With Quote
Old 01-31-2013, 10:53 PM   #4
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I think you are right. Spoke with Micah a while back and I came to the conclusion that they are way more that what I need. I will shoot him a PM tho.
There is a set of +2mm Pauters in the classifieds. I thought they were custom order. They are a little more than I need price and strength wise, but they are one of my options right now.
Old 01-31-2013, 11:06 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
-Matt
You are correct. We asked for 300m and L19 hardware.
In fact I just spent a good portion of the afternoon working on one for a customer.
Old 01-31-2013, 11:57 PM   #6
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
I have a set of those rods linked in the first post...
http://www.ebay.com/itm/SUBARU-EJ18-...sories&vxp=mtr
Got them cheap a while ago, they look good and measure out well. I bought them cause I'm a hoarder, haven't used them yet.
theotherguy is offline   Reply With Quote
Old 02-01-2013, 07:30 PM   #7
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Anything else out there?
Old 02-01-2013, 07:33 PM   #8
Matty_STi
Member#: 333602
2012 STi
Does BC have some?
Maybe shoot Dustin a PM
Old 02-01-2013, 07:58 PM   #9
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Does BC have some?
Nope. No demand
Old 02-01-2013, 08:16 PM   #10
bebesito21
Member#: 176128
5862 ...baby boosted
I was looking for these too. Decided I'm gonna bite the bullet and get mps rods. More than I need yes but Dom knows what he's doing and why not have the extra security running hi boost hi rpm. That's the whole point of a long rod destroked setup. Also the weight savings is important.
Asf can still sell u the rods if u call they are ~300 for the set iirc but he warned me that he isn't comfortable recommending them for over 8k-8500k rpm and over 500whp. I'm sure I would eventually eclipse both. They broke a rod in the dksmshr car at around 600whp
bebesito21 is offline   Reply With Quote
Old 02-01-2013, 10:44 PM   #11
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Ya I had a set but sold em. Kind of wish I had not but they were overkill for what I needed and the money was better spent elsewhere on the build
Old 02-04-2013, 03:08 PM   #12
3MI Racing
Member#: 200987
What are you looking for exactly? I'm guessing you're doing a lower cost destroke using off the shelf pistons?
I can get you whatever you want and I've thought about stocking some 4340/L19, +2 (132.5mm) rods as I've had several people inquiring.
-Micah
3MI Racing is offline   Reply With Quote
Old 02-04-2013, 03:57 PM   #13
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Ya I am doing a +2mm rod build with shelf Manley stroker pistons (or JE Hybrid Pistons) and a 79mm stroke OEM crank. Nothing outrageous as I am keeping my current 30r setup through break-in, but I may throw a GTX30r or 3576 on at some point. MAX 500 WHP GST style, but around the 400 WHP mark most of the time. After spending a lot of time crunching CR numbers from my other thread I figured this is my best bet. Around 26cc dish, the D25 heads I have, and rods to match.
May be picking up the +2mm Pauters I mentioned before, but a moderate level +2 rod would probably not be a waste of your time. Something like MPS used to stock. Good for those of us not going for the kill.
Any more power, or dedicated track plans, and I would do a real +4mm/75mm stroke and do it right
Old 02-07-2013, 01:09 AM   #14
3MI Racing
Member#: 200987
Ah, so doing a +2mm rod on 79mm, just how I like to set them up (see the Honey Badger). The lengthened rod is a joke as far as calling it a long rod (see Crawford) but it can allow you do design for lighter internal to reduce reciprocating mass.
26cc dish, won't that have you down in the 7.xx range?
Old 02-07-2013, 01:42 AM   #15
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Exactly! After our discussions and most descriptions of the true long rod/ destroke setup, I don't think it's what I need for now.
This particular build is using D25 heads (the ones i was considering trading or selling that I PM'ed you about) so it should be around 8.5 CR with .020" HGs, and a good quench area. The +2 rods have the positives you mentioned, and they let me run a piston that will fit with the D25 heads.
Of course I realized, belatedly, that JE makes a piston with a 26-26.4cc dish for hybrids with EJ20 heads...
Old 02-23-2013, 10:16 AM   #16
jacky599r
Member#: 137631
2006 WRX
Red
Op have you had any luck getting reasonably priced +2mm? Im putting my build on hold and see if its possible to build my half assembled block with +2mm instead of Manley H beams... what kinda CR would this be on a stock HG and wiseco 100mm?
jacky599r is offline   Reply With Quote
Old 02-23-2013, 11:39 PM   #17
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Nah I ended up picking up those Pauters I was looking at. Micah hinted at offering a budget +2mm rod in the future if there is enough interest tho...
