Old 02-01-2013, 05:52 PM   #26
shahabshaukat
Member#: 343446
2002 WRX Wagon
so if we swap red and green it should all be fine?
shahabshaukat is offline   Reply With Quote
Old 02-01-2013, 06:01 PM   #27
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
yes45
BeBop86 is offline   Reply With Quote
Old 02-01-2013, 08:39 PM   #28
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Not according to how vision.dynamix said it should be.
WRX_02_227 is offline   Reply With Quote
Old 02-01-2013, 08:59 PM   #29
projectQWKSLVR
Member#: 285270
03 WRX
I want to see the back of the lamp with the cover for the high beam pulled back. Lets chase these wires from plug to bulb.
Guess I'll know for sure next week when the FedEx guy drops them off. :-)
projectQWKSLVR is offline   Reply With Quote
Old 02-01-2013, 09:04 PM   #30
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
I don't think the issue is with the bulb wiring. I think it's the signal plug that is wired wrong.
Old 02-01-2013, 09:20 PM   #31
projectQWKSLVR
Member#: 285270
03 WRX
I agree it's the connector itself that doesn't match the OEM wiring, but seeing exactly what goes where will make it easier for those of us that want low beam on with high beam, using HID low and halogen high.
Old 02-01-2013, 09:25 PM   #32
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
they make reps now? ARGH!!!!
djerickd is offline   Reply With Quote
Old 02-01-2013, 10:00 PM   #33
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
for $370 I don't think it's that great of a deal. By the time you end up upgrading components, they will cost as much as the real thing.
illmatic is online now   Reply With Quote
Old 02-01-2013, 10:14 PM   #34
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Well I was lucky enough to find damaged black chromes (HID) JDMs for 350$ including ballasts and leveling motors switch. I repaired them with jbweld.
I dont think I would have ever paid 600$+ for a jdm pair to hack and retro them like I did. But at that price (the depo) it kinds of make sense, but at the same time it is not really that much of a deal.
It will be interesting to see how they are made on the inside and see if they are easy to work on, do they give more room for larger projectors. On mine there was not much meat left on the projector bracket once I was done installing the rx350bx.
I wired my jdm low beam to be on all the time except when switch is to off and handbrake pulled. I used the common positive (middle wire) of the 9007 connector to trigge my low beam relay feeding the ballasts. High beam is simply another relay triggered by the high beam switched ground and common positive.
frederik is offline   Reply With Quote
Old 02-01-2013, 10:24 PM   #35
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Does it look to you like they are 3 inch lenses? Or do they use smaller lenses than the jdms?
Old 02-01-2013, 10:28 PM   #36
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I got a set of real deal black chrome JDM's up for grabs PM me!
Old 02-02-2013, 02:53 AM   #37
dictoresno
Member#: 139816
2002 WRX, VF34 swap
heres a link to them on ebay. i actually just bought a blacked out pair of Depo lights (pair from amazon for $134) because my old ebay blacked out ones were cracked from a fenderbender and hazed over a little. i must admit, the Depo ones are almost perfectly identical to the stockers. the other ebay brands are a little different in terms of their wiring and or back pieces that hold the bulbs. the generic ebay ones fit and work fine, but i specifically wanted an as closest to stock i could get in terms of quality. the Depo branded ones are definitely the way to go. unfortunately i never saw these before, wish i couldve got them, they look awesome.
http://www.ebay.com/itm/DEPO-02-03-S...a80090&vxp=mtr
it says they are 9005 low beams, H1 high beams and include the PnP 9007 connector
dictoresno is offline   Reply With Quote
Old 02-02-2013, 03:51 AM   #38
CT26SupraTurbo
Member#: 213393
2003 WRX
Tomei Powered
Just bought one with HID kit they offered for little more. I was going to pull trigger with JDM headlights but one i v found was too beat the **** up.
I will do reviews once those comes in. I do not expect too much from their HID kit but i specified for 6000k instead of 8000k -_-
so to sum it up,
high beam - h1 need to buy for high beam
side marker - bugeye stock?
low beam- 9007 or 9007 hid?
turn signal - i kinda want it orange or yellow but i wonder what they use. can we reuse stock?
and reverse pin for red and green at 9007 connector?
CT26SupraTurbo is offline   Reply With Quote
Old 02-02-2013, 10:39 AM   #39
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
I'm interested in some pics and reviews as well. If they have a 4300k HID kit that works well out of the box without any retrofitting, I would be all over that. Otherwise, I'm ok with a good set of halogens too.
iyzmi is offline   Reply With Quote
Old 02-02-2013, 11:12 AM   #40
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
For the price of the HID's........ it's getting close to the same price as picking up a set of authentic JDM HID's. I also don't like the way they did the reflector around the projector, the seam is awful. Best ebay headlight ever though, if the real ones were still selling at $1k this would have been a steal, they are just a few years late to the party.
LIQUIDSK8S is offline   Reply With Quote
Old 02-02-2013, 12:01 PM   #41
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Regarding being late to the party, I think until recently thete was no much choices for bugeyes, either usdm replicas or ugly ebay style.
Recently with the usdm retrofitted look ones ans the other projector with LEDs, maybe they saw they would lose market and released the nicer headlight that should outsell the other questionable looking projector headlights that are not that much cheaper than the replica jdm.
And if we cant really agree if the price is good or not so good I guess they made a good job at evaluating how much people are ready to pay for these.
I guess we will soon see thread from people saying they have xyz problem with their "JDM" hid headlights they thought genuine when in fact they have replica halogen projectors with a H1 PnP kit in. But at the same time we should see less people running jdm without modding the shields, which is a good thing.
Old 02-02-2013, 02:17 PM   #42
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I meant they were late to the party regarding price. With the authentic lights costing $100-150 more, these replicas are overpriced IMO. Had they come out a few years ago when the real lights were fetching $800-1000 it would be a great deal.
Old 02-02-2013, 02:25 PM   #43
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
My insurance company just paid out $1400 for the JDM lights that were on my car. :P
Old 02-02-2013, 02:46 PM   #44
projectQWKSLVR
Member#: 285270
03 WRX
Dink! lol
Old 02-02-2013, 03:37 PM   #45
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Are you talking about new or used JDMs?
Old 02-02-2013, 03:56 PM   #46
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
Used, who on earth would pay the ludicrous price for new ones??
I bought a set of black HID's for $550 and a set of chromes for $450. There are some great deals out there if you know where to look. On average they are $600
Old 02-02-2013, 04:06 PM   #47
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Well someone had to pay the ludicrous amount to make them used
Old 02-02-2013, 04:16 PM   #48
kurlyfries
Member#: 282131
2006 tacoma
black
Sorry I haven't updated it yet, I've been swamped between work and school. I should have time to work on them tonight or tomorrow
kurlyfries is offline   Reply With Quote
Old 02-02-2013, 04:34 PM   #49
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
No, majority of the used JDM's are taken off of wrecked STi's. All of these used JDM's were not purchased new separate from the vehicle.
Old 02-02-2013, 06:47 PM   #50
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Where do you buy the real ones if you don't mind me asking?
